follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Electronics | Audio | NAV | Infotainment
Old 08-01-2012, 10:15 AM   #1
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
My audio build
I just added my JBL PX300.4 to the stock speakers and it sounds pretty good. Quality is crap (I'm coming from Focal components w/ an Alpine DSP) but it's loud and the distortion is minimal. Compared to stock it's 100x better. But I'm coming from my previous build of a computer with digital audio, an Alpine DSP, Focal components and 2 12" Alpine's in a ported enclosure.
Now I just need some bass in this BRZ (and some new front speakers). I was thinking about fiberglassing a 12" sub (maybe two) in the spare tire well. Once my dynamat gets here I can get started.
I'll keep you all posted.
8/5/2012 - Sound deadening on Doors
Added some sound deadening material to the front doors. They are nice and solid now and the door shuts with a nice thunk ...no rattles. I still have the stock front speakers in the doors and the "dynamat" didn't really help them much (I didn't really expect it to since I didn't "seal" the door). It's incredibly hot outside but next up is the rear deck as that rattles and vibrates incredibly. I might use multiple layers.
Also, I saw some JL Audio 6W3 speakers the other day and I think I'm going to try and fiberglass these into a sealed enclosure in the door. That's the plan, we'll see how it turns out but I don't foresee myself getting started on it until late next week.
8/7/2012 - Trunk preparation
My Alpine Type R's are too deep - I'll be using the spare tire well but I'll be inverting the subwoofers in the far corners of the trunk rather then mounting the sub directly into the well.
I uploaded some pictures of the sound deadening in the trunk and the preparation of the sub box ...still much more to do
Name:  spare tire well.jpg
Name:  box initial layout.jpg
8/8/2012 - Fiberglass frames are ready
I created the fiberglass frames this morning for the subwoofers - cake walk but now I must wait because the weather is horrible today. The plan is still the same - inverting the subs firing down into the corners. But, I was also thinking that I could also (later down the road) put shallow mount subwoofers here and have even more trunk space. Should the need arise it's good to have that option. pics below.
Name:  fiberglass frame 1.jpg
Name:  fiberglass frame 2.jpg
Name:  sub mount 1.jpg
Name:  sub mount 2.jpg
8/9/2012 - First layer of fiberglass
I was able to test fit the frame today and start the first layer of fiberglass. Once this layer cures I can pull it out, clean it up, and layer on some more with it out of the car.
I also put a picture up showing why mounting them straight into the well would not be best. I'd either have to raise the floor (which from the factory is already high) or use some rings and mount the subs on an angle. I think the corners are going to work best. See below for new pics.
Name:  sub location 2.jpg
Name:  sub location 1.jpg
Name:  depth issue.jpg
Name:  1st layer of glass.jpg
8/14/2012 - Sub boxes ALMOST done!
So I finally finished all the fiberglassing. I put about 6 layers on it and finished it by glueing and screwing the top plate on. I still have to mount the L brackets, predrill the sub screw holes, and mount the T-nuts. Once that's all done then the boxes are officially done!!
My JL 6W3s should be here tomorrow and hopefully when the rain lets up I can continue onward.
Name:  1 layer cured.jpg
Name:  6 layers - done.jpg
Name:  glued and screwed.jpg
8/14/2012 - In and pounding
I just had to wire it up and take a listen ...it pounds and sounds fabulous. I took one of those crappy youtube videos.
Name:  boxes in and mounted.jpg
8/22/2012 - JL Audio 6W3s
I actually got them a while ago and snapped some pics. They will fit, but, I'll need to mount them onto the door panel which should actually be very easy. The speaker area of the panel unscrews which will make it easy to manipulate and mount it after the fact.
I've been very busy with work and stuff around the house so no progress, but there's pics of the JL's below
Name:  jl depth.jpg
Name:  jl test fit.jpg
9/21/2012 - Trunk floor done
Been a while - I've been busy with house renovations and haven't had much time to put into working on the car. My recent addition is the completion of the trunk floor. I'm not happy with the amplifier placement. I would've went vertical but I wanted it to be secure and I don't have a welder to whip up a nice metal bracket. Instead, I just wound up putting them flat. I'll build a box to cover them so it's a little cleaner.
Here's the latest pictures of the new trunk:
Name:  floor in 1.jpg
Name:  floor in 2.jpg
I love my BRZ
rmjjensen is offline   Reply With Quote
The Following 5 Users Say Thank You to rmjjensen For This Useful Post:
Auto-Hauss (08-10-2012), LeftFootBrake (08-10-2012), Marcoscrdo (04-07-2013), pheoxs (04-08-2013), tripjammer (08-24-2012)
Old 08-01-2012, 10:19 AM   #2
KRAZYK
Self Entitled
KRAZYK's Avatar
Drives: 13' Red FR-S, 12' Toyota Tundra
Looks good!.. I am planning out my install as well - been thinking about going with some Focal components or RE Audio components.
KRAZYK is offline   Reply With Quote
Old 08-01-2012, 10:24 AM   #3
rmjjensen
rmjjensen's Avatar
Also, this car is the EASIEST car I've ever worked on ...period. The headunit comes out with ease, rear quarter panels come right out, and I was able to get 0 gauge wire through the factory grommet RIGHT NEXT TO THE BATTERY! 0 gauge wire without drilling?! Unheard of.
I've been out of the audio game for a long time now. I've heard a lot about Hertz component speakers but I haven't actually heard them. I don't think I'm going to install my Focal's in this car - I might sell them and try to get a nice 3-way component set.
This car is actually difficult to plan out a good sounding stereo but everything is there! Speakers against the front windshield is GREAT! It's the complete opposite of 6x9's in the rear deck ...oh the dreaded 6x9s in the deck - where your stereo imaging is completely lost since they just blare off the rear backlight.
I love my BRZ
Old 08-01-2012, 10:34 AM   #4
KRAZYK
Self Entitled
KRAZYK's Avatar
You are right about this being a hard car to plan out.. It gives you the hint of going with a 3 way, but I have a feeling any decent tweeter will not fit in the factory location. Ive got a spare 5 channel amp laying around that I think I will use for my build.. but I'm not sure if I want to do a set of 2ways and bridge the 4 channels down to 2, or if I want to leave the 4 channels and run some 3.5s up front also. Too many options - im sure any of them will be better than stock.
Old 08-01-2012, 10:27 PM   #5
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Speaker wire zip tied to power wire? Um...
Is your power ran straight into the amp or is there a distribution block hidden somewhere?
Did the 0 awg just fall nicely between carpet and frame next to the passenger seat?
michaelahess is offline   Reply With Quote
Old 08-02-2012, 08:03 AM   #6
rmjjensen
rmjjensen's Avatar
With the use of "line level converters" on the BRZ the least of my worries is attempting to stop noise. The line level is guaranteed to give unwanted noise. What a bummer that there's no preamp output on this great looking headunit.
There's distribution blocks tucked away near the giant styrofoam under the mat.
The 0 gauge presented no problem - it's running along the bottom corner down the passenger side. I'm still amazed how easy that was.
My sound deadening is arriving today!! I hope not too late so that I can get started on the fun stuff. I should probably just start stripping the whole car right now.
I love my BRZ
Old 08-02-2012, 11:45 AM   #7
michaelahess
Sweet. I put 25sqft of sound deadener in, another 100sqft just showed up yesterday! (not worried about weight, just chuck the wife out)
I've got a Scosche SLC-4, well the previous version which is identical, and I actually was surprised that there was NO noise from it! My system is completely hiss free until you get to the max volume on the HU, then it's just the smallest amount. I was very impressed with that.
Glad to know 0 gauge works just as well as 4, won't be worried about upgrading now!
Old 08-02-2012, 12:18 PM   #8
computertech01
Drives: Jetta MK1V
Might have to make a 2 hour drive so you can install my audio for me.... I've only had bad experiences with best buy installation. I'm definitely going to have to switch out the stock speakers. Do you think any aftermarket amps would fit where the stock one goes? I don't really like attaching the amp to the back of the seat.
computertech01 is offline   Reply With Quote
Old 08-02-2012, 01:05 PM   #9
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
Morel MT250 fits in the stock location perfectly and sounds amazing.
The Elate or Hybrid Ovation 6 3way fits flawlessly and performs brilliantly in all stock speaker locations.
Symbiont is offline   Reply With Quote
Old 08-05-2012, 10:17 AM   #10
rmjjensen
rmjjensen's Avatar
The stock amp is tiny - maybe about 6"x6". I'm not sure what might fit there but I think the new Rockford Fosgate amps are pretty small.
Updated first post with NVX Audio sound deadening on the doors.
I think I finally have a plan for this setup. I'm going to use JL Audio 6W3's in the doors, my focal tweets in the dash and leave the stock midrange (still not sure on that but I think the stock mid will be fine). For bass I'm going to use the spare tire well and fiberglass 2 Alpine 12" Type R's (I might go with just one - not sure) and also incorporate my two JBL amps into the floor - sides of the sub enclosure. I'm a long ways away from this though.
Next up, sound deadening the rear of the car - including that horrible rear deck!
I love my BRZ
Old 08-05-2012, 06:09 PM   #11
computertech01
Drives: Jetta MK1V
I wish you had done a diy write up seeing as you know your stuff. I'm interested in what wiring kit you used and anything else. I'm basically just looking to do what you've done so far so I can be setup for future additions.
Old 08-05-2012, 10:17 PM   #12
mashal
DADA
mashal's Avatar
Drives: 2013
More pictures if you have already taken , or if you could of where everything is.
I'm also planning the build but this car is just messed up with the speaker layout
mashal is offline   Reply With Quote
Old 08-07-2012, 08:07 PM   #13
rmjjensen
rmjjensen's Avatar
Not really much to write up - the grommet in the firewall next to the battery is the ideal place to run the power wire. As for amping the speakers, I basically used the wires at the factory amp in the trunk for all the front speakers, and ran new wire to the rear quarter panel speakers. The preamps run all the way up to the headunit and hook up to a preamp I added to the factory head unit.
I'll take pictures once I finalize everything. The wiring is just under the mat - it's not pretty but I plan on changing the entire thing - this install was merely to get some better sound.
I love my BRZ
Old 08-07-2012, 08:09 PM   #14
rmjjensen
rmjjensen's Avatar
I changed my mind regarding the subwoofer placement. The Alpine Type R's I have are way too deep and would take up too much trunk room if I mounted them in the spare tire well.
Instead, I'll be using the spare tire well as air space and invert the subwoofers into the false floor. Since they're being inverted I'm going to mount them into the far corners of the trunk.
That's the plan!
Also, I officially ordered some JL Audio 6W3's for the doors ...that'll be interesting...
I love my BRZ
Old 08-08-2012, 01:21 AM   #15
drifter
Drives: truck and old car
Can you tell me the largest speaker size that can be used to replace the back ones?
drifter is offline   Reply With Quote
Old 08-08-2012, 06:15 AM   #16
-max-
Drives: Firestorm FRS
Sub'd
looking forward to seeing how this comes out. I actually thought about going inverted with my sub also, as its 6 1/2" deep. Its either that or find something shallow enough to fit.
-max- is offline   Reply With Quote
Old 08-08-2012, 11:40 AM   #17
rmjjensen
rmjjensen's Avatar
I honestly didn't take any measurements when I was back there - next time I take the quarters off I'll report back.
Originally Posted by -max- View Post
Sub'd
The Alpine's I have are about 7-7 1/2" deep - they will fit normally in the deepest part of the spare tire well but it would be tight - otherwise I'd have to raise the floor higher than stock. I'm curious how my inverted subs in the corners will sound - they've been in a ported box since day 1 so I'm not expected to be blown away just for the sheer fact it's going to be sealed now.
I love my BRZ
Old 08-08-2012, 11:43 AM   #18
rmjjensen
rmjjensen's Avatar
Finished the wooden frames for the fiberglass this morning. Unfortunately it is insanely hot out today and I don't foresee myself actually getting started with a layer of fiberglass today. Ugh - hopefully it cools off soon but the humidity is rough right now.
See the first post for pics of the wooden frames. Also, this car just keeps getting better and better! Both sides of this car are perfectly symmetric! I've never worked on a car where both sides of the trunk were the same - it's always been some computer, fuel fill up, abs lines, or spare tire in the way.
I love my BRZ
Old 08-08-2012, 11:56 AM   #19
-max-
My sub is 6 1/2" plus have to leave room for the vent. I need to pit it in there and see if I can fit it.kind of dumb that I have not dome this yet.lol
Old 08-09-2012, 10:04 AM   #20
rmjjensen
rmjjensen's Avatar
I think you'll be okay - it'll be tight but would work right down into the spare tire well. The subs I have are about 7 1/2" deep - you can see in the pic I posted how much higher the floor would need to be.
I love my BRZ
Old 08-10-2012, 02:11 AM   #21
Auto-Hauss
Auto-Hauss's Avatar
Drives: 2013 Scion FR-S-Asphalt
If you still have your door panels off could you take close up pictures of the bulb socket and bulb of the door still light. Also could you take a close up picture of the harness for the bulb socket at the Tee in the harness. I wanted to know if the wires for the light are tied into the wires at the Tee or if they continue down into the loom. Sorry for thread jacking its just that only BRZ limited cars have that harness. Premium BRZ and FR-S don't have that part of the harness. So Its nice finding a person that has the limited and the door panels off.
Good luck with the build. Thanks
Auto-Hauss is offline   Reply With Quote
Old 08-10-2012, 05:46 AM   #22
cruzinbill
Drives: Argento 6spd FR-S
coming along nicely, is the sub gonna face up or down tho? I keep seeing it both ways so curious.
cruzinbill is offline   Reply With Quote
The Following User Says Thank You to cruzinbill For This Useful Post:
rmjjensen (08-10-2012)
Looking for an FRS/BRZ in the SE For Audio SpeakBeck Southeast 8 02-17-2013 11:57 AM
Max's Audio build -max- Electronics | Audio | NAV | Infotainment 92 02-16-2013 01:06 PM
OEM Audio Plus Subwoofer K2 Electronics | Audio | NAV | Infotainment 28 12-21-2012 09:28 AM
BRZ Audio Question poudre Electronics | Audio | NAV | Infotainment 4 07-11-2012 07:48 AM
Audio Options Aznek CANADA 2 02-26-2012 02:17 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
