Drives: Raven FR-S
Flashing Security Light in Dash?
I was sure when I first got the car there was a flashing security light in the dash after you lock the doors with the fob. Can someone confirm if the FR-S has this? Our tC has one even though there's no alarm.
#2 |
Drives: 2013 HotLava FRS, 2005 Legacy
Mine does not have a flasher. I was just thinking about this last night in fact when I noticed my Legacy has a blinker, so I went and checked the FR-S and it didn't
HotLava FRS MT |
| The Following User Says Thank You to Neziah For This Useful Post: | ravenMTgirl (08-16-2012) |
#3 |
Drives: 2013 FR-S Black
Mine has one, I remember noticing it yesterday when I was parked in the garage at work. I will have to look closer to tell you where it is located. I was used to this on my tC and was happy to see that the FR-S had the same thing.
#4 |
Drives: Whiteout FR-S
I can confirm the FR-S has the security blinking light.
| The Following User Says Thank You to nocurfew For This Useful Post: | Bonburner (08-18-2012) |
#5 |
Drives: FR-S Raven
I know theres a light that blinks on the dash, when you have the key in the car. to warn you that the key is somewhere in your car (ex. in your pocket) just in case you dont lock your car and leave your keys inside.
#6 |
Lightness is a sickness
Drives: 03 Acura CL-S6 & 13 Scion FR-S 6MT
The FR-S does have a security light when the car is locked.
2003 NBP Acura CL-S 6MT, very very sleepy, 1 of 480
2013 FR-S 6MT, Asphalt, First 86 |
#7 |
FR-S does have this light, even though it has no alarm. The light means that the immobilizer is set. After inserting the key, the car will read the transponder inside the key. if the transponder code is a match, light goes off car fires up. If the transponder code in the key is not registered with the immobilizer ecu, the ecu will cut fuel. The car will crank but it will not start cuz the injectors are not opening. you can get a key that actually turn the ignition cylinder and makes the car crank however it will not start.
| The Following 3 Users Say Thank You to driver01 For This Useful Post: |
#8 |
Drives: Raven FR-S
Thanks for confirming
mine quit flashing for a couple days but now its working again. I guess I'll make an appointment if it stops again.
#9 |
Mr. Know It All
Drives: 2013 FR-S Asphalt
Mine never flashed, and just today it started flashing.....or somehow I never noticed it before and all the sudden I do notice it???
2013 FR-S Asphalt MT (55w HID's)
1985 Celica Supra 1JZ (Stupid Fast) |
| Traction light flashing under trail braking; TC and VSC are both off... | CSG Mike | Tracking / Autocross / HPDE | 72 | 10-26-2012 12:05 AM |
| Light flashing under trail braking. | CSG Mike | Suspension | Chassis | Brakes | 14 | 08-16-2012 03:10 PM |
| Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 09:06 PM |
| Turn signal amber LED's flashing quickly | michaelahess | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 07-13-2012 09:55 PM |
| anybody else see the flashing carrot??? | poormans_LFA | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 01-18-2012 08:25 AM |
