03-03-2013, 05:57 PM | #57 | |
Drives: Black frs project
Robi |
03-03-2013, 06:53 PM | #58 |
I love going fast!
03-26-2013, 02:19 PM | #59 |
Dismember
Drives: 2013 Red Scion FR-S
I see you have slightly wider tires on the same diameter wheels. What do you think of going with either lower-profile tires and the same width you have now on 17's or switching to 18's or even 19s at the same width?
03-26-2013, 02:33 PM | #60 |
This thread is awesome
03-26-2013, 06:08 PM | #61 |
Testing has proven that a non forced induction car with me in the seat is faster on 17" 225 with a enkei (LIGHT!) 8" wheel. the only reason to go to an 18" is if you had someone giving you tires and they didn't mind you losing. 19" are even worse...tires are springs and with geometry corrections in place so that the car distribiutes its weight transfer correctly SOFT IS FASTER...
The Following 8 Users Say Thank You to robispec For This Useful Post: | autobrz (05-29-2013), Calum (04-16-2013), CSG Mike (03-26-2013), EAGLE5 (03-26-2013), jonnyozero3 (03-30-2013), juliog (03-26-2013), NorCalRider (03-30-2013), Rampage (03-26-2013) |
03-26-2013, 09:13 PM | #62 |
Drives: Scion FR-S (Raven)
I don't remember where I read it. But what's your take on front and rear bumper beams? Did you remove those? Do you remember how much each weighed and wether it made much a change in frame rigidity? I thought it was Robispec's car but can't remember.
2013 Raven FR-S MT + Sparco Assetto 18x8 + Michelinn Pilot Super Sprot 225/40/r18 + Takeda CAI + Fortune Auto 500 coilovers + Tanabe Sustec front and Rear strut tower brace + Carbeau FX1 / 6 point harness / Harness Bar + Nameless front pipe + Perrin cat back + FA20club E85 tune + Wilwood front & rear brakes
03-26-2013, 11:34 PM | #63 |
Pulled both beams no change in stiffness.
Speedventures requires that we run at 2508 so we put the beam back in the rear. Robi |
03-27-2013, 04:40 AM | #64 |
Because compromise ®
Drives: Red Herring
Would you please tell me what rear lca and toe adjusters you are using?
03-27-2013, 07:38 AM | #65 |
currently stock.
03-28-2013, 07:43 AM | #66 |
Drives: Subarus
On modern cars the bumper beams are for safety and damage reduction, they do little for stiffness. Plus a box shape isn't efficient for torsional stiffness.
03-30-2013, 07:26 PM | #67 |
Dismember
I love what robispec has done to the car. I also hate it because his goals are different from mine so most of his mods are useless to me, like the crash beam removal and suspension. At the same time, I can see getting those Enkeis and and the oil/water radiator.
03-30-2013, 08:26 PM | #68 |
Light weight aluminum beams in the works!
03-30-2013, 09:18 PM | #69 |
Dismember
Interesting, but hard to prove the safety of without a crash test or some serious computer engineering. Steel and aluminum act differently. If possible, go wider than stock for better offset protection.
03-30-2013, 09:44 PM | #70 | |
Drives: 4 wheels & some metal bits
Can you confirm the best wheel width you've found is 8"? I ask because your first post of the thread says you're on 17x9.0's... |
Similar Threads | ||||
Canu_50's FR-S Time Attack, drift car!! | canu_50 | Member's Car Journals | 28 | 12-05-2013 02:04 AM |
My FR-S In Time Attack Mode!! | track_warrior | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 12 | 09-25-2012 02:13 AM |
Ontario Time Attack - TMP July 7th | 7thgear | CANADA | 8 | 07-07-2012 06:14 PM |
Vancouver auto-cross, time attack.. ? | EsoBOFH | CANADA | 4 | 06-20-2012 03:23 PM |
Tsukuba time attack review in the Car Top magazine | yajin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 5 | 05-18-2012 05:12 PM |
