follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Wheels | Tires | Spacers | Hub
Wheels | Tires | Spacers | Hub Specific topics relating to wheels and tires.
Old 08-07-2012, 08:16 PM   #1
Draco-REX
Draco-REX's Avatar
Drives: 07 STI, 03 WRX, 13 BRZ
Hubcentric Rings
No idea what they are or what they do? Heard of them, but aren't sure if you should have them? Here's a quick rundown about Hubcentric rings.
When looking at wheels, you may have seen rings like this:
Just a circular ring with a flared base.
This is a hubcentric ring. It fits between the center of your wheel and the raised center of your hub.
Here are a before and after:
(Before)
Parts from the center, outwards:
Axle Spindle
Axle Nut
Hub Lip
gap
Wheel Center
Lug Nuts (fastened to lug studs)
etc.
(After)
If you look closely at the Before picture, you will see a gap between the Hub Lip and the Wheel Center. Look at the After picture and you will see that the hubcentric ring fills that gap. The lip on the ring retains the ring behind the wheel.
So no unsightly gap. What else does it do?
That raised lip is part of the hub.
A simple diagram:
This is a very strong piece as it supports the weight of that corner of the car, holds the wheels on, mounts the brake disk to stop the car, and in the case of driven wheels, attaches to the axle and transfers the engine's torque to the wheels. So it's safe to say it can handle a lot of forces.
When you fill the gap between your wheel and the hub with a hubcentric ring, you're letting the forces acting on the wheel (bumps, potholes, cornering force, etc) transfer directly to the strong hub. Without that gap filled, these forces have to go through your lug studs.
Is this catastrophically bad? Not necessarily. There are plenty of cars with aftermarket wheels that aren't hubcentric that are probably perfectly fine. But these cars might not see pothole-ridden roads or racing. The issue is that OEMs make their stock wheels hubcentric. The wheel centers are the right size on their own to snug around the hub. This makes for a stronger wheel, and the lugs only have to be strong enough to hold the wheel to the hub. Meaning, OEM lug studs are not hardened. They are not designed to bear the entire weight of the car.
So those using the OEM lug studs should use hubcentric rings if they are planning to use their new wheels for racing, off-road use, or just have to deal with a lot of potholes. Not doing so runs the risk of shearing off the lug studs.
So any other reasons to get them?
An added benefit to hubcentric rings is that they will center your wheel on the hub, making sure it is perfectly aligned. This will cut down on the chance of unevenly tightened lug nuts causing the wheel to vibrate. When fitting a hubcentric wheel, you'll be able to spin it slightly back and forth on the lug studs before you tighten the nuts. This will show that the wheel isn't resting on the lugs but on the hub itself and is perfectly centered.
I can't get hubcentric rings for my new wheels that will fit my car, what do I do?
Don't panic. Just don't abuse your lug studs. Try to miss big bumps and potholes. Don't haul @$$ over speed bumps. And don't do track days or heavy AUtoXing. If you do want to do these things, replace your lug studs with hardened ones from ARP or a similar company. They are much stronger and can bear the weight of the car better than the OEM studs.
I hope this helps clear up any confusion. Obviously I advocate hubcentric rings for ANY replacement wheels that aren't naturally hubcentric for the car. I haven't yet seen a modern aftermarket wheel that wasn't able to fit Subaru hubs with a ring.
The Following 21 Users Say Thank You to Draco-REX For This Useful Post:
07stealth350z (08-25-2012), baldolera (08-27-2012), Duo (08-25-2012), ft86Fan (08-07-2012), GaN-MaN (11-14-2012), hyper4mance (08-15-2012), industrial (08-25-2012), Jesse (01-17-2013), kwood9000 (08-30-2012), Laika (08-08-2012), MarkMash (08-07-2012), monkie (01-18-2013), MVJ1975 (08-08-2012), Phaedrus29 (08-08-2012), RAYSSPL (11-08-2012), rcm47 (08-23-2012), Slartibartfast (08-26-2012), Spartan65 (08-10-2012), thatWESguy (01-17-2013), TuxedoCartman (08-29-2012), WRB-DZA-BRZ (10-04-2012)
Old 08-07-2012, 08:24 PM   #2
switchlanez
The Male Member
switchlanez's Avatar
Drives: Yes
Thanks, great post. My understanding was non-OEM wheel have a different contact surface to your hubs compared to OEM wheels. As a result, they may cause non-optimal wear to your hubs/bearings. Hubcentric rings help distribute load more evenly to your hub. I've heard the whole bit before about the wheels studs bearing the weight if no hubcentric ring is there; the OP details all of that.
"This isn’t about specifications or numbers but a cultural phenomenon."
-Moto-P
Old 08-07-2012, 08:28 PM   #3
Draco-REX
Draco-REX's Avatar
Originally Posted by switchlanez View Post
TLDR all of your post but my understanding is non-OEM wheel have a different contact surface to your hubs compared to OEM wheels. As a result, they may cause non-optimal wear to your hubs/bearings. Hubcentric rings help distribute load more evenly to your hub.
You may have wanted to at least read the first three sentences....
Old 08-07-2012, 08:31 PM   #4
switchlanez
The Male Member
Drives: Yes
Yeah I edited my post. I sort of skimmed through at first and thought you were confused about their purpose.
-Moto-P
Old 08-07-2012, 08:33 PM   #5
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, 330 Ci
I'm hearing conflicting facts regarding hub rings. Some (like you) say they carry the load while others say it doesn't. They claim the sole purpose of the hub ring is to help you easily center the wheel while mounting. I kind of agree with you that the hub ring does carry the vertical load but if that is the case, why are most rings made of plastic?
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'04 BMW 330 ci (White)
ft86Fan is offline   Reply With Quote
Old 08-07-2012, 08:37 PM   #6
Draco-REX
Draco-REX's Avatar
I've bought 5 sets of aftermarket wheels, and all but one used metal rings. The set that weren't were a high-impact composite, kind of what Rhino ramps are made of. Maybe some companies use cheaper plastic to save cost. In that case, then they would only be good for centering the rim. But the good ones will take a hit and direct most of the force of an impact directly to the hub.
The Following User Says Thank You to Draco-REX For This Useful Post:
ft86Fan (08-08-2012)
Old 08-07-2012, 08:37 PM   #7
dwx
If you tighten the lugs down correctly, it's the static friction between the wheel surface and hub which hold things in place. The lug nuts just provide clamping force, they don't carry any load, unless of course you don't torque them down properly. Hubcentric rings do not carry any load either, they are only there to help center the wheel before you tighten it down, in fact most hubcentric rings are cheap plastic or aluminum.
With the tapered lugs on the Subarus if you torque down the lugs in the correct order (star pattern like a flywheel), the wheel will almost always be centered on the hub. I've used non-hubcentric rims for autocross (16x10s...), track, etc. for years and never had any issues. People get in trouble with the plastic rings when doing things like tracking the cars because they can melt or metal ones expand since they aren't the same as the wheel and the wheel gets stuck on, etc...
I'd use them on street wheels, they make the wheel easier to mount and you won't get weird vibrations from screwing something up and the wheel being off-center.
dwx is offline   Reply With Quote
The Following 4 Users Say Thank You to dwx For This Useful Post:
ft86Fan (08-08-2012), RAYSSPL (11-08-2012), Ryephile (11-12-2012), Spaceywilly (08-14-2012)
Old 08-07-2012, 08:40 PM   #8
switchlanez
The Male Member
Drives: Yes
I don't think hubcentric rings bear the load; the bearings do that. The rings merely channel/distribute the load to the hub instead of the studs. Everything touching the hubcentric rings is static and is supposed to be mated tightly together so they don't see drastic impact forces that would cause them to shear/fracture. Most of the impact gets directed to the bearings/suspension.
-Moto-P
Old 08-07-2012, 08:41 PM   #9
Draco-REX
Draco-REX's Avatar
Well, I would rather have them than not for the reasons outlined above. Lugs can shear, so anything that can help minimize that is a good thing in my book.
Old 08-07-2012, 09:12 PM   #10
dwx
Studs generally only shear if the nuts aren't torqued correctly. If everything is true and torqued correctly, they do not carry any load. The wheel sits on the lugnut, people use fairly soft lightweight aluminum lugnuts all the time. If they were carrying sufficient loads they would probably deform.
I will say Subarus are not known for having the strongest wheel studs in history, they are very prone to breaking if they are undertorqued. Not sure if the BRZ is the same but you can find many failures on later gen Subarus. If they are undertorqued then you are putting load on the studs and I've seen someone shear all 5 at one time on a rallyx course. 99% of the failures are with stock wheels, which of course are hubcentric.
For a car seeing heavy track use I would probably just replace the studs with some ARP ones or something similar. With these cars you don't have to press out the rear hub to change the rear studs like the older WRXs, so that's a bonus.
The Following User Says Thank You to dwx For This Useful Post:
Old 08-08-2012, 07:51 AM   #11
ft86Fan
ft86Fan's Avatar
This is what I mean by the conflicting facts but I guess we all agree that using hubcentric rings can't hurt and its a good idea. You can get a set of plastic ones for $8 anyway.
Old 08-08-2012, 08:24 AM   #12
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
This ^^^
sho220 is offline   Reply With Quote
Old 08-08-2012, 09:07 AM   #13
dsgerbc
Drives: WRB BRZ, STI on order
Yeah, they don't bear any load, until they do, and then the difference could be the wheel falling off and going home on a flatbed vs. keep on driving home on a bent rim.
Old 08-08-2012, 10:27 AM   #14
schtebie
Drives: CBS BRZ Limited
(After)
A little off topic, but are those McGard Spline Drive lugs? If so, how do you like them?
schtebie is offline   Reply With Quote
Old 08-08-2012, 11:35 AM   #15
yoshiharadesign
yoshiharadesign's Avatar
the hub centric rings main focus is to soley center the wheel to prevent any vibrations that may occur from the wheel being mounted slight off center. Metal or plastic makes no difference as long as the plastic is a high temp grade and rigid with minimal play. Because there is always some play in the lug holes and the wheels, the ring effectively positions the wheel in the prescribed location.
yoshiharadesign is offline   Reply With Quote
The Following User Says Thank You to yoshiharadesign For This Useful Post:
Old 08-08-2012, 11:45 AM   #16
OrbitalEllipses
I'm different, yeah I'm..
OrbitalEllipses's Avatar
Drives: Attitude
Depends on the sizing. For instance, I want SSR wheels that have a 79.5 hub bore. Subaru hub bores are 56.1. No one makes a hub ring for that application aside from SSR and they charge around $20/ea.
Old 08-08-2012, 11:53 AM   #17
7thgear
Cynical Pessimist
7thgear's Avatar
Drives: Canada
you can avoid using rings if you slowly hand tighten your wheel in a star pattern
and by hand tighten and slowly, i do mean hand tighten, and slowly
the conical seat of the lug nuts will center the wheel 5 studs, but only if you do it slowly and evenly (ie, don't tighten just one nut all the way)
so if you have the time, i recommend doing it this way as it will do an even better job at centering your wheel than the centering ring.
Time-Attack Consultant (Ontario, Canada)www.time-attack.ca
Contact me with all your autrocross, time attack, and other race events questions.
The Following User Says Thank You to 7thgear For This Useful Post:
Old 08-08-2012, 11:59 AM   #18
yoshiharadesign
i would not suggest to exclude the ring. If possible always have the ring in place as regardless of how slowly you tighten the lug nuts, slight variances will always produce some vibrations. There is a reason why all oe fitments are hubcentric wheels.
The Following 2 Users Say Thank You to yoshiharadesign For This Useful Post:
OrbitalEllipses (08-08-2012), sho220 (08-08-2012)
Old 08-08-2012, 12:01 PM   #19
dwx
Yes that's what I was getting at. You need to do it in at least two steps of torque, don't just hammer down each nut in the star pattern.
Old 08-08-2012, 12:12 PM   #20
OrbitalEllipses
Drives: Attitude
There's really no reason not to use them...
Old 08-08-2012, 12:13 PM   #21
Draco-REX
Draco-REX's Avatar
Gorilla spline drives. I've used Gorilla lug nuts for a while now and have been very happy with their quality and durability.
Old 08-08-2012, 12:23 PM   #22
7thgear
Cynical Pessimist
7thgear's Avatar
Drives: Canada
i have been hand tightening hub-centric wheels for a decade with zero vibrations
the tolerance of 5 studs canceling each other out will be less than that of a single ring.
Also, OE wheels are OE wheels, they are built to match. Less confidence can be given to aftermarket.
5mm spacers and hub rings. zooki Wheels | Tires | Spacers | Hub 7 04-05-2013 09:57 PM
Buying OZ Superleggera 17x7 - Do I need hub rings? NYC BRZ Wheels | Tires | Spacers | Hub 2 06-10-2012 02:56 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
