| Wheels | Tires | Spacers | Hub Specific topics relating to wheels and tires. |
#23 |
Drives: 2013 Argento Silver Automatic FR-S
This seems ideal to me. The more spacers you add, the more lug nuts are in play to spread out the load. Five hardly seems sufficient per wheel. Three, four spacers per wheel and you're spreading the force across twenty or twenty-five lug nuts per wheel, so each one is under only a small amount of stress. Like lying down on a bed of densely-packed nails versus only a few nails. Plus you can then have those wheels as wide as you want for the flattest cornering stance.
| The Following User Says Thank You to Nepenthe For This Useful Post: | F3dzo (07-24-2012) |
#24 | |
Drives: 2013 Subaru BRZ
| The Following User Says Thank You to ayau For This Useful Post: | F3dzo (07-24-2012) |
#25 |
What's the proper torquing on our wheels? I think the manual says 89 ft lbs, but I'd like confirmation on that.
#26 | ||
When In Doubt...
Drives: Slowww
You're good to go! Sorry for missing your text earlier
GBS Mafia ![]() |
| The Following User Says Thank You to Laika For This Useful Post: | Phaedrus29 (08-09-2012) |
#27 |
Inverse Animosity
Drives: Celica GT-S
I work at Discount Tire and we're not even allowed to work on the car if it has spacers. It's deemed unsafe.
![]() Inverse Animosity- These words codify my declaration of deference, and indemnify myself from the counter-progressive nuisance of biased judgment, ridicule and criticism based on discrimination such as driveline, engine size, pre-established dogmas, preconceptions or any such trivial nonsense. |
| The Following User Says Thank You to Asterisked Accolade For This Useful Post: | Entropy (08-10-2012) |
#28 |
Seņor Member
Drives: '13 Subaru BRZ L 6MT (SWP)
FUD = Fear, Uncertainty and Doubt
ie people possibly spreading mis-information about the subject. The problem is that nobody can come of a consesus about if (or what kind of) spacers are safe to run.
#29 |
#1819
Drives: Subaru BRZ
I used 25mm spacers on my RSX-S and it just ruined my alignment. I hope yours are of better quality than the ones I used.
#30 |
Drives: Black FRS
Just make sure they are at least 5052 Aluminum and hub centric.
Every Porsche I have ever owned and worked on has had bolt on spacers with studs. |
#31 |
Discount Tire is correct to make that as their policy. The reason why is because you are essentially adding an additional assembly which makes 10 lugs per corner. When you are dealing with that many per corner, the potential for error becomes greater. Its not saying spacers couldnt be safe, just for a company with thousands of employees, the potential problems and danger to the consumer is such that they wouldnt risk it.
#32 |
Drives: 2011 GTI / 2013 FR-S
Instead of using spacers, I would trade for wider or lower offset wheels if you're looking for a flush fit. Just my take on it.
#33 | |
Inverse Animosity
Drives: Celica GT-S
#34 | |
Seņor Member
Otherwise I'd agree with you.
#35 |
Drives: Scion FR-S
what size tire are you running in that pic?
| Shot these on my driveway last night | Hanzo | Photos, Videos, Wallpapers, Gallery Forum | 108 | 04-02-2013 08:09 AM |
| wheel spacer to 5x114 | derka-derka | AUSTRALIA / NEW ZEALAND | 12 | 07-02-2012 10:27 PM |
| mines13's living in the 90's boosted street DA build. My soon to be FRS driveway pal | mines13 | Other Vehicles & General Automotive Discussions | 16 | 03-30-2012 02:30 PM |
