Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-25-2012, 12:33 PM | #15 |
Drives: 2013 White Out FR-S
08-25-2012, 12:34 PM | #16 |
Honestly the only other testing we will be doing for a bit is on a Manual. I want to see how this tune carries over. Not to mention the car is apart waiting of the turbo to arrive Monday barring hurricane Isaac.
08-25-2012, 12:35 PM | #17 |
Pricing is posted in our thread in the vendor section.
08-25-2012, 12:59 PM | #18 |
When In Doubt...
Drives: Slowww
The HP "dip" hasn't been fixed either. It's been made a little less linear than it was stock all for an extra ~4whp from ~4k-7k....I'd be able to give a better response about the rev range if the full dyno sheet was posted. I'd love to see what the manual tune will look like. Looks like it has potential but I don't think all the work is done here. IMHO I don't see $600 of benefit unless you only drive at the very top of the rev range all the time.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
08-25-2012, 01:25 PM | #19 |
Things will vary on the display for the graph. I dont use much smoothing when tuning since that minimizes the amount of dip i can see. I want to see the dips for tuning purposes since this relays a lot of info such as misfire/detonation etc but for a sales standpoint its not that pretty. Here is another image with the smoothing increased some that shows there is significant gains down low. Also the break points on the graph play a large roll in the amount of separation you see in the graphs. I have made it a bit easier to read now with those more familiar with dynojet graphs
08-25-2012, 05:12 PM | #20 |
Drives: subatoy
what is the 2STEP feature for?
08-25-2012, 07:02 PM | #21 |
Well at this point for a manual transmission vehicle you would be able to set the rpm you launch the car from a dead stop to minimize wheel spin and for more consistent results while drag racing. Basically you hold the clutch pedal fully depressed and you can simultaneously floor the gas pedal and the rpms will stop at the preset rpms until the clutch is release and the vehicle passes roughly 3-5mph.
Similar Threads | ||||
EcuTek RaceROM Launch Control | just86 | Software Tuning | 47 | 03-14-2014 02:55 PM |
EcuTek Tuning in Australia | 86drift | AUSTRALIA | 46 | 09-01-2012 06:48 AM |
EcuTek preparing to release PRO ECU software for BRZ | Visconti | Engine, Exhaust, Transmission | 335 | 08-13-2012 11:34 PM |
EcuTeK tuning available *BRZ & FR-S* | Cotnoir | Engine, Exhaust, Transmission | 29 | 07-11-2012 07:15 PM |
Estimated HP gains - bolt on mods and reflash? | ahausheer | Engine, Exhaust, Transmission | 209 | 01-14-2012 06:14 AM |
