12-09-2014, 12:42 PM | #1387 | |
Drives: '22 BRZ
I'll just wait patiently for more track reports |
12-11-2014, 10:06 PM | #1388 | |
Drives: '13 Black Subaru BRZ Limited
12-15-2014, 12:21 PM | #1389 |
Drives: GTI, BRZ
It's a little tough to tell, but does the TRD spoiler cover the holes from the BRZ's stock spoiler, or are they still visible?
12-15-2014, 12:37 PM | #1390 |
Driving Coach
The Following User Says Thank You to ATL BRZ For This Useful Post: | chanomatik (12-16-2014) |
12-15-2014, 09:27 PM | #1391 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
I wish I could convey the difference you see with the various dynos when you travel around. Only good comparison is on the same dyno, under similar conditions. Eddy current type dynos essentially have a "dial" to calibrate whichever way you'd like (high or real) while dynojets can be problematic and easy to fool with a hairdryer pointed at the weather station...
12-15-2014, 10:02 PM | #1392 | |
Drives: '22 BRZ
Say hi to Hans for me |
The Following User Says Thank You to DocWalt For This Useful Post: | ATL BRZ (12-16-2014) |
12-30-2014, 08:52 PM | #1393 |
Driving Coach
Getting busy.
To Do: Mishimoto Radiator, Hoses, and thermostat install Velox race splitter install JDM Underbody panels install Install new driver's side ingnition coils Change all fluids to fresh Millers Nanodrive Low temp thermostat installed. Stock is 88C, Mishi is 76 C Radiator installed. Made more progress after this and finished up the radiator install but didn't take any more pics. Taking my sweet time and finishing up later this week. More updates and pics soon. |
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post: | Carlos_M (12-31-2014), chanomatik (01-06-2015) |
01-01-2015, 12:16 PM | #1394 |
Drives: 2018 Subaru BRZ
Great build
On my fourth 86... and everything in between
The Following User Says Thank You to Scracho For This Useful Post: | ATL BRZ (01-01-2015) |
01-01-2015, 02:40 PM | #1395 |
Driving Coach
Edit: decided against the oil pan baffle.
01-01-2015, 04:56 PM | #1396 | |
Permatex Right-Stuff (Hondabond) has always worked well back in my days at Honda.
01-02-2015, 08:29 PM | #1397 |
Driving Coach
Made more progress today.
Installed the JDM underpanels after changing my transmission and differential fluid with fresh Millers CRX 75w90 NT gear oil When pulling my original drivers side coils I found the source of my slow oil leak. It is not leaking from the cam carrier seal as I originally thought. It's coming from what looks to be the hole for the coil bolt and/or the coil/plug tunnel. I'm not sure if my eyes are deceiving me since it's difficult to see in there at all without an inspection mirror but the tunnel felt dry and the only oil I could find that was collecting at the bottom of the coil looked like it was originating at the threaded hole for the 10mm bolt securing the coil to the block. Very bizarre. Plug tunnel appears to be dry, but I could be wrong since it's difficult to see. Anyways I installed two new 652 coils on the driver's side (from below) and will keep these two original coils as spares since they still work fine and don't throw codes (yet). I was going to install the race splitter but I discovered that I'm missing some hardware. @FT-86 SpeedFactory are taking good care of me and already sent it to me in the mail today. Thanks again Yo. I also decided not to keep the Moroso oil pan baffle. I'm not sure it would be worth installing since the pan is adhered to the block and won't come off without prying it and inevitably bending it and have to flatten it back. I chatted with @Reaper about this and after agreeing that the factory baffle is sufficient and I don't see much benefit to the extra baffling since the oil level is already above the top of the pan in the FA20. I also haven't heard of anyone having issues with the pan itself not holding oil in it. We agreed that I should instead be considering an oil accumulator (Accusump) to keep pressure and lubrication under high lateral loads before bothering with a baffle for the pan. Right now with 245 street tires I don't think it's an issue that needs to be immediately addressed. Should I go wider and stickier then maybe I will look into it more seriously. Might go ahead and change the oil this weekend and do the drilling and bracketry installation for the splitter so I can get everything back together and ready for the rest of the hardware to get here. Last edited by ATL BRZ; 01-02-2015 at 08:43 PM. |
The Following User Says Thank You to ATL BRZ For This Useful Post: | chanomatik (01-06-2015) |
01-02-2015, 09:07 PM | #1398 |
Drives: '22 BRZ
Looks like that bolt hole for the coil got drilled through by accident or something... Weird.
01-02-2015, 09:14 PM | #1399 |
in orbe terrum non visi
Drives: violent
You on R comps with forced induction will be an issue with fueling from the stock tank on e85. I have a plan when you do it.
The Following User Says Thank You to Reaper For This Useful Post: | ATL BRZ (01-02-2015) |
01-03-2015, 10:10 AM | #1400 |
Driving Coach
Tags |
jdl turbo, mazworx, racecomp engineering, track build, verus engineering |
Similar Threads | ||||
Wnt3d's 86 - Turbo E85 Daily/Track Build | wnt3d | Member's Car Journals | 77 | 07-17-2017 03:35 PM |
No Limit Motorsport Full Blown BRZ Build | No Limit Motorsport | Member's Car Journals | 16 | 07-08-2014 12:46 PM |
