12-18-2015, 02:55 PM | #141 |
Drives: red frs
Skip barber racing school = best mod you'll ever do on a car
heel toe downshifting all day |
12-18-2015, 03:09 PM | #142 |
Drives: 2014 BRZ Limited
12-18-2015, 03:13 PM | #143 |
Benched 86lb
Drives: Ultramarine FR-S
I never hold on the clutch, unless it's nearly "go time", or if I need to be on alert for some reason. Otherwise, any neutral action is done by being in neutral.
12-18-2015, 03:20 PM | #144 | |
When I was learning to rev match, I had to change the way I thought about it. Instead of worrying about the exact RPM to hit, I started thinking of the transmission input speed as a hook moving down and the engine RPM as a ring. Then I just used the accelerator pedal to toss that ring up there so that it hooked on the transmission speed. If I tossed it too hard or too soft, it wouldn't work. If you were playing a ring toss game in real life, you wouldn't sit there trying to calculate the speed of the ring and the speed of the hook and the distance between them and the wind direction and velocity. You'd just toss it up there and miss. Then you'd adjust by feel until you tossed it just right to catch on the ring. Soon you'd be able to do it every time. Ring toss in a car is the same, except that the hook is moving a different speed in each gear. So downshifting into 4th takes a lower toss of the ring, while going into 2nd takes a higher one. You just keep tossing those engine RPM up onto the transmission by feel, and eventually you'll just do it without thinking about it. |
The Following User Says Thank You to extrashaky For This Useful Post: | Celica00 (12-18-2015) |
12-18-2015, 04:09 PM | #145 |
Drives: 2014 BR"ZED" Sport-tech DGM MT
It's just an expression/saying |
The Following User Says Thank You to FLYFISHR For This Useful Post: | Ultramaroon (12-18-2015) |
12-18-2015, 04:14 PM | #146 |
12-18-2015, 04:25 PM | #147 | |
Drives: Toyobaruion
This. It's all by feel. too many variables to give you an specific "amount" of blip, especially depending on your deceleration rate. |
12-18-2015, 04:56 PM | #148 | |
Drives: 2013 GBS BRZ Limited
And "Adjustable Spanner" is actually much more descriptive than "crescent wrench". Now don't get me started on Al-U-Mini-um. The brits version of the pronunciation is actually correct for the element Aluminium. (funny spell checker is trying to 'fix' my spelling right there...) However the alloy that we are all familiar with is pronounced Al-oo-Min-um in Murica. |
12-18-2015, 05:12 PM | #149 |
Benched 86lb
12-18-2015, 05:27 PM | #150 |
chicken tonight
12-18-2015, 07:34 PM | #151 |
Spell checker want's to change about 10% of what I type. It really, really hates colour.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Ultramaroon (12-18-2015), _Kodiak (04-05-2020) |
12-18-2015, 07:51 PM | #152 |
Drives: 2013 Brz C38 (bought not built :P)
or anything with iser or yser
analyse, nope analyze recognise nope recognize Think americans just felt bad for the z being used so little. also it's pronounce ""zed" not "zee" |
The Following 4 Users Say Thank You to fumanchu1 For This Useful Post: |
12-18-2015, 11:36 PM | #153 |
chicken tonight
Soooo... it's working properly.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (12-18-2015) |
12-18-2015, 11:43 PM | #154 |
Well it seems to believe I is a 'Murican.
The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (12-18-2015) |
Tags |
kr-s is colorblind |
Similar Threads | ||||
Show us your Custom Roll Cage or Roll Bar and Harness Setup | Black Tire | Tracking / Autocross / HPDE / Drifting | 27 | 02-13-2015 09:59 PM |
downshift to first | swpbrz | Engine, Exhaust, Transmission | 13 | 05-07-2014 08:33 PM |
Has anyone actually seen any of the Cusco roll bar / roll cages installed? | xenocharger | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 06-03-2013 06:54 PM |
Car rattle at neutral. | IloveBaldEagles | Issues | Warranty | Recalls / TSB | 3 | 12-23-2012 06:55 PM |
Roll stiffness: Springs vs anti-roll bars? | Captain Snooze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 07-24-2012 05:44 PM |
