#127 | |
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
#128 |
Drives: UK GT86
I'm on 1.5.0
.: Stealth 86 :.
#129 |
Drives: UK GT86
@solidONE did you try just blanket flattening the IAT table? Using the latest update of the tool it would be quite easy to start generating an individual IAT Compensation Table using the log stats screen.
.: Stealth 86 :.
#130 | |
Drives: FR-S Whiteout
#131 |
Calle Atun
#132 |
Drives: UK GT86
It's always worked as far as I remember. Just select copy the whole map in ECUtek and paste it into the window and then click validate.
.: Stealth 86 :.
#133 | |
Calle Atun
#134 | |
Drives: UK GT86
You are, you're doing want I thought. Don't highlight the whole table and click copy as you're not copying the x and y axis definitions, which is what you need. Go to Edit > Copy Entire Map to Clipboard
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | Toyota John (06-10-2014) |
#135 | |
Calle Atun
Thanks @Kodename47 that was the problem. |
#136 |
Calle Atun
I think I got it. How does this look?
#137 | |
#138 |
Looks like you got it to work right. Now click the total correction and current box so you can see how far off the original scale is compared to that the app generated. Might want to zoom in to get a closer look at the maf scale below 2.8V.
#139 | |
Drives: UK GT86
Once you have scaled your MAF to as good as possible at the range where the multiplier is 0% (1 on ECUtek) then use the Log Stats screen. I would add an extra 2 columns to the log file itself: dV/dt and Error %. dV/dt formula: =IFERROR(ABS(((V2-V1)/(t2-t1))*1000),0) Error correction: =IF(Fuel System Status=2,(LTFT+STFT+100),(AFR/Commanded AFR) *I have a more advance formula to take into account the delay between cylinder and O2 sensor, but it's a bit extreme to add here easily - I will add my Calibration Data spreadsheet as a separate thread* Click set axis and paste in your IAT table and validate it as the axis. Load in a log and set the x as IAT and y as g/s. If you added the extra columns as above: Set Data as Error Correction Filters: dV/dt < 0.6 (or whatever you use for CL MAF scaling) AFR < 16.5 At this point I would take the mean and count and paste them into this spreadsheet. Try that and see how it works. It's just a theory at the moment but based on what you've tried I don't see how it will be much different. Obviously check the table after. Try and ensure that the OEM axis of 0 compensation is kept. You may well get a slight change in those cells and I would then compensate the rest a little for that. I have added the option to set the % of the total correction to the tables so you can try incremental changes.
.: Stealth 86 :.
Abbey Motorsport/K47 Tuned Sprintex 210 Supercharger Kodename 47 DJ: Soundcloud / Instagram / Facebook Last edited by Kodename47; 10-03-2014 at 02:16 PM. Reason: Updated |
The Following User Says Thank You to Kodename47 For This Useful Post: | solidONE (06-11-2014) |
#140 |
Drives: UK GT86
.: Stealth 86 :.
AFR in Closed Loop | Toyota John | Software Tuning | 39 | 07-07-2019 08:26 AM |
BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 03:14 AM |
Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 05:49 PM |
Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 02:23 PM |
Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 10:19 AM |
