08-02-2016, 10:41 AM | #14925 | |
#FiftyShadesOfBlue
Drives: 2015 FR-S
Ideally I want to have the new wheels/tires on with no spacers and then in the winter go back to stock wheels with spacers for "flushness" with both sets of wheels without having to change the studs.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes |
08-02-2016, 11:14 AM | #14926 |
Wayward Member
Drives: Hot Lava 86
Word of advice as well, if they are not hub centric and have a much wider bore, you will need skinny lug nuts. I found out the hard way that if you increase the bore, but keep the bolt pattern, the space has to be lost somewhere, and that space is lost in the bolt holes.
The Following User Says Thank You to Nevermore For This Useful Post: | Tectoniic (08-02-2016) |
08-02-2016, 11:19 AM | #14927 | |
The Following User Says Thank You to Ashikabi For This Useful Post: | Tectoniic (08-02-2016) |
08-02-2016, 11:34 AM | #14928 | |
#FiftyShadesOfBlue
Drives: 2015 FR-S
I'll look into open ended with caps but for now I'm holding out. This is why I held off on wheels because there are just so many things you have to make sure you have correct between bolt pattern, offset, stud length, clearance w/ fenders, tire+wheel diameter vs OEM, brake clearance etc..... I'm sure there will still be something I forgot when I go to install them...
08-02-2016, 11:48 AM | #14929 | |
Wayward Member
Drives: Hot Lava 86
Have you tested them to see that they fit? I had tuner style lug nuts that didn't fit my forgestars.
08-02-2016, 12:02 PM | #14930 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
Not yet, but I'm testing them tomorrow before I order the tires. I did think that far ahead
The Following User Says Thank You to Tectoniic For This Useful Post: | Nevermore (08-02-2016) |
08-02-2016, 01:13 PM | #14931 |
Wayward Member
Drives: Hot Lava 86
Yeah, I did not know my lug nuts didn't fit until the tires were mounted, I had gone out and bought a new jack and torque wrench, the car was jacked up with the stock wheel off and the new wheel on. I was pissed.
08-02-2016, 01:17 PM | #14932 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Well I am back from my trip, so here is a TL;DW (Too long; didn't write)
It was awesome I drove through Alberta and BC in Canada, Washington, Idaho, and Montana in the USA. Car is great on gas. My girlfriend is a princess lol. Northern Montana has some of the best twist roads with high speed limits. The I-90 in Washington (I think that's what it was) is the worst road I have ever driven on, it may have been a gravel road it would have been smoother. |
08-02-2016, 01:20 PM | #14933 |
i quit smoking today cold turkey
08-02-2016, 01:31 PM | #14934 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Almost had a heart attack when Doug Demuro posted he was leaving Jalopnik. Though Im worried too much of a good thing on Oversteer will kill his brand.
He's kinda like a calmed down version of @MisterSheep and @go_a_way1 |
The Following 2 Users Say Thank You to finch1750 For This Useful Post: | go_a_way1 (08-02-2016), MisterSheep (08-02-2016) |
08-02-2016, 02:19 PM | #14935 | |
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | finch1750 (08-02-2016), MisterSheep (08-02-2016) |
08-02-2016, 04:00 PM | #14936 |
sometimes i switch to the BRZ forums on here just so I can change the color of the twin in the banner to blue because it matches the background
08-02-2016, 04:07 PM | #14937 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
And because they get a nice quarter panel view whereas us FRS plebs get a side shot with tires that have a 3mm sidewall
08-02-2016, 04:28 PM | #14938 | |
Similar Threads | ||||
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
