Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 02-14-2017, 12:11 PM   #15149
eromsdal
ERO
eromsdal's Avatar
Drives: '16 Subaru BRZ Series Hyperblue T
Confirmation
Originally Posted by treminaor View Post
Nope. There's currently no adapter on the market to make it work with the '16 harness. The AX-TOYUSB-1/2 will NOT work with a 2016 starlink Subaru.
I used the existing one for people with the square dashboard holes, so there's some gaps. It looks acceptable for the time being until someone releases ones made for the new dash style.
You don't need the dash kit to mount your radio to the car, so don't waste your money on it unless you don't mind the look.
Existing radio guides for the 2013-2015 BRZ will tell you to wire the blue power antenna wire on the Toyota Metra 70-1761 to your blue/white remote power (System Remote Blue/White on Pioneer decks) to turn on the door speaker amps. This is incorrect for 2016 models. You need to wire your blue/white remote power wire to the 9th pin (Brown wire) of the 28 pin data harness, which is the 3rd wire harness coming out of the car. This harness is for the backup camera, the integrated mic, the door amp power, and more.
For the reverse camera to work you need a voltage regulator to step down the 12v power from the car harness to 6v, the required voltage for the OEM rear view camera. I suggest buying this: Amazon.com: DROKĀ® Waterproof High Efficiency Car Power Converter DC12V to 6V/3A Step Down Voltage Module 9-22V to 6V Power Supply: Electronics
Splice into your 12V accessory power wire to the red 12v INPUT wire of the regulator and wire the black ground wire to the black INPUT ground wire on the regulator. Wire the yellow 6v OUTPUT wire of the regulator to pin 11 of the 28 pin harness (this will power on the OEM camera). Wire the black OUTPUT ground wire to pin 22 of the harness (camera ground).
I removed the prewired RCA plug with pins on it from the useless AX-TOYCAM2 harness I had laying around... if you don't have that harness just cut up any old RCA cable and separate the copper ground from the signal wire inside of it. The signal wire is your + (pin 12) and the ground is your - (pin 13) - plug them into their respective holes on the 28 pin harness. I then plugged the other end of the RCA cable into the rear camera input of my Pioneer AVH-x8500BHS. Remember to go into your settings and change the Camera from "Off" to "Battery" (not "Ground"), and set the camera to NTSC under "Video Signal Options"
So to confirm, as I have a 16 brz as well... the back up camera can work with rewire and you can use a 2013-2015,2017 dash pieces would work to fill in the gap?
eromsdal is offline   Reply With Quote
Old 02-14-2017, 12:12 PM   #15150
eromsdal
ERO
eromsdal's Avatar
Not sure why it places the reply in this thread, I'm not used to using forums
Old 02-14-2017, 04:21 PM   #15151
Prmspen
Student Driver
Prmspen's Avatar
Drives: 2016 Subaru BRZ Limited
Installed Perrin front end links. That's the last piece of my autocross setup for this year done. Also included Perrin 19mm adjustable front sway bar, OE camber bolts, and RE-71Rs. Having run bone stock last season, I'm looking forward to the first event.
Prmspen is offline   Reply With Quote
Old 02-14-2017, 04:25 PM   #15152
trigun286
trigun286's Avatar
Drives: '16 WRB Limited
Switched maps on my OFT for e85. Got the butt dyno seal of approval. 😁
Sent from my Nexus 6P using Tapatalk
trigun286 is offline   Reply With Quote
Old 02-14-2017, 08:22 PM   #15153
15limited
15limited's Avatar
Put da hood on, fitment will need some fine tuning.
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 02-15-2017, 01:32 AM   #15154
Trueweltall
Trueweltall's Avatar
Installed front and rear A119C dash cameras, install took a lot longer than I thought it would because I wasn't smart enough to get a coat hanger to fish wire through the headliner when I started. Spent ~$250 overall, worth it for the peace of mind if someone hits me.
Trueweltall is offline   Reply With Quote
Old 02-15-2017, 11:36 AM   #15155
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
I installed a front mount A119c w/GPS and the optional polarized lens. Been using it now for 3 weeks @ 1440p, I really like it. Have full confidence it will save me headaches if someone ever hits me
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Old 02-15-2017, 02:59 PM   #15156
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
some q & a
Some l o l s
Some brap brap brap
100% weeeeee
[ame="https://www.youtube.com/watch?v=GvmOy5WbVhk"]Q & A + Wife's Impression + Pub Dog meet. - YouTube[/ame]
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 02-17-2017, 09:28 PM   #15157
2017-BRZ
Drives: 2017Crystal White Pearl BRZ Limited
Today I let the BRZ lead in our daily dance..and I think I will allow that to happen more often..
2017-BRZ is offline   Reply With Quote
Old 02-18-2017, 01:31 AM   #15158
mm10
Drives: '17 BRZ
Got these beautiful things recently.
Currently sitting on STI springs.
Volk CE28n 17 x 7.5 +50
I'm in love
mm10 is offline   Reply With Quote
The Following 3 Users Say Thank You to mm10 For This Useful Post:
2017-BRZ (02-18-2017), derekbrz24 (02-18-2017), eblamble3 (02-18-2017)
Old 02-18-2017, 09:06 PM   #15159
2017-BRZ
I like the way it looks good job..sick in black....
Old 02-19-2017, 02:48 AM   #15160
mm10
Drives: '17 BRZ
I can already see myself spraying them bronze one day down the track, but for now the black is nice!
Old 02-19-2017, 02:57 PM   #15161
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
3rd autocross in my '17 BRZ. Fresh tires and the thing is flying, can't wait to get the engine mods installed.
[ame]https://twitter.com/Colo_SCCA/status/833088911756894208[/ame]
justinco is offline   Reply With Quote
The Following 6 Users Say Thank You to justinco For This Useful Post:
derekbrz24 (02-19-2017), DocWalt (02-19-2017), Lonewolf (02-19-2017), nisti (02-20-2017), OrangeGuitar (02-19-2017), Wondark (02-20-2017)
Old 02-19-2017, 06:53 PM   #15162
2017-BRZ
cleaned up the vomit gift in the back seats by my 2 year old....
Got my VIN today... Enemies BRZ First-Gen (2012+) -- General Topics 63 04-12-2012 10:19 PM
sat in a BRZ today NESW20 BRZ First-Gen (2012+) -- General Topics 8 03-31-2012 08:53 AM
