12-16-2015, 01:04 AM | #141 | |
Consult with your builder and tuner, to see if it's appropriate for your specific setup. |
12-16-2015, 01:06 AM | #142 | |
Drives: '15 FRS
The Following 2 Users Say Thank You to VitViper For This Useful Post: | CSG Mike (12-16-2015), FRS Justin (12-16-2015) |
12-16-2015, 01:10 AM | #143 | |
Drives: 2013 Asphalt FRS
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
12-16-2015, 01:18 AM | #144 | |
( by the way I saw the Honda you tuned kicking serious ass at the track. Full beast mode) AND PUT UP A VIDEO WITHOUT YOUR TRACTION CONTROL ON. FROM A ROLL IS FINE!!!! Please
12-16-2015, 01:23 AM | #145 |
Drives: '15 FRS
I don't need to turn it on or off... The traction control only engages when I'm at the limit of the tire and keeps the vehicle at steady acceleration... at the limit of the tire. Wheel spin really isn't all that cool.
12-16-2015, 01:34 AM | #146 | |
12-16-2015, 01:39 AM | #147 | |
I thought you like wheel spin using launch control on stock tires smh
The Following User Says Thank You to FRS Justin For This Useful Post: | wise345 (04-20-2016) |
12-16-2015, 01:40 AM | #148 | |
12-16-2015, 01:46 AM | #149 |
12-16-2015, 01:52 AM | #150 |
Still waiting to see all those records you hold.
Not sure what I need to prove, it should be pretty obvious to you if you really have experience building engines, that 300hp NA on a bottom end is not out of the question at all. Hell, I'd bet it could be done with just fuel and nitrous. |
12-16-2015, 02:01 AM | #151 | |
we already schooled you that nitrous is not N/A AND to hit 300hp on a 2.0 fa20 stock bottom end N/A is not possible But I did see you drifting a frs through a pretty sharp off camber which takes some skill. That was impressive I must admit. So stop screwing around and get to the front of the pack....... edit: I was wrong you can drive and I will say it right here I was wrong you could be a front runner
12-16-2015, 02:15 AM | #152 | |
Nitrous, while adding oxygen content, does not stop the engine from naturally sucking in the air itself. Forced induction would imply that the pressure inside the manifold is above atmospheric, due to something forcing air into the engine, causing it to imbibe more air than it can on its own. Since you're a drag racer, I can see why you would consider Nitrous FI; it's not "all motor". While excluded from "all motor", it's still not forcing a positive pressure into the manifold, the engine is still aspirating on its own. |
12-16-2015, 02:16 AM | #153 | ||
Drives: '15 FRS
And then there's launch control. And traction control. Which are not the same thing as boost control. You cannot achieve optimal acceleration using simply boost control. It'll never happen -- I'm not going to explain to you why. Why don't you just try it yourself. So... tell me again why I care about AMS's boost control system? Quote:
Or just continue to display this level of ignorance, it is quite amusing, to say the least, lol. |
12-16-2015, 02:24 AM | #154 | |
Drives: 370z
The reason that na doesn't need as strong internals as fi is because you are normally limited by the amount of air that you pull in. You can make it as efficient as you want and there is still a max bmep that you cannot surpass. but if you are saying nitrous counts, nitrous causes pretty insane cylinder pressures, so the end effect is the same as fi. You get hp with more air instead of more revs. Edit: of course that is assuming you are using nitrous ALL THE TIME. The fact that it is just sporadic makes it like a scramble button on a fi. It would be like if you normally ran super low boost then periodically ran short stint at high boost. Is the failure rate acceptable with that usage? Who knows |
The Following 2 Users Say Thank You to totopo For This Useful Post: | CSG Mike (12-16-2015), FRS Justin (12-16-2015) |
Tags |
kill brain cells, not facts |
Similar Threads | ||||
FlexFuel and Facts | Shiv@Openflash | Software Tuning | 69 | 10-16-2019 01:08 PM |
Anyone Else? Hearters Blowing when off. | Kiske | Issues | Warranty | Recalls / TSB | 7 | 04-09-2014 05:22 PM |
How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 03:29 PM |
Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 09:14 PM |
Facts you may or may not know about your GT86/BRZ/FR-s | FiRStsc10n | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 07-09-2013 03:05 PM |
