05-13-2016, 04:39 PM | #1415 | |
Drives: 2013 "Hot Lava"
It should only take a few minutes if you're lucky with the roll pin on your stock RLO. I wasn't so lucky. I started out with trying to use the long end of a 2.5mm (I think that's right) allen key. It wasn't having any of it. Even giving the end of it a good tapping didn't budge the roll pin. Other folks have had their's plop right out without a lot of force but these were not the tools for one being sticky. So I went to Home Depot and got a rubber hammer and a modular punch with an assortment of sizes (seen on the floorboard of my picture). All of the punches they had were essentially progressive, so the rated size is essentially for the tip but it gets fatter along the shaft of the punch. I don't know, perhaps that's normal, but this made for a lot of effort. I destroyed that stock RLO hammering that punch through. Split it, and had a piece nearly smack me in the face when it broke off. Hammering on that punch felt so wrong but it worked, and I've seen more than one video where this was necessary. But the shifter itself wasn't damaged at all and the new pin for the new RLO went in like butter. Then it's just a matter of a few tries with the locking adapter and the new shift knob to get it perfectly aligned. So, if you've already got the tools you're looking at a few minutes at the fastest, maybe fifteen if it's being a little stubborn. Main thing that will add time is getting over the feeling you're going to break something (at least for me that was the case). I will echo one thing I read online though, it's better to pop the ring around your shift boot and lift it off the top, rather than pull it down and away from the RLO. Everything'll go back together quicker and smoother and it gets it out of the way while you work.
2013 Hot Lava FRS :: OFT Stage 2+ :: JDL UEL Catless :: JDL Over-Frontpipe :: GReddy Evolution RS Catback :: Enkei "Tarmac Black" RPF1 :: Tein Flex-Z Coilovers :: 245/35r18 Conti DW :: RS*R R-LCA :: Racer-X Fab R-Toe Arms :: Mishimoto Intake Tube :: Mishimoto Oil Catch Can :: JDL FSTB :: Raceseng "Slammer" + RLO :: Diode Dynamics HID + Tail-as-Turn + DRL :: 5:AD Spoiler ::
05-13-2016, 04:47 PM | #1416 |
Drives: BRZ + Ducati M796
Even if the punch is right it can be tough to get it in and out. Getting it in can be much easier by freezing the pin and heating the RLO, so the metals contract and widen, respectively. Still terrible.
05-13-2016, 10:37 PM | #1417 |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
It's coming
Instagram: 86_Maul |
The Following User Says Thank You to ShadowReaper For This Useful Post: | stevemp5 (05-14-2016) |
05-14-2016, 04:45 AM | #1418 |
Drives: 2014 GT86
Add crest to that above and one will have Holy Hand Grenade of Antioch shift knob
The Following User Says Thank You to churchx For This Useful Post: | BurnetRhoades (05-18-2016) |
05-14-2016, 08:09 AM | #1419 |
Drives: Subaru BRZ
05-16-2016, 09:15 AM | #1420 |
Hail Magnet
I think its either 2, 3, or 4. I know 5 is right out. I think there is a book somewhere with the instructions.
05-16-2016, 10:03 AM | #1421 | |
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | HunterGreene (05-16-2016), Sarlacc (05-17-2016) |
05-16-2016, 03:41 PM | #1422 |
Drives: Subaru BRZ
05-16-2016, 08:23 PM | #1423 |
Drives: 2016 Brz wrb limited
Anybody know how to cover up the rest of the screw? |
05-17-2016, 08:36 AM | #1424 |
Drives: 13' Scion FRS
05-17-2016, 09:38 AM | #1425 |
Driver
Drives: Black 2013 BRZ
Totally agreed - started with a punch and all that did was mangle the pin. Took me a six-pack of drill bits (and a few hours) to get that effer out.
05-18-2016, 11:52 AM | #1426 | |
Indulgent Tormenter
I just googled "star wars sticks shift knobs" that one came up.. it's by Etsy
05-18-2016, 03:24 PM | #1427 |
05-18-2016, 07:40 PM | #1428 |
Drives: 2014 Whiteout FRS
http://bloxracing.com/shop/index.php...ath=65_120_161
I have the same shift knob. I used a lockout level adapter. Did the trick.
Tags |
knobs |
Similar Threads | ||||
Shift Knob | Jwong | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 29 | 12-12-2014 01:33 AM |
Kartboy Shift knob | Spartan65 | Interior Parts (Incl. Lighting) | 8 | 10-03-2012 06:18 PM |
any other shift knob? | oso_25 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-31-2012 01:38 AM |
TRd Shift Knob | GaN-MaN | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-24-2012 01:57 PM |
