Old 04-26-2013, 08:04 PM   #127
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
It says that you also have to buy the day-time running light
Originally Posted by CamryDS View Post
100+ dollars for a HARNESS!? no way, how can that even be possible just for connectors?
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 04-27-2013, 01:21 AM   #128
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
still a big rip.
CamryDS is offline   Reply With Quote
Old 04-27-2013, 03:24 AM   #129
Willsonk
Drives: Scion FR-S Asphalt AT & XB
I bought (2) SU00302583. I know its not the right part. I have decided to take out the 2 red wires with connectors and install them into my harness.
Can someone confirm that the black wire in the harness is the ground? Planning to tap into that wire to ground the fog lights.
This leaves me 2 sets of wires green and black color left from the harness. Anyone want to buy the sets. $15 a set ...... just wanted to off set what I paid already.
Willsonk is offline   Reply With Quote
The Following 2 Users Say Thank You to Willsonk For This Useful Post:
imravenit (04-27-2013), Tama-Y (05-10-2013)
Old 04-27-2013, 08:45 AM   #130
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
This leaves me 2 sets of wires green and black color left from the harness. Anyone want to by the sets. $10 a set ...... just wanted to off set what I paid already.
Someone mentioned earlier in thread that the black was not a ground. I had assumed it was.
FRSFirestorm is offline   Reply With Quote
Old 04-27-2013, 10:13 AM   #131
norm24
Drives: TSX
http://www.ft86club.com/forums/showthread.php?t=34169
See step / image 22.
norm24 is offline   Reply With Quote
The Following User Says Thank You to norm24 For This Useful Post:
Old 04-27-2013, 10:35 AM   #132
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
yes you can use the black wire as a ground. and your new pin would be your power.
imravenit is offline   Reply With Quote
The Following User Says Thank You to imravenit For This Useful Post:
Willsonk (04-27-2013)
Old 04-30-2013, 10:08 AM   #133
jcat5150
Hybrid Harness
You pop the pins and combine the two harnesses. Also you do not need to take the front bumper off. Just reach up by the headlight and detach the harness. They are both visible from the wheel well. The only cutting you have to do is on the Y harness ground. I simply popped the pin from OEM USA plug and reattached it to the Y (soldered etc). Honestly if I did it again I would create my own Y ground from the OEM turn signal to the H11, and install the missing pin to the harness and call it a day. The hybrid plug still uses a pigtail like the Subaru guys are having to do. I will say that my install was super clean though:
HYBRID PLUG (USA 3 pin Turn Signal)
jcat5150 is offline   Reply With Quote
Old 06-28-2013, 04:22 PM   #134
Tsungfai
Tsungfai's Avatar
Drives: 2013 Scion FR-S Raven
Bump in case someone is still interested in the stalk route.
Just got this from Nigel and I will install it this Saturday.
Front and Rear fog light with NO AUTO!
Unfortunately no part number came with the switch.
Tsungfai is offline   Reply With Quote
Old 07-01-2013, 06:00 PM   #135
FRSHunter
Drives: Asphalt FRS
Hi Guys, I wanted to add I think I just found the part where I can make this kit myself for a fraction of the cost:
Here's the plug assembly that we need:
http://www.villagescionparts.com/sho...roduct=8465060
Here's the Stock Code:
SU00302583
Can someone at Toyota verify if this is the harness that we need so we can do this fog light plug n play?
Sorry I'm a little slow and just wanted to clarify if this harness replaces the current harness and that no repinning will be required?
FRSHunter is offline   Reply With Quote
Old 07-02-2013, 12:41 PM   #136
CamryDS
yeah that's out the window by now heh.
This is not the right part. The guy selling this part online didn't show the part number. You're better off buying the USD version or the version from iishi motors ( depending if you want a push button fog switch or a switch on the stalk.
Old 07-02-2013, 12:52 PM   #137
Tama-Y
Tama-Y's Avatar
Drives: ZN6, DC2
That is not the correct part. That is only the standard cable that connects to the signal light. I made the mistake and purchased this part as well. I was misled by the diagram that indicates its a Y cable but it actually is not at all.
Still looking for an OEM part, but seems like I need to make one afterall. Now only if I can find those female pin connectors. Rona & Parts Source was no help.
Tama-Y is offline   Reply With Quote
Old 07-04-2013, 03:55 AM   #138
Retro86
Retro86's Avatar
Drives: Awesome
its a pin lol those harness that you guys bought prolly has them, you guys just need to pop open those connectors.
Retro86 is offline   Reply With Quote
Old 07-22-2013, 08:04 PM   #139
FRSHunter
Drives: Asphalt FRS
Old 07-23-2013, 04:06 AM   #140
FRSHunter
Drives: Asphalt FRS
FRS fogs using BRZ stalk Sco2355 DIY (Do-It-Yourself) Guides 378 12-16-2018 05:17 AM
Factory shift light/chime Wonderbar Electronics | Audio | NAV | Infotainment 29 04-05-2013 03:30 PM
Manual shifter stalk thread dimensions for knobs bcj Scion FR-S / Toyota 86 GT86 General Forum 1 03-19-2013 06:42 AM
SEAT BELT STALK COVERS cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 1 03-01-2013 12:57 PM
FRS fogs using BRZ stalk Sco2355 Cosmetic Modification (Interior/Exterior/Lighting) 0 02-18-2013 01:51 PM
