Tracking / Autocross / HPDE / Drifting What these cars were built for! |
01-15-2024, 07:37 PM | #127 |
Drives: 2013 frs base
What kind of switch is that on your Accusump?
01-16-2024, 04:01 PM | #128 |
Drives: 2017 BRZ
It's an electric ball valve. They are a little bigger, but they work better IMO than a solenoid style control (seals better, isn't energized constantly in its open state) now if you want the accusump to have a controlled on/off that's fast then the solenoid is the way to go.
01-17-2024, 08:47 AM | #129 | |
01-17-2024, 10:21 AM | #130 |
Drives: 2017 BRZ
The Following User Says Thank You to gt5759 For This Useful Post: | blsfrs (01-17-2024) |
01-18-2024, 12:24 PM | #131 | |
01-18-2024, 04:03 PM | #132 | |
Drives: 2017 BRZ
Oil temps wise I normally see 235* to 250* in the pan and about 20* to 30* less after the cooler at the filter adapter. I know the accusump gets hot enough I don't want to touch it after a race but that's as much data on that standpoint that I have. |
The Following User Says Thank You to gt5759 For This Useful Post: | blsfrs (01-19-2024) |
02-06-2024, 12:01 PM | #133 |
Drives: 2017 BRZ
Plumbing is coming together, still waiting on some more materials to finalize connections on hoses, insulation wrap and what not but basically, it's all there now.
All of the electronics are now in the car as well other than mounting the rear-view camera. I keep telling myself I'm racing this full season and not just fixing everyone stuff! Hard lines will be done in the tunnel once the drivetrain comes back out here probably this weekend. |
The Following 3 Users Say Thank You to gt5759 For This Useful Post: |
04-03-2024, 06:06 PM | #134 |
Drives: 2017 BRZ
More time spent on Lucille. Everything is in the car now and wiring is beginning to spread
mounting for the screens on the doors So I'll back up a little, a few little things still need to go in such as the 80-amp breaker for the ESP and the canbus hub but other than that it's just stringing wire, looming and terminating now! Wires in the last pic are not final, its just a in progress moment. Spent a little over 5 hours Sunday just working on the software for the pdm and ecu Firewall wire penetration is via radlok for the main power like the pdm and deutsch bulkheads. Those are installed now but I forgot to take a pic! |
The Following 8 Users Say Thank You to gt5759 For This Useful Post: | blsfrs (04-04-2024), Code Monkey (04-04-2024), DocWalt (04-04-2024), redlined600 (04-04-2024), RedReplicant (04-03-2024), Ultramaroon (04-05-2024), villainous_frx (04-04-2024), Wangspeed (05-05-2024) |
04-03-2024, 10:15 PM | #135 |
Drives: Fr-s
Was the motivation behind going with cameras over mirrors drag reduction or something else? Do you have them tied into a recording system?
04-04-2024, 12:04 PM | #136 |
Drives: 2017 BRZ
Hit it on the head! Aero was first, then visibility bonus - between all three cameras I can see 90* out from the doors all the way around very clearly. Video recording use is there and will be used later for race videos but mainly logged for use in car contact issues on track.
05-05-2024, 06:09 PM | #137 |
so much win. really nice looking race car!
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Similar Threads | ||||
Jensen NASA ST4 race build | thin2win | Member's Car Journals | 18 | 04-14-2021 12:15 AM |
Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
Superpenguin's "Not Another Build Thread!" Build Thread | superpenguin | Member's Car Journals | 7 | 06-17-2015 04:00 PM |
Car 986 Scion FR-S NASA PTD Race Car Build | phastafrican | Member's Car Journals | 70 | 01-03-2015 09:32 PM |
