Member's Car Journals Car journals by our members. |
10-31-2023, 08:46 AM | #127 |
Drives: Subaru BRZ
Went to Barber last weekend. Changed engine oil and transmission fluid afterwards, 734 miles on the new transmission.
The car is slightly vibrating at idle due to the engine mounts, if this persists, raising the idle to 900 rpm should take care of it. The engine/exhaust sounds amazing at WOT, quite guttural and raw, I can finally hear rpms building up from inside the car. |
The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | RedReplicant (10-31-2023), villainous_frx (10-31-2023) |
12-19-2023, 10:15 PM | #128 |
Drives: Subaru BRZ
Latest oil analysis.
The Following 4 Users Say Thank You to Code Monkey For This Useful Post: |
12-20-2023, 12:11 PM | #129 |
Drives: Toyota GT86
you should try using a GL-4 only oil in the trans vs a GL-4/GL-5 hybrid. I switched out my gear 300 for amsoil MTL and felt the shifts were smoother. Mostly a piece of mind thing in the end... Kinda sucked as I had JUST put in the gear300 lol
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
The Following 2 Users Say Thank You to autoracer86 For This Useful Post: | Code Monkey (12-20-2023), DocWalt (12-21-2023) |
03-26-2024, 01:06 PM | #130 |
Drives: Subaru BRZ
Well, the clutch started slipping after two hpde weekends so here goes another tranny pull. Out with the old, in with the new...
The Following User Says Thank You to Code Monkey For This Useful Post: | RedReplicant (03-26-2024) |
04-16-2024, 06:10 PM | #131 |
Drives: Subaru BRZ
The BRZ just turned 2 years old, put 3,761 miles in year 2, 11,481 miles total. |
05-10-2024, 08:33 AM | #132 |
Drives: Subaru BRZ
Installed DocWalt's hood vent, here's a picture from Road Atlanta with fellow twins.
The Following 3 Users Say Thank You to Code Monkey For This Useful Post: |
05-12-2024, 11:33 PM | #133 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Nice line up! Looks like a great day.
The Following User Says Thank You to villainous_frx For This Useful Post: | Code Monkey (05-13-2024) |
05-13-2024, 02:07 PM | #134 |
Drives: Subaru BRZ
Changed transmission fluid after 3.5 hpde weekends, kept on pouring Redline in a used Motul bottle as the Motul container works with the fluid transfer pump.
The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | autoracer86 (05-13-2024), villainous_frx (05-14-2024) |
05-13-2024, 02:11 PM | #135 |
Drives: Toyota GT86
Nice swap ! Hopefully you notice better shifting
The Following User Says Thank You to autoracer86 For This Useful Post: | Code Monkey (05-13-2024) |
05-13-2024, 02:17 PM | #136 |
Drives: Subaru BRZ
Pulled the front bumper to fix one pre-bulbed plusnut that started spinning, tightened the nut and added JBWeld around all 10 nuts to hopefully prevent any future slipping.
Used this opportunity to install the Outbound Motorsports GR86 cup car intake kit. Now I can commence work on a custom splitter. |
05-14-2024, 09:01 PM | #137 |
Drives: 2022 BRZ
A lot of similar mods! I just added Cusco mounts and the Outbound intake snorkel. The mounts added a fair bit of NVH. I really like the snorkel. I can actually hear some induction now
The Following User Says Thank You to Wangspeed For This Useful Post: | Code Monkey (05-16-2024) |
05-28-2024, 11:45 AM | #138 |
Drives: Subaru BRZ
Used a free piece of alumalite that fell off someone's Lotus to fab a splitter. Did not have enough material to do a one piece so cut one half of splitter and mirrored it to get the other half. Glued a piece of aluminum on the bottom to connect the two halves and Gorilla taped the edges. The splitter survived one day of HPDE so far.
05-28-2024, 11:59 AM | #139 |
Drives: Subaru BRZ
Swapped an OS Giken from Shaftworks into a spare 4.1 diff I purchased a while ago. Now waiting for ARP studs to arrive before I begin the break in process.
The Following User Says Thank You to Code Monkey For This Useful Post: | autoracer86 (05-28-2024) |
05-28-2024, 03:55 PM | #140 |
Drives: 2023 BRZ, 2018 Golf R 6MT
How many times did you have to remove/install that wheel to make the stud look like that? Lol.
Did it get cross-threaded at some point? |
Similar Threads | ||||
2017 Subaru BRZ hpde build | Code Monkey | Member's Car Journals | 207 | 04-18-2022 10:11 AM |
2022 BRZ JDM Spec build at HKS USA for SEMA2021 | 143 | BRZ Second-Gen (2022+) -- General Topics | 5 | 02-14-2022 12:27 PM |
redSerpente’s HPDE/86CUP Street build | redSerpente | Member's Car Journals | 10 | 04-26-2021 06:50 PM |
LS3 HPDE / Time Attack Build | RavioliG | Member's Car Journals | 17 | 02-11-2018 03:56 PM |
86_Freak - Build for DD/C Street/HPDE duties | 86_Freak | Member's Car Journals | 3 | 03-07-2016 09:15 AM |
