Old 03-15-2023, 01:53 AM   #183
gpvecchi
gpvecchi's Avatar
I have to check the CalID, I'll let you know.
BTW, please let me know how to update the ABS module with Techstream, I didn't succeed.
I already had normal Brembo definition before, I have PP.
The Following User Says Thank You to gpvecchi For This Useful Post:
Trap63 (03-15-2023)
Old 03-15-2023, 08:36 AM   #184
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Originally Posted by RedReplicant View Post
Do you know the CAL ID for it? I wonder if this is something we can change. I'm going to poke around in my car later with Techstream.
I am assuming Brembo calibration is less intrusive too.
How are you able to receive CAL ID files? with TIS regular h/m registration/payment?
Trap63 is offline   Reply With Quote
Old 03-15-2023, 08:47 PM   #185
RedReplicant
Drives: None
I pulled the calibration ID on a few I had here, they all kinda match the unit that they came off of, just with a different leading part number.
IE:
27536CA050 => 27522CA050
27536CA070 => 27522CA070
Ignore all of the errors, car is K24 on Haltech.
I also checked the units from two of my friend's GRs - one base, one premium and same numbers
It is a mystery, definitely not like MK60 stuff where you can adjust chassis / slip parameters with INPA.
RedReplicant is offline   Reply With Quote
Old 03-16-2023, 02:38 PM   #186
geraldjust
Drives: MR2, Sliver BRZ
The GR and modules are much more different than gen1. The canbus networks are completely different and the internal program is too. The subroutines in code are slightly different. So they won't drop in without major rewriting firmwares on it. At the point Pedal dance does the same thing.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 03-16-2023, 02:45 PM   #187
RedReplicant
Drives: None
There is no change to ABS regulation?
Old 03-16-2023, 04:12 PM   #188
gpvecchi
gpvecchi's Avatar
The latest Cal ID for JDM Racing models is 27522CA840.
I'm interested in how to flash it using Techstream
Old 03-18-2023, 07:51 AM   #189
Compelica
Compelica's Avatar
Drives: 86 GT
I wonder why the calibration is etched onto the body of the VSC module, does that imply that it is not rewritable?
DIY stuff at Compelica Works
Compelica is online now   Reply With Quote
Old 03-18-2023, 01:59 PM   #190
gpvecchi
gpvecchi's Avatar
Probably for identification. It seems that both Techstream and SSM4 can write calibrations, but I don't know how to do...
Old 12-28-2023, 06:35 PM   #191
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
I found a unit 27536CA030 But it has a date of 2016 (16-06-24).
the crashed car has the track button and other aesthetic elements of my17.
Do you think it will work? It is the only unit I have found in my country.
Ruben_86_ is offline   Reply With Quote
Old 12-29-2023, 02:08 PM   #192
RedReplicant
Drives: None
Yup. 27536CA030 is good to go as long as the transmission types match.
The Following User Says Thank You to RedReplicant For This Useful Post:
Ruben_86_ (12-31-2023)
Old 01-17-2024, 11:41 PM   #193
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Thanks for the guide. I had this installed tonight. Don't be like me and accidentally push the white plug into the hole when trying to repin. I spent an hour trying to pick it out and then eventually got a screw, screwed it into the hole with the plug and pulled it out.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
Yoshoobaroo (01-29-2024)
Old 01-29-2024, 03:15 PM   #194
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
I installed a 27536ca030 of 2016 and it works perfect in my 2012, thanks for the guide.
The Following 2 Users Say Thank You to Ruben_86_ For This Useful Post:
Jdmjunkie (01-29-2024), Yoshoobaroo (01-29-2024)
Old 01-29-2024, 03:43 PM   #195
RedReplicant
Drives: None
Has anyone tried downloading calibrations through TIS and updating units with Calibration Update Wizard?
Trap63 (02-02-2024)
Old 03-15-2024, 12:32 PM   #196
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Is there a way to turn everything but ABS off automatically on startup?
2014 BRZ: Full track car. Gutted, caged, coilovers, AP enduro, OMP, bolt ons, aero, etc,
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies.
2018 GLE 63 AMG: +800hp whistling AWD TT V8 grocery getter
2016 GX460: IDK. Too reliable to sell. Too boring to use.
GrandSport is offline   Reply With Quote
Review of "Track Mode" on the MY17+ cars trippinbillies40 Tracking / Autocross / HPDE / Drifting 85 02-22-2021 09:27 PM
FS: Nameless muffled track pipe 2013-2016 Dave-ROR Engine, Exhaust, Bolt-Ons 4 05-20-2020 11:27 PM
Track mode vs. VSC sport alex87f Scion FR-S / Toyota 86 GT86 General Forum 9 10-30-2018 10:47 PM
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 10:34 PM
