09-01-2013, 01:26 AM | #141 |
Drives: WRB BRZ Sport Tech
That's what I thought ant mentioned to my dealer, however it's only a faint smell when first start the car up or turn the car on, so the fan hvac fan is blowing. But like I posted, I'm looking for instructions to get to the heater core to inspect for myself. My dealer has also refused the TSB for the window switches so....to get them to look into something is a huge hassle.
09-01-2013, 10:40 AM | #142 | |
Drives: Subaru BRZ Sport Tech Satin White
09-01-2013, 12:02 PM | #143 | |
Drives: BRZ Limited
I'm at 4100 miles and my level when cool also read at the low mark. Adding 1 cup of diltilled water brought it up to the full mark when the engine is up to operating temperature. I would consider this normal and you shouldn't worry especially considering your environment. |
09-01-2013, 01:19 PM | #144 |
Pressure test it. Most pressure testers have a pressure gauge mounted to the pump handle. Pump up system to operating pressure and watch gauge for 15-30 minutes. It should not drop. If it does, you have a leak somewhere. Your dealer should be able to do this and if they won't, contact Subaru.
The Following User Says Thank You to White64Goat For This Useful Post: | civicdrivr (09-01-2013) |
09-01-2013, 05:45 PM | #145 | |
09-01-2013, 05:50 PM | #146 | |
09-01-2013, 08:00 PM | #147 |
If there is a PSI listed on the cap, that's your limit. Usually around 15 lbs.
09-01-2013, 09:12 PM | #148 |
Drives: Scion FR-S
Don't have anything useful to add to this thread unfortunately, other than mine is slowly losing coolant as well. First noticed it at 8000 miles, and has been increasing in quantity missing since. I'm perplexed on the "evap is normal" concept. On all my previous cars I've never had to top them off, so anything that evaporated was negligible. Only time I've had to every oil change was a heater core leak or a head gasket. Not trying to be rude, just curious if someone could give me a layman's explanation. I understand it's a vented tank, I've just never had experience with this quantity of evaporation taking place.
09-01-2013, 09:20 PM | #149 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
@civicdrivr I may have missed it (I just found this thread), but did the repair affect your original issue in this thread?
On a side note, Toyota seems to want to disown the frs based on their desire to take care of their customers. At least at the dealership level. Also, it sounds to me like they never had a FE involved if he was never available. Sent from my SCH-I535 using Tapatalk 4
09-01-2013, 10:04 PM | #150 | |
Drives: BRZ Limited
The Following 2 Users Say Thank You to fstlane For This Useful Post: | 448hpsti (09-02-2013), Nightbringer (09-01-2013) |
09-02-2013, 07:40 AM | #151 |
Drives: Ultramarine FR-S (MT)
Interesting thread. I noticed a few weeks ago that my coolant reservoir was totally empty in a span of 4k miles! (I had it topped off at my last oil change) I didn't check the radiator cap but I will do so next time. It has been very hot in the past few months so I'm hoping that was it.
Sent from my Galaxy Nexus
09-02-2013, 10:34 AM | #152 | |
Actually, the only manufacturing defect on my 1998 Mazda Protege was a defective radiator cap, come to think of it. The only warranty claim I made. The dealer kept replacing the block heater because that's where the coolant blew out when the rad cap failed to relieve expansion into that bottle. The reverse effect: a rad cap with insufficient spring pressure could cause a loss of coolant. European systems pressurize to around 21 psi and are designed not to breathe up to that pressure. They have enough head room to allow only some air out at higher than designed pressures, breathing air back in when the system cools. The expansion bottle systems have to "breathe" coolant out and back in. |
The Following 2 Users Say Thank You to Suberman For This Useful Post: | civicdrivr (09-02-2013), fstlane (09-02-2013) |
09-02-2013, 11:44 AM | #153 | |
Drives: 2018 Golf R
I picked up the Robispec rad/oil cooler two months ago. I'm still waiting for the sandwich plate and lines, but I'm hoping once I install it the coolant loss would slow or (preferably) stop altogether.
Parting out HERE
09-02-2013, 02:15 PM | #154 | |
Similar Threads | ||||
FRS uses a lot of coolant? | JLMtm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 124 | 01-23-2015 06:34 AM |
Coolant Question | boredom.is.me | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-15-2013 07:50 PM |
Engine Coolant? | L3P47 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 04-13-2013 11:33 PM |
Alright to use 5-6 old coolant? | Hanakuso | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-11-2013 08:47 PM |
Low Coolant | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 12 | 11-25-2012 12:03 PM |
