follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Issues | Warranty | Recalls / TSB
Old 07-27-2012, 12:47 AM   #23
rs_two_five
Drives: 2007 Subaru WRX
Heat and humidity can do a number on performance...
X2
Or possibly the feeling you're getting is from the added weight of the fuel in the tank. Heck, I notice driving my WRX when the tank is low vs full. It's the reason why I always fuel up before auto-xing.
rs_two_five is offline   Reply With Quote
Old 07-27-2012, 07:37 PM   #24
CircuitJerk
She sings baritone...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
There could be several things at play here.
Fueling up with a reduced octane level can cause the ECU to start correcting and changing timing to compensate. I don't know how the 86 is set up so this part is more speculation than anything.
I've had it take almost half a tank or better before things settle in. My Rav4 V6 shares the same engine as one of the Lexus models with direct injection that requires premium. It is rumored the ECU programming is identical and has the logic to compensate for regular or premium.
When I changed to 93, after about 3/4 tank I noticed more pull and responsiveness especially in hot humid weather. The mileage improved slightly as well. When fall came and the temps dropped to the high 70's (F) I changed back to regular and had a similar experience for what it seemed like an entire tank of fuel.
What I suppose was happening was the higher octane in the higher temps and humidity allowed more aggressive timing and better performance whereas the 87 it would just lag in hot weather since it was pulling timing..
Don't panic, drive it out but avoid WOT as much as possible.
Go back to the 93+ and give it a half tank and see what happens.
CircuitJerk is online now   Reply With Quote
Old 09-07-2012, 07:49 AM   #25
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Originally Posted by Ad8707 View Post
Filled 91 v power (no ethanol), hour later noticed significant power loss..it's taking awhile for the rpms to climb...car has 4000km no oil change..did I get bad gas...or is something more serious ie maf sensor fuel pump/fuel filter..it takes awhile for those things to go bad right...
Update? It's been over a month.
Grimlock is offline   Reply With Quote
Old 09-07-2012, 01:40 PM   #26
Razz
Razz's Avatar
Drives: Fast
When this happens buy a can of HEET to remove water.
http://www.autozone.com/autozone/acc...ier=136367_0_0_
Razz is offline   Reply With Quote
Old 09-07-2012, 10:06 PM   #27
Coheed
Coheed's Avatar
Drives: Super Sentra
Use ISOHEET it is non-corrosive.
Coheed is offline   Reply With Quote
Old 10-15-2012, 07:46 PM   #28
TemeCal
TemeCal's Avatar
Drives: 2013 FR-S Ultramarine
Sorry to resurrect this thread. However, I just had the exact same thing happen to my car. My car had Mobil 91 in it, and it was very quick and responsive. Just fueled up with 91 Shell V-Power, and it is SLOW now. It honestly feels like a completely different car, like I'm back in the Corolla rental Toyota put me in.
Anyway, I was curious to see if you resolved your issue. If so, what'd you do? Switch brands? Octane booster?
Before anyone says I should be using 93, I'm in CA and only have access to 91. I do have some Torco fuel additive I use in my desert toys, so I may mix some into this tank.
Thoughts??
TemeCal is offline   Reply With Quote
Old 10-15-2012, 08:40 PM   #29
so26
Drives: Raven FR-S 6MT
Soooo how does this story end?
so26 is offline   Reply With Quote
Old 10-15-2012, 10:57 PM   #30
Rob_g
Drives: 2010 4Runner Trail
Thoughts??
I have tried v-power 91 octane and it seems to consistently lower the mileage I get by about five to ten percent. We don't have 93 anywhere locally here in SK.
Rob
Rob_g is offline   Reply With Quote
The Following User Says Thank You to Rob_g For This Useful Post:
TemeCal (10-15-2012)
Old 10-15-2012, 11:14 PM   #31
TemeCal
TemeCal's Avatar
Rob
Thanks Rob. Did you notice any loss in power also? This is my 1st tank on Shell, and happens to coincide with my power drop.
Old 10-15-2012, 11:56 PM   #32
gmookher
shell sucks?
Old 10-15-2012, 11:58 PM   #33
Razz
Razz's Avatar
Drives: Fast
Gas Stations vary in the amount of ethanol from day to day.
This effects power output.
Old 10-16-2012, 12:28 AM   #34
gmookher
Originally Posted by gmookher View Post
shell sucks?
No , not to be g=funny, i live by techron/chevron, but have been using shell in the BRZ for a quieter fuel pump, but I too feel there is less power in Shells 91 vs the other guys 91
Old 10-16-2012, 12:38 AM   #35
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
I use shell at least once a month just to clean up things inside but i do see a difference using shell compared to QuikTrip gas..... Use that all the time and it seems to have more go compared to Shell
SMOKETREES is offline   Reply With Quote
Old 10-16-2012, 12:55 AM   #36
AVOturboworld
Manufacturer of Boost
The problem with gas stations, especially ones that you have never been to before, is that while you paid for, and thought you pumped, 91+ octane gas into your car, you are unfortunately at the mercy of the gas station owner, who may not actually be using 91+ octane at those pumps. In Japan there was a big scandal over that, actually.
It's something we noticed on our big cross-country road tune trips. Most gas stations were "honest", but occasionally we'd hit that bad one and the car would would start pinging.
Paul Hansen
Office Phone: 206-546-4455
Office Hours: 9am ~ 5pm Pacific Time
http://www.avoturboworld.com/index.php
http://www.facebook.com/BRZSportsCarClub
The Following User Says Thank You to AVOturboworld For This Useful Post:
sierra (10-16-2012)
Old 10-16-2012, 04:28 PM   #37
Bristecom
Bristecom's Avatar
Drives: 99 Mitsubishi Eclipse GSX, Evo X MR
I'm pretty sure I got some bad V-Power my last fill in the Eclipse. I'm still trying to work it out of the system. There's been rumors of bad gas going around (no, not that kind of gas) also with BP. But I've been using V-Power for years and this is the first time I may have had an issue (but I'm still not 100% certain it is the fuel).
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 10-16-2012, 09:51 PM   #38
Rob_g
I couldn't say, but it sure as heck didn't run any better with it.
Rob
Old 10-16-2012, 10:10 PM   #39
FRiSson
Drives: FR-S MT
Got something like this a while back. I thought my calipers were dragging - but that wasn't it. The engine would lose power, particularly at neutral throttle, and I had to goose the accelerator to compensate. It continued to act up periodically through about 4 fillups. Finally, it has disappeared after 1,000 miles. I took it to two dealers, but the problem is kind of subtle and they just couldn't feel it. Gas mileage suffered by about 10% as well.
FRiSson is offline   Reply With Quote
Old 10-16-2012, 10:21 PM   #40
jasper
jasper's Avatar
Drives: Scion FR-S Firestorm Red
I drove my car a lot before getting the crickets fixed I had this issue my dealership said it was because the fuel pump was bad which caused the crickets once I got them fixed that all went away. Not sure how true all that is but it seemed to work.
jasper is online now   Reply With Quote
Old 10-17-2012, 10:18 PM   #41
TemeCal
TemeCal's Avatar
So, I happen to have 5gal of Torco Accelerator in my garage. I added 8oz of it to my ~10gal of fuel. My car woke up BIG time.
I'm not sure what the issue was, but it was either bad gas or lower than the advertised 91 octane. My car is running great again! No more Shell for me (may try it again later).
Old 01-06-2013, 01:05 AM   #42
captainzib
Oompa Loompa of Science
Drives: Scion FR-S
Originally Posted by RandomHero View Post
Not to be a stick in the mud but doesnt each bottle raise the octane by like 0.3? so to go from 87-90 thats 30 bottles? Octane doesnt make power it just prevents knock. Look elsewhere before wasting money on octane booster. Take it to dealer if it gets real bad. But unless its knocking (banging) the octane is fine.
I realize this is an old thread, but I just thought I'd point out that while the bit in bold is correct, when modern cars sense lower octane than desired, the computer will adjust the timing to compensate which could result in the power loss OP is feeling.
It says in the manual for this car that 93 is preferred but 91 can be used if that's not available. I know there are cars out there that say 93 preferred but 87 can be used, with the ecu running different timing as mentioned above to compensate.
captainzib is offline   Reply With Quote
Old 01-06-2013, 01:59 AM   #43
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Scion FR-S, 66 beetle, 11 GSXR 750
Our cars will run on 87 if you have to put it in.. I've been out of the mechanic field for a few years.. But when I was doing my ASE classes and schools and stuff.. There wasn't a car that is a USDM vehicle that couldn't run on 87.. They all had to have a map.. Even Ferrari or Lamborghini ... They couldn't be responsible for a engine that blew out of warranty because all that is around is 87 octane and the driver had to use it.. For instance the sandy incident, 87 was all that was available in some places.. If you had to put it in your car and the engine would detonate, even with that sticker, the manufacture is still responsible, it would be a law suit they wouldn't want to handle.. It'll run different.. You especially notice it in the summer months.. But it should still run acceptable.. I thought about running 87 for half a tank to see the differences in this car.. My 93 probe with the Jdm KLZE engine was suppose to run 93+ but ran just fine with no noticeable difference in performance.. Unless i was driving up the only hill in central Texas.. Then I could hear a slight knock.. Other wise fuel mileage and performance stayed the same.. I remember when I used to cry over 1.75$ for premium.. We have a station here in Barstow off the highway to get the suckers that don't turn left and drive a block that pay 4.35 to 4.80 for 91.. It's like 3.75 a block down the road the other way..
Gixxersixxerman is offline   Reply With Quote
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
Marrk (01-06-2013)
Old 03-16-2013, 01:26 PM   #44
FRiSson
Drives: FR-S MT
I have had problems after two fillups. The first one lasted for about 1,000 miles. After the second time it happened, I added a half bottle of HEET additive. It went away quickly after that. I believe that the FR-Z is particularly sensitive to gas quality problems due to the dual nature of the fueling system.
Factory Oil Fill Level Black Tire Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 03-09-2013 08:44 AM
Loss of power after gassin up HELP!!!! Ad8707 CANADA 26 07-29-2012 05:24 PM
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 77 10-31-2011 09:30 PM
DI and engine power loss over time Sport-Tech Engine, Exhaust, Transmission, ECU 7 06-27-2011 04:49 PM
How much are you guys paying to fill your tanks? Giccin Off-Topic Lounge 64 04-13-2011 12:36 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
