01-26-2015, 11:15 AM | #127 | |||
Drives: 2013 Subaru BRZ
Thanks -John |
01-26-2015, 07:03 PM | #128 |
Drives: white-out FR-S
I'm getting a slight rattle noise around 2k rpm. I notice the can is close to the hose below it...
01-27-2015, 04:23 PM | #129 |
01-27-2015, 04:39 PM | #130 |
Drives: WRBrz
I'm also noticing this noise, sounds like a tin-ey vibration when engine is under load.
EBSC - dt.FF - MXP CompRS
01-27-2015, 04:39 PM | #131 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Mishimoto Build Thread: BRZ/FR-S Direct Fit Baffled Catch Can Kit!
Try opening the can and setting the metal colored piece towards the center.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
The Following User Says Thank You to Sojhinn For This Useful Post: | WRB5titch (01-27-2015) |
01-27-2015, 04:43 PM | #132 | |
Drives: WRBrz
01-27-2015, 08:02 PM | #133 |
So it is the circular metal piece that can twist?
01-27-2015, 08:08 PM | #134 |
Drives: Asphalt FR-S
I'm guessing the piece vibrates and if it's close to the can's edges, it touches and create a slight rattle.
01-27-2015, 08:09 PM | #135 |
Drives: 1966 Mustang, 2013 FR-S
Install difficulty for an automatic car should probably be bumped up to a 3/5. The automatic has a bunch of brackets and piping that make getting to the pcv valve all but impossible.
When mounted, the hoses rub up against the conduit for all the automatic electrics that run across the engine bay so obtusely. I have no complaints with the setup, as there is no better way to do this. It just sucks a bit for an automatic. Just like with installing the GrimmSpeed cylinder brace, there's extra junk in the way. The silicon hoses are probably the best material choice for abrasion resistance, so I'm extremely happy about that. Last edited by Rosticles; 01-27-2015 at 09:19 PM. |
01-28-2015, 10:52 AM | #136 | ||||
Thanks! Quote:
Thanks! |
01-30-2015, 05:44 AM | #137 | |
Drives: Toyota
And the can end of the inlet hose touches three things, the brake booster line (see Front.jpg), the wiring across the back of the intake manifold and the banjo joint on the clutch slave cylinder (see Inlet_Side.jpg) The PVC end of the inlet hose clears everything. But is a huge pain to connect as on RHD cars there is a bracket for the brake booster hose in the way (see PVC_End.jpg). It is going to be very difficult to do up the clip on there! The outlet hose from the can to the intake manifold clears everything, but only just (see Outlet_Side.jpg). It goes under the wiring with a millimetre or two to spare (see Front.jpg). As John mentioned Mishimoto are revising the bracket for RHD, so looking forward to that = ) I have asked Pat from Mishimoto customer services if they are revising the inlet tube also as it is rubbing on all that stuff, but have not heard back as yet Bracket.jpg Front.jpg Inlet_Side.jpg PVC_End.jpg Outlet_Side.jpg |
The Following User Says Thank You to eztygr For This Useful Post: | keen as (01-30-2015) |
01-30-2015, 11:00 AM | #138 | |
03-20-2015, 07:49 PM | #139 |
Drives:
I received my Beatrush Type 2 Front Tower Bars this past Thursday...awesome product but because of how the mounts are made the bracket for the oil catch can would not mate up.
I'm sure some of the other aftermarket front tower bars might present this problem as well... here is my solution: ___________________________________________ **1" stainless steel U-Bolt purchased at Ace Hardware.** **Line up, mark, and drill hole in catch can bracket.** **Installs as pictured.** **Used an anti-chafe tape to protect metal surface and to create some friction in order to eliminate any potential rotation.** projekt zeal86 build Last edited by zeal86; 03-23-2015 at 11:55 PM. |
The Following User Says Thank You to zeal86 For This Useful Post: | DAEMANO (04-14-2015) |
03-21-2015, 01:40 PM | #140 |
Drives:
Installed pics...
**Installed some stand-offs to prevent any potential rubbing... this is more of a preventative measure than a requirement...at least on LHD 6-speed 86s.** projekt zeal86 build Last edited by zeal86; 03-22-2015 at 01:03 AM. |
The Following 2 Users Say Thank You to zeal86 For This Useful Post: | DAEMANO (04-14-2015), TheBRZsKnees (04-25-2017) |
Similar Threads | ||||
Mishimoto Compact Baffled Oil Catch Can Build Thread! | Mishimoto | Engine, Exhaust, Transmission | 81 | 08-21-2019 08:05 PM |
Mishimoto Build Thread: BRZ/FR-S Silicone Induction Hose | Mishimoto | Engine, Exhaust, Transmission | 23 | 11-29-2018 11:35 AM |
Mishimoto Build Thread: BRZ/FR-S Performance Cold-Air Intake | Mishimoto | Engine, Exhaust, Transmission | 90 | 12-03-2016 06:22 PM |
FS:WA- ADD W1 REd Baffled Universal Aluminum Catch can | glamcem | Engine, Exhaust, Bolt-Ons | 0 | 07-05-2014 07:15 PM |
Win a Mishimoto Oil Catch Can! | Mishimoto | Announcements, Contests, Giveaways | 68 | 10-23-2013 05:27 PM |
