06-07-2014, 01:31 AM | #1415 |
Drives: 2013 BRZ Premium Dark Gray Metallic
Wow that looks very risky...
06-07-2014, 01:49 AM | #1416 |
Installed kit last weekend. Tuned today. Wow. Some issues... But great power.
Sent from my SGH-M919 using Tapatalk
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
The Following User Says Thank You to SPCorBUST For This Useful Post: | DeliciousTuning (06-07-2014) |
06-07-2014, 02:19 AM | #1417 |
06-07-2014, 02:21 AM | #1418 | |
Drives: 2022 BRZ Limited
Wow, and the performance shop who did the install never mentioned this? those nubs should go in between the OEM crank pulley and they should sit flush AFAIK .. Did you check the tq on the crank pulley with a torque wrench? it should be 94 ft/lbs according to the service manual
06-07-2014, 02:45 AM | #1419 |
I have searched for all the aftermarket crank pulley options and it looks like Beatrush is the only one that retains the OEM shape..too bad it costs more than $300 that's crazy expensive for a single pulley IMO
http://ft86speedfactory.com/beatrush...ulley-810.html
06-07-2014, 02:54 AM | #1420 | |
In race engines we build we usually see horsepower gains and smooth engine performance when we use heavy harmonic dampers such as the ATI super dampers the ultra lightweight aluminum crank pulleys compromise the reliability of the engine....they are widely made and sold because they take no engineering or tooling to make, can be made cheap, and people buy them...unfortunately The larger accessory pulleys are fine , just not the crank pulley |
06-07-2014, 03:08 AM | #1421 | |
the only alternatives seem like lighter crank pulley and/or lighter flywheel at the moment..I also ordered some Cusco Accelerator pedal but it will maybe a help a bit but I don't expect by much.. AFAIK, FA20 engine doesn't use harmonic balancers is that what you mean in your first paragraph?
06-07-2014, 03:23 AM | #1422 | |
here is a link to the ATI product: http://www.atiracing.com/products/da...dam-subaru.htm Here is a link to BHJ and also technical whitepapers about the importance of Harmonic Dampers: http://www.bhjdynamics.com/index.php...vrsueignutk6u3 as for locking up and spinning out...dont dump the clutch. aside from that if you are trying to make the engine 'blip' faster, the crank pulley is the wrong place to look for that response. as was said before, start in the areas with the highest MOI (moment of inertia)..the crank pulley does not have enough mass or diameter to significantly impact the rate the engine spins up or spins down.....start at the flywheel and clutch package. an ideal set-up for you would be an ultralight flywheel combined with a 7" twin-disc carbon clutch (which you can feather and ride/slip all you want if you need to)...if the clutch isnt in the budget, even the flywheel alone will make a significant difference. |
The Following User Says Thank You to gmsii For This Useful Post: | zoth (06-07-2014) |
06-07-2014, 03:49 AM | #1423 | |
as for locking up, I never really dump the clutch but I perform late brake and try to carry as much as corner speed as I can, so my driving style requires me to operate very quick downshift/rev matching .. this may never be an issue for someone who uses his/hers car at street/auto-x but it's quite important for track use imo
06-07-2014, 04:04 AM | #1424 |
Drives: Subaru BRZ-SWP
I did I quick run on the 1/4 did mid 13 s on high altitude here in el paso TX with 100 degree weather. On street tires, I think 12s is doable on slicks and better temperatures. Yes I also enjoy drag racing.
Sent from my SGH-M919 using Tapatalk |
The Following User Says Thank You to Taino-BRZ For This Useful Post: | DeliciousTuning (06-07-2014) |
06-07-2014, 04:07 AM | #1425 | |
there is nothing more sensitive to rear wheel lock up than a motorcycle during aggressive downshifting and braking....before slipper clutches became standard in racing motorcycles, in addition to matching engine speed, the rider needed to have good enough clutch control to slip the clutch to drag the engine rpm up to higher transmission speeds when necessary |
06-07-2014, 10:22 AM | #1426 |
Drives: FRS with 2jz, 2015 STI 9.68@147
We checked clearances and torqued the bolt to spec. Obviously the nubs do not line up due to the convex on the aftermarket crank pulley but the heights of the stock pulley to aftermarket pulley where the bolts sit is the same. The car has been dyno'ed and driven and torque was checked again to verify and all was well. I had mentioned to the customer the aftermarket pulley actually worked with the kw kit before customer had picked up the car.
The Following User Says Thank You to PrimeMotoring For This Useful Post: | glamcem (06-07-2014) |
06-07-2014, 01:44 PM | #1427 | |
06-07-2014, 02:21 PM | #1428 | |
Interesting, after hearing the issues I highly doubt I would consider getting one, I think it's just not worth the effort/hassle considering that we have SC kit installed now.. I will probably get a lighter flywheel and call it a day the problem with these type of aftermarket parts (the ones that are made of weight savings) is the negligence of the importance of the OEM design .. the engineers of these cars have their own reasons for a particular design..oh well
Similar Threads | ||||
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
