05-02-2017, 03:49 PM | #15527 |
Drives: 2013 BRZ Limited / 2015 Q50S
Got in on the $100 rebate the day before it expired, showed up this morning.
The Following User Says Thank You to BRZyJ For This Useful Post: | 15limited (05-03-2017) |
05-02-2017, 04:28 PM | #15528 |
Drives: Subaru BRZ
05-02-2017, 05:15 PM | #15529 |
Drives: 2015 Subaru BRZ Premium
Custom Muffler Delete Pipe
Bought a couple exhaust pipes and a coworker helped me build and install a muffler delete track pipe.
It's got a nice, deep growl to it. Sounds amazing in 1st gear. If you're in the TN region and interested in one, let me know! |
05-03-2017, 02:54 AM | #15530 |
Senior Citizen
Drives: 2015 WRB BRZ
Finished up installing my EB-S/C. Amazing kit, two |
The Following 5 Users Say Thank You to Dan37BRZ For This Useful Post: | BirdTRD (05-03-2017), imnotsureaboutbrz (05-03-2017), justinco (05-04-2017), sprintertrueno86 (05-03-2017), yberther (05-10-2017) |
05-03-2017, 10:13 AM | #15531 |
Drives: wrb brz
Installed Valenti Euro Winker relay. Install was a freaking pain in the ass, couldn't get that original relay out. Was seconds from going mad and brute-forcing the old one.
[ame="https://www.youtube.com/watch?v=OKu1rc4Tr1Y"]ヴァレンティ ユーãƒ*ウインカーリレー - YouTube[/ame] Last edited by piotrr; 05-03-2017 at 06:44 PM. |
05-03-2017, 06:32 PM | #15532 |
Drives: 2017 Subaru BRZ WRB PP
05-03-2017, 06:41 PM | #15533 |
Senior Misanthrope
They feel like brakes. Any real change in feel is down to pad choice and tires. I got this kit due to its higher heat capacity and thicker brake pads. In theory, it will pay for itself after a lot of track use.
05-03-2017, 07:46 PM | #15534 | |
Senior Citizen
Unfortunately they might be for sale soon, they won't clear my Brembo GT BBKs. |
05-04-2017, 08:56 AM | #15535 |
Drives: 2022 GR86
05-04-2017, 01:35 PM | #15536 |
Senior Misanthrope
It's okay; they're frequently misunderstood. Lots of people think BBK = more stopping power, but that's not really the case in most situations. If your stock brakes can hit ABS, then they have enough stoppingpower--the limiting factor is the tire, not the brakes. Stickier tire = shorter stopping distance.
The natural first upgrade for performance use is some better brake pads and fluid. "Better" in this case means they have a higher operating temperature and can take more abuse before they fade/boil. With street tires, on most tracks, the OEM brake calipers with good track pads will be sufficient. The primary reasons to upgrade to a BBK are heat capacity, pad availability, longevity, weight, and decreased caliper flex. For instance, the AP sprint kit caliper is much stronger and more rigid than the OEM calipers. It also accepts larger and thicker pads, meaning they'll last longer. The rotors are vented more for better cooling. And because the rotors are two-piece, the hat can be made of aluminum instead of iron, saving lots of weight. edit: there are street-appropriate pads that have a higher initial bite than the OEM pads. Something like that might provide the sort of feel you're looking for. Not sure what pads would do the trick, though. |
The Following 3 Users Say Thank You to kch For This Useful Post: |
05-04-2017, 02:37 PM | #15537 |
btr.life
Drives: 2022 GR86
Just to add to what kch said, which is all good info. Especially about the tire being the most important part.
I did notice the AP brakes seem to have better clamping power over the stock calipers (not necessarily the same as stopping power). Or, it could be a combination of the caliper and SS brake lines providing improved feel and feedback. But, there is definitely an improved feel in the pedal under hard braking, like the calipers are squeezing a lot harder than the stock calipers (I am using the same type of brake pad and same tires as when they were stock).
The Following User Says Thank You to justinco For This Useful Post: | bentleyboii (05-04-2017) |
05-05-2017, 10:21 PM | #15538 |
Drives: 2015 BRZ Ltd
I went from stock brakes --> SS lines --> pads --> rotors --> to a BBK
The biggest change is the ability to deal with heat which equates to braking power (ability). My current set up (RR-racing stage II) is not up there like the AP Racing kit but its cost effective and is a massive improvement over stock for the trackday pounding it gets. Not sure I would have gone down the same route for street use.
2015 BRZ Ltd trackday speciale (eventually) | 2017 BMW M3 Competition Pkg
Gone: 2011 G37S | 2009 WRX Wagon | 1998 C2S garage queen | 2006 Mini Cooper S | 1997 C2S trackday speciale | 1999 ///M Coupe | 1990 E30 ///M3 | 1997 Corvette | 1993 205 1.9 GTI | 1997 328is |
The Following User Says Thank You to Surj_brz For This Useful Post: | bentleyboii (05-07-2017) |
05-07-2017, 06:44 PM | #15539 |
Project Shadow
Drives: 2015 BRZ Limited 6MT
After waiting for over a month, the car was finally picked up and is on its way to FullBlown Motorsports. I had to call another transport company and cancel with the other one because they weren't doing anything. Luckily I got a full refund. Car will return in about a month.
The Following User Says Thank You to Drakiv For This Useful Post: | D_Thissen (05-07-2017) |
05-08-2017, 08:37 PM | #15540 |
Black housing tail lights...thought about doing the DIY but I wussed out and just got the Depos
The Following 7 Users Say Thank You to BRZyJ For This Useful Post: | B-R-Z (05-09-2017), BirdTRD (05-09-2017), Brayden_23 (05-11-2017), Drakiv (05-08-2017), Husker BRZ (05-08-2017), KR-S (05-09-2017), norcalpb (05-08-2017) |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 10:35 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 08:53 AM |
