Old 08-24-2013, 02:34 AM   #141
JiB
JiB's Avatar
Drives: GT86
ive read through this thread and seen a few guys running 17x9 +38 with 245/40.
Is there full clearance stock height? and also full clearance with 1in lowering springs?
JiB is offline   Reply With Quote
Old 08-24-2013, 11:26 PM   #142
toby714
Drives: whiteout
Originally Posted by Jive Turkey View Post
those tabs will rub REGARDLESS. you either let them rub themselves out or do what king tut and i did and dremel them out. in the front on the new setup you'll be okay with atleast a 245/40 or a 255/35 in the rear though you'll be a bit more aggressive than i am now, so you'll need like 2.5 degrees of camber unless you wanna run a stretched tire... should look good though!
also 265/40 is HUGE. go to a 265/35
any chance you can post of pics of how much you guys dremel off the rear? just want to get a general idea. thanks!
toby714 is offline   Reply With Quote
Old 08-24-2013, 11:52 PM   #143
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Cough.....
265/35/18 Hankook RS3 Square on 18x9.5 + 38 RPF1s
And our other car for STX on 255/40/17 Hankook RS3 Square with 17x9 +35 RPF1
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
red_comet (08-25-2013)
Old 08-25-2013, 12:12 AM   #144
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
swift springs with 17x9 35 rpf1's on 245/40. Need some more camber on the front
bkblitzed is offline   Reply With Quote
The Following User Says Thank You to bkblitzed For This Useful Post:
Goya (08-25-2013)
Old 08-25-2013, 08:19 AM   #145
red_comet
Severed Member
red_comet's Avatar
Drives: Argento 2013 Scion FR-S Manual
Here's a question for those of you who have the experience...
I'm looking at getting yoshihara design dy-12c in gunmetal, 18x8 et40 and wrapping them in BFG sport comp-2 (budget is a concern here, I know they aren't the best BFG makes) in a 235/40r18 size.
Is that going to land me a somewhat meaty sidewall/tread? I've looked up the specs and I'm leaning to "yes", but I'm not sure.
87 Volvo 760 Turbo <3
02 WRX THE QUEEN IS DEAD, LONG LIVE THE QUEEN!
06 Xfire Bite me I liked it
13 FRS doriftoooo!
DON'T PANIC
red_comet is offline   Reply With Quote
Old 08-25-2013, 10:45 AM   #146
mrk1
Drives: Sterling BRZ Ltd
Why do people makes excuses when buying Comp 2's? It's a good tire and much more street user friendly then say the Rival. I ran the G Force Sports for years on my last mini and loved them. Even preferred them to the higher price kdw. When my stockers wear out I plan on ordering comp 2's.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
John.Hong (08-26-2013), red_comet (08-25-2013)
Old 08-25-2013, 11:31 AM   #147
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Originally Posted by p00mba View Post
The following wheels specs on the new wheels i purchased and waiting to arrive:
Front-18x9 +38
Rear-18x10 +38
Current wheels:
Front - 18x8.5 +34
Rear - 18x9.5 + 40
Front - 225/40/18
Rear - 265 /40 /18
I'm dropped about 2 inches, basically no wheel gap, but i rub ever so slightly in the rear, the plastic tab where the bumper and body meets, it only rubs on hard turns or bumps in the road...
Your new wheel specs match the wheels I am getting. Work Emotion XD9?
AVodka14 is offline   Reply With Quote
Old 08-25-2013, 12:33 PM   #148
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
if by meaty sidewall you mean no stretch then yes. on an 8' wide rim the appropriate tire size is a 235/245 depending on brand. you should be square and fill out the entire rim.
however 235 isn't exactly meaty. with that offset you will be a little sunk, but i'm sure it will look good either way!
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
Old 08-25-2013, 12:40 PM   #149
red_comet
Severed Member
red_comet's Avatar
By square do you mean the width of the wheel's lip, the tire's rim width, sidewall section and tread width should be the same?
Because I'm looking at the sport comp-2's in 235/40r18 and it says the lip width of the tire is 8.5", wider of course than the DY-12c's 8" lip. Tirerack says the tire is recommended for 8-9.5" widths, so I figure I'm safe but numbers on a sheet don't necessarily take everything into account.
235 isn't meaty as in wide- I'm really looking for a solid sidewall, for the tire to look thick and juicy on the wheel regardless of the overall width of the wheel, you know? No stretch!
13 FRS doriftoooo!
DON'T PANIC
Old 08-25-2013, 05:20 PM   #150
bkblitzed
is better than you
bkblitzed's Avatar
It's probably cus they never used the tire before. Im a fan of bfgoodridge just because they make good cheap tires that last a long time. Used the comp 2's in the STi for a track day and they did great. I have the comp 2's on the frs now, and can't say much since i dont have an alignment but they're doing pretty good.
Old 08-26-2013, 11:35 AM   #151
p00mba
p00mba's Avatar
Drives: FR-S :)
Work Miester S1R
p00mba is offline   Reply With Quote
The Following User Says Thank You to p00mba For This Useful Post:
AVodka14 (08-26-2013)
Old 08-26-2013, 01:27 PM   #152
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
My Rota 17x9, 43 w/ Conti DW 245/40, matte black on black BRZ (dirty from weekend dirt road trip). Steering is just slightly heavier while rolling slowly, but that may also be brand new tires on concrete, although it is wet out for me. No odd handling noticable, lots more grip - particularly in the wet. Wheel alone weighs 19.5#, so negligable weight difference. Conti tires are supposed to be relatively light compared to other performance tires in the same size. Acceleration "seat of pants" feel is unnoticable to me.
From above front driver's wheelarch - wheel slightly turned unfortunately.
boarder1995 is offline   Reply With Quote
The Following 2 Users Say Thank You to boarder1995 For This Useful Post:
Flow (08-26-2013), HATED1 (08-26-2013)
Old 08-26-2013, 07:45 PM   #153
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
this thread needs.......MOAR MEAT!
took my frs through the woods over the weekend.
WHITE is offline   Reply With Quote
The Following User Says Thank You to WHITE For This Useful Post:
boarder1995 (08-26-2013)
Old 08-28-2013, 06:05 PM   #154
Jive Turkey
the tuna, no crust.
moar meet you say? here is the latest from @DarkCard and me.
For the rest of the pictures and high resolution's jump on their flickr and facebook page
DarkCard Flickr
Facebook
The Following 18 Users Say Thank You to Jive Turkey For This Useful Post:
1086 (05-08-2014), armythug (09-15-2013), chimera118 (08-29-2013), DarkSunrise (09-05-2013), FreedE (08-29-2013), fx35s (12-14-2014), GaN-MaN (10-22-2013), gkubed (08-06-2016), JEFFSTYLE (01-05-2014), mfbmike (09-05-2013), Nothing (09-11-2013), NWFRS (10-24-2014), ShutterSpeed (12-12-2013), Silver Ignition (05-03-2014), smbstyle (09-02-2013), SnapOv3st3r (11-18-2014), suaveflooder (02-20-2014), WHITE (09-03-2013)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
