12-03-2012, 07:42 PM | #127 | |
Drives: '13 DGM BRZ Limited
12-03-2012, 09:11 PM | #128 |
Drives: Whiteout FR-S
12-13-2012, 10:54 AM | #129 |
I purchased aftermarket wheels back in June. I also purchased another set of sensors at the same time at Discount Tires. There is STILL no solution to resetting those sensors to work with the car. Therefore, the light is always on. Discount is looking into a solution for the problem but no answer yet. Is it possible that you could use another cars setting to make it work properly?
12-13-2012, 11:17 AM | #130 |
I park near my stock rims, but I drove about 60 km (I think that's around 40-50 miles? Not sure) the other day on my winter tires (with no TPMS on them). But my light never turned on. Any idea why?
12-13-2012, 12:12 PM | #131 |
12-13-2012, 12:21 PM | #132 |
12-30-2012, 06:21 PM | #133 |
Red is Fastest
Drives: 13 FRS 6MT Firestorm
If models in Canada have TPMS or not possible that its a simple hardware fix. Its either that or they ship different coding in the ECM.
I disabled the TPMS on my 06 Tundra. Been a long while but it was online. Think you had to just track down a wire and tie it to a ground to disable the light. I hate TPMS and will disable it at some point on the FRS. I have a new wheel and tire package coming, without the sensors. |
12-30-2012, 06:34 PM | #134 |
Drives: '13 GBS Subaru BRZ
One note. When I switched to my winter wheels without TPMS sensors the light came on pretty quick and would go on and off periodically. I was playing around with techstream and cleared all the errors in techstream. After I used techstream the light hasn't come back on again.
12-30-2012, 07:36 PM | #135 | |
Red is Fastest
I'm also looking through the service manuals to see if I can locate the TPMS wiring in the instrument panel hoping there is potential to disable the light there. Of course I could tear into the cluster and cover it as some have done. |
12-30-2012, 08:04 PM | #136 | |
http://www.ft86club.com/forums/showthread.php?t=7827
The Following User Says Thank You to neutron256 For This Useful Post: | FRSFirestorm (12-30-2012) |
01-07-2013, 11:57 PM | #137 |
Drives: 2013 Whiteout FR-S
cancel
01-08-2013, 08:26 AM | #138 |
Red is Fastest
Just a quick followup. I haven't completely given up the hardware disable of the light but it isn't looking good. From the wiring diagrams I've found appears the TPMS signals are read from the antenna in the rear deck lid. Then fed to the Body ECM. I couldn't find the actual TPMS light in the instrument cluster, since its not used universally, all countries I'm assuming its left blank in the manuals I have. Anyway it appears the light in the cluster is signaled via the CAN bus. Not an individual circuit you could disable.
01-08-2013, 10:10 AM | #139 | |
Drives: 2013 Scion FRS Raven
The Following 2 Users Say Thank You to Pbrown For This Useful Post: | 8R6 (03-23-2014), PLZdontscream (01-29-2013) |
01-08-2013, 10:00 PM | #140 | |
Drives: Firestorm FR-S
The Following User Says Thank You to scioneric For This Useful Post: | niceguy21 (04-19-2013) |
Similar Threads | ||||
TPMS Sensors.. | Dave-ROR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 04-08-2014 01:22 PM |
Subaru TPMS Nonsense | Grimlock | BRZ First-Gen (2012+) -- General Topics | 67 | 10-07-2013 03:15 PM |
TPMS Sensors | ashtray | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 78 | 05-24-2013 04:24 PM |
Auto Parking Sensors? | Swancoat | Scion FR-S / Toyota 86 GT86 General Forum | 86 | 02-18-2012 02:01 AM |
