04-01-2017, 04:15 PM | #127 |
Drives: Scion FR-s, xB, iA, Silverado Z71 4
I just looked under the hood.
I'm a bass player with quite large hands. I think I'm gonna jack up the engine. I'm almost at 120k miles so it's probably time. BTW, I paid around $100 for the plugs from Amazon. |
04-01-2017, 04:31 PM | #128 | |
What does the engine hanger look like? What's a joint pipe? What is engine under-cover 1? What do the oxygen sensor connectors look like and where are they? Etc. This is ridiculous. Because of my large hands, I'm assuming I'm going to need to jack the engine. Sadly, I can't find anything on the internet telling you how to do that. |
04-01-2017, 11:55 PM | #129 | |
Drives: red 2014 FR-S
https://demos.starbase7.net/t3Portal..._rm_index.html |
04-02-2017, 11:23 AM | #130 |
Drives: 2013 Raven FRS
I have lifted the engine before. It wasn't so bad. But that was back when I had stock exhaust and drive shaft.
Now that I have a 2.5" overpipe and one piece aluminum drive shaft I do not know how this will be as the clearance of these parts comes close to hitting the frame. I also have no idea how this may stress the drive shaft. Last time I did not disconnect my exhaust. You can only jack it up so high before something starts getting caught on the frame as the whole transmission is connected not to mention your engine wires. Remember to remove all battery connections,all strut bars, and don't forget to remove the connection to the alternator as that hard line will snap if lifting while connected. Also loosen or remove any intake connections that are bolted down. Just be observant from top to bottom. Lift small inches at time then inspect if anything might be caught, listen for noises of stress on parts and look around. Also make sure you use a levelled flat block of wood to support the whole base of oil pan when lifting or you will risk denting it. I also am not sure how far up you can jack the engine before it max out. It may or may not give you clearance from the side walls of the frame to easily remove the spark plugs. But at least you don't have to be reaching down below. Last edited by FrostedFlakes; 04-02-2017 at 11:42 AM. |
The Following User Says Thank You to FrostedFlakes For This Useful Post: | Teseo (04-02-2017) |
04-03-2017, 10:15 PM | #131 | |
Drives: WRB Subaru BRZ Limited 6MT
04-05-2017, 10:36 AM | #132 |
Drives: '97 NSX-T, '18 Type R
My mechanic says it can be done without lifting the motor if you have the right extensions.
05-05-2017, 03:53 PM | #133 |
Drives: frs
05-08-2017, 02:34 PM | #134 |
Drives: 13 Subaru BRZ, 02 Audi TTQ
Check the first post of this thread.
05-29-2017, 12:41 AM | #135 |
Drives: 2014 BRZ Limited
I did it tonight. Not that bad at all. Here is my video.
[ame="https://www.youtube.com/watch?v=o4DTojPr6-0&t=3s"]BRZ Spark Plug Change - YouTube[/ame] |
The Following 12 Users Say Thank You to sunrisecirrus For This Useful Post: |
05-29-2017, 03:55 AM | #136 | |
Drives: 2014 Whiteout FRS
Takes patience but its really easy. |
08-23-2017, 03:06 PM | #138 |
Just thought I'd mention that I'm at 128k on my original plugs. Everything's running fine. No missing, and still averaging 32 mpg with a manual.
04-10-2018, 01:06 PM | #139 |
Hello fellow Kentuckian. You actually have more miles than me-I'm at 118k, and I thought I was the high mileage winner.
05-10-2018, 03:01 PM | #140 | |
And I still have not changed the brakes. Brakes are for chickens. BTW, I got a puncture in one of my tires and took it to the Bardstown Costco a couple of days ago. They said it couldn't be fixed so I bought a new tire at the guarantee pro-rated price. They slapped the spare on until it arrived. So, it arrived and I told them I'd swap the tires my self. I get home and they were so tightly mounted that I snapped off a lug. I returned and asked them to do the rest. They said that if another lug snapped off they would have to have it towed out. After discussion they said I could have the lug(s) replaced and they would pay for it. So I took it to my Toyota dealer and had them remove the spare. Two more lugs snapped off. They replaced all three and the lug nuts for $78. |
Similar Threads | ||||
Spark plugs for turbo | whitefrs | Forced Induction | 88 | 05-05-2018 09:18 PM |
boosted spark plugs? | 350matt | Forced Induction | 9 | 08-09-2014 03:54 PM |
Spark plugs | Triumphrider | Engine, Exhaust, Transmission | 12 | 06-19-2014 10:47 AM |
spark plugs | subaruferrucci | Engine, Exhaust, Transmission | 22 | 04-10-2013 11:24 AM |
