Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
12-15-2017, 09:41 PM | #141 |
Drives: 2300LB FRS
Anyone running the StopTech 355x32 Front with an 18x9.5 wheel?
01-18-2018, 09:58 PM | #142 |
Drives: 2015 BRZ Sport Tech
Does the CSG Brembo GT kit have any confirmed fitment for 17" wheels? Specifically wondering about TC105Ns.
01-30-2018, 03:33 PM | #143 |
Drives: 2013 WRB BRZ 6MT
02-01-2018, 12:49 PM | #144 |
Drives: 2013 Satin White Pearl BRZ
AP sprint
Enki rpf1 +45 need a 10mm spacer but fit fine. Sent from my Pixel using Tapatalk |
02-18-2018, 02:31 PM | #145 |
Drives: Crapcan
Stop Tech 328 BBK with ST40 Calipers
Clears Rays 57DR 17X9 +38 by a huge margin. Like almost 3/4 of an inch. Clears stock wheels with 10mm Spacer by about 3/16 at the closest point. Also, using the 50mm Nismo studs allows you to use stock lugs on the stock wheels with spacer. Without spacer with the 57DR's my PMU Super 7's will tighten all the way down and hold the hat in place. |
02-28-2018, 08:03 AM | #146 |
Drives: Toyota GT86
Hi all,
There is any template about the Brembo STI WRX 2008+ with 326 30 discs? I would like to know if clears these alloys: Enkei RPF1 17x8 +45 Rays 57DR 18x8.5 +38 |
02-28-2018, 10:16 AM | #147 |
Drives: 2014 GT86
There are very few that retrofit non native designed brakes on twins. I'd guess you might be more successful in wrx/sti related forums regarding clearance of specific wheels.
03-16-2018, 07:30 PM | #148 |
Drives: Hot lava frs
Does anyone know if the wilwood 6 piston bbk will fit 17x8 +45 rpf1"s?
04-04-2018, 06:48 PM | #149 |
Drives: 2017 Subaru BRZ Limited
does 17X9 +35 fit Brembo GT 326 BBK?
08-01-2018, 03:32 PM | #150 |
Drives: 2017 BRZ PP
Looking at picking up some RS05RR's in 18x9.5 +43.
Anyone know if that would clear the performance package Brembo's? |
09-19-2018, 04:39 AM | #151 | |
Drives: 2016 GT86 N/A
RPF1 17x7.5 +48mm
Does anyone know if RPF1 17x7.5 +48mm fit StopTech 4pot (328x28mm) front kit ?
01-06-2019, 09:17 PM | #152 |
Drives: 2014 frs (someday)
01-14-2019, 01:53 AM | #153 |
Drives: 2019 Toyota 86
Outside of the RFP1 what Enkei rims can fit a BBK as a 17 inch diameter and 8 to 9 inch width?
01-22-2019, 05:36 PM | #154 |
Drives: 2018 BRZ PP
In my search for wheels for my 2018 BRZ with Performance Package, I ended up measuring my car and creating a clearance template. My initial measurements weren't super accurate; I used a combination square and dial calipers in some crazy orientations in a 20 degee parking garage. However, I printed the template out a few times to double-check on the car and made modifications as needed. I would say it's accurate to about a millimeter. I figured I would post the thing if it might help anyone out, just remember it was created by some idiot on the internet. As with any clearance template, print full scale and verify a few of the dimensions before cutting out. Make sure there's at least 3mm clearance between the template and the wheel.
Now the tricky part is checking wheels that I don't have yet. Any chance someone has TSW Nurburgrings in 17x8 +35 or +45 that they would be willing to check? |
The Following User Says Thank You to Dumpster Dan For This Useful Post: | churchx (01-22-2019) |
Tags |
big brake kit, brembo, essex, stoptech, template |
Similar Threads | ||||
Dyno Database | E92M3Guy | Engine, Exhaust, Transmission | 33 | 04-17-2013 10:20 AM |
The *Official* BRZ Pre-Ordered Database Thread | Zaku | BRZ First-Gen (2012+) -- General Topics | 727 | 03-17-2013 07:29 AM |
We should start a dealer BRZ order database | eikond | BRZ First-Gen (2012+) -- General Topics | 13 | 03-01-2012 12:56 PM |
