11-02-2019, 07:33 PM | #127 |
Drives: 2022 GR86
11-02-2019, 08:02 PM | #128 |
Drives: 2017 Toyota 86
Ouch. Any signs of it going bad before the trouble shifting gears?
11-02-2019, 09:35 PM | #129 | |
Drives: Subaru BRZ
Not yet. But I had to pull the FP to remove the transmission and the cat is already loose.
The Following User Says Thank You to Code Monkey For This Useful Post: | dowroa (11-02-2019) |
11-02-2019, 09:52 PM | #130 |
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Does the BRZ transmission have an oversized bearing replacement kit? Something where a better overall mechanism is used? I think the snout it replaceable on the BRZ, but the quality of Subaru's throw-out bearings has always been in question for all the Subarus I have ever owned.
11-02-2019, 10:02 PM | #131 |
What a bummer, especially considering all the time, effort, and money you have put into the car. Hopefully it is as simple as a bad TOB and nothing else was damaged.
11-02-2019, 10:22 PM | #132 |
Drives: Subaru BRZ
I hope it is just the TOB. One of the side clips is missing and I do not think there is anything else in that area that the bearings could come from.
Not really worried about the whole situation, that's the nature of the game I play. |
11-03-2019, 10:52 AM | #133 |
Drives: '13 BRZ TLM Spec
So since those ball bearings were in the M/T fluid, they are from inside the transmission assembly. There are several ball bearings in the transmission that are used as detents to align different components. They should never be just floating around in the fluid. Problem seems to be more than just the TOB
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
The Following User Says Thank You to Opie For This Useful Post: | Code Monkey (11-03-2019) |
11-03-2019, 12:47 PM | #134 |
Drives: Subaru BRZ
Thanks, figured it may be the case! The TOB bearings are bigger too. The clutch looks ok I guess?
11-05-2019, 06:39 PM | #135 |
Drives: Subaru BRZ
Sourced a used transmission locally, from a totaled Series.Yellow.
11-05-2019, 08:18 PM | #136 |
How many miles on your car?
11-05-2019, 08:24 PM | #137 |
Drives: Subaru BRZ
11-05-2019, 08:59 PM | #138 |
Drives: Subaru BRZ
Just got my oil analysis from Blackstone.
11-16-2019, 05:48 PM | #139 |
Drives: Subaru BRZ
Took the clutch to Clutch Specialty and they told me it was ok to run it so it is back in the car.
Got the Verus clutch fork with a new TOB and a clutch fork pivot but then a brand new Money Shift Racing hydraulic TOB came up for sale and I could not pass the deal. The transmission is back in the car, still need to reconnect all the wiring and finish up hooking up the hydraulic TOB. |
The Following User Says Thank You to Code Monkey For This Useful Post: | MCTeeJ (11-18-2019) |
11-16-2019, 07:47 PM | #140 |
Drives: 2013 Rally Blue w/Bronze wheels MT
I’m jealous of you getting that MSR, I wanted to see if it would have fit my project. I also ordered some stuff from neatgearboxes down in Australia.
About how think do you think that back plate is that gets put into the transmission? |
Similar Threads | ||||
Berzerk's 2017 CWP 'Slow and Steady' Build Thread | Berzerk | Member's Car Journals | 12 | 07-24-2017 04:57 PM |
Rodie's slow '13 FR-S build | rodie | Member's Car Journals | 0 | 06-14-2015 08:05 PM |
Slow Progression FRS Build | dgerny | Member's Car Journals | 1 | 04-15-2014 06:48 PM |
Tkalz slow build! | Tkalz | Member's Car Journals | 15 | 10-13-2013 05:35 PM |
Slow Build by Jooks | jooks | Member's Car Journals | 4 | 07-03-2013 10:53 PM |
