Old 06-27-2015, 04:56 PM   #141
erok81
Drives: 2015 BRZ
So...those sensors for the downpipe. How did yours go? Due to the bung locations only one of mine barely reaches (I could probably play it like a guitar string) and the other is about two inches too short. So I'm going to have to lengthen mine.
Anyone else ran into that?
erok81 is offline   Reply With Quote
Old 06-27-2015, 04:59 PM   #142
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
U cant use the clips that hold the wires to the block. Can u take a pic
Sent from my SAMSUNG-SM-N900A using Tapatalk
drambo136 is offline   Reply With Quote
Old 06-27-2015, 05:12 PM   #143
erok81
Drives: 2015 BRZ
I'm not using the clips. I tried swapping them since one is longer than the other. But even then I was an inch or so away from the plug.
Old 06-27-2015, 05:20 PM   #144
drambo136
drambo136's Avatar
Huh that's odd. Can u take a pic? Did u ever replace them?
Old 06-27-2015, 05:23 PM   #145
xxscaxx
Drives: 2013 SWP BRZ
My front O2 sensor was too short but bending the plug bracket down allowed enough space to connect it.
xxscaxx is offline   Reply With Quote
Old 06-27-2015, 05:24 PM   #146
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Update, still leaking. Tried a new flange, several gaskets and oil pan sealant. It leaks and only where the turbo and flange meet. I'm removing the turbo and taking a good look at it as something can't be right, this isn't normal and this leak can't be so persistent.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 06-27-2015, 05:24 PM   #147
erok81
Drives: 2015 BRZ
Nope. The car has 1500 miles total. Everything is stock. I took a pic but it's really just me pulling on a wire showing about an inch between the plug and the connector. It's the gray one that won't reach. It's going the shortest path too.
Old 06-27-2015, 05:25 PM   #148
erok81
Drives: 2015 BRZ
Are you using the new drain thing? My WRX had a precision turbo that leaked no matter what I did. I even tried making a gasket out of copper.
Hopefully that be fancy one will fix it.
Old 06-27-2015, 06:05 PM   #149
drambo136
drambo136's Avatar
Hey yomny how did u mount the intercooler to the crash bar?
Old 06-27-2015, 06:13 PM   #150
yomny
yomny's Avatar
I think this is my case lol. I've used everything and anything, even new bolts and washers every time i use a new flange. I've tried three paper gaskets, one new flange without gasket, instead using O-ring and finally oil pan sealant which seals the hell out of anything with oil, apparently it met its nemesis. I'm going to pull the turbo and check for cracks or any visual problems before going back to the original flange and more sealant. Open to suggestions guys, the oil has to be coming from somewhere else but as you see in most pics, every area around the drain port is leak free and clean.
This is with sealant, freshly installed, let it cure for 24hrs..
Here is its 24hrs later after a drive and letting it cool down.. leaking! its not horrible but you could see the oil between the sealant.
Here's third paper gasket, oem, already saturated with oil, the day after leaked.
Here's the O-ring flange, no paper gasket.. leaking.
Here's the new flange, the opening for the drain is almost twice as big as the turbo's opening, meaning anything and everything coming out of that turbo oil drain hole should fall well within, well it doesn't lol.
Old 06-27-2015, 06:43 PM   #151
erok81
Drives: 2015 BRZ
I am that point now. Looks like you just notch the crash beam for the ic outlets and then drill a couple holes on the underside of the crash beam.
Old 06-27-2015, 07:03 PM   #152
yomny
yomny's Avatar
That's right, mark where the intercooler inlet and outlet would go, take off just what's needed and then drill some holes where the mounting tabs fall on the crash beam. I'm going to post some pics in a bit from my install thread.
@drambo136
Check out this thread, first post you'll see a few good pics of the cutting areas and how to mount. Notice the crash beam on the passenger side has a square hole right in front of the intercooler coupler, I had to cut this open to reach the nut for the bolt secure the intercooler mounting tab, the driver side already has access.
http://www.ft86club.com/forums/showthread.php?t=81623
Old 06-27-2015, 08:45 PM   #153
erok81
Drives: 2015 BRZ
@yomny - is your bov on the passenger side? The way my outlets were sized my ends up on the driver side...
Old 06-27-2015, 08:56 PM   #154
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Those little drips are a pita @yomny. Hate to say it but really common with aftermarket turbo installs. Best thing I can say is don't use paper gaskets and clean the heck out of everything with brake cleaner before putting on any sealant. Then careful with the torque. Overdoing it will have the same effect. It is a low pressure system on the drain side (and coolant side really...) so you don't need torque so much, but a broad clean surface for the gasket maker to stick to and not lift off.
Xero-Limit is offline   Reply With Quote
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
Kris86 (06-27-2016), yomny (06-27-2015)
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 08:03 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
