Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-10-2017, 01:25 PM | #43 | |
Drives: 2015 Raven FRS
03-10-2017, 04:24 PM | #44 | |
LMGTFY
Drives: 13 FRS, 91 Miata
At what RPM are you making 400whp? Cause at peak torque you're only making 276hp. Assume you hit peak HP at 7k, You'd need 300 torque. Even at 8k your cars torque would need to be higher than what you stated as your peak torque. Your numbers don't add up. |
03-10-2017, 04:27 PM | #45 |
Drives: Toyota 86
You have quoted 2 different peoples cars in there Drifter :P.
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
03-10-2017, 04:30 PM | #46 |
Drives: Toyota 86
Heres a pic of one of my Dyno runs for reference.
03-10-2017, 05:29 PM | #47 | |
Drives: Toyota 86
03-10-2017, 06:30 PM | #48 |
LMGTFY
03-28-2017, 06:50 PM | #49 |
Drives: toyota86 full opt aero auto
Now that I'm pretty close to having the funds for the edelbrock kit I'm contemplating about a 2002 996 Carrera s I saw in an add..
it's priced the same with the resale value of my gt86.. and the funds for the edelbrock kit can go to any maintenance issues Sent from my HUAWEI NXT-L29 using Tapatalk |
03-31-2017, 08:54 AM | #50 |
Drives: 2013 Scion FRS
I too have noticed late shifting and some slippage when going form 1st to 2nd and 2nd to 3rd. When really on it I have to shift a good 1-2 seconds before I want it to actually shift. I'm currently in the 350-380 WHP range on 265s and I'm trying to figure out what all I can do to beef up the trans.
02-10-2019, 12:38 PM | #51 |
Drives: 2013 GT86
What trans fluid are you boosted guys using?
12-02-2019, 05:34 PM | #52 |
Drives: 2013 Toyota FRS
I've been using the stock WS but overheated the tans twice (very hot days on track) costing me 2 sets of clutch packs. This time I'm going to add a friction modifier which also reduces temp (according to claims) add a temp gauge, and change fluid more frequently. Also considering switching to Amsoil Signature series or OE; both of which are replacements for WS.
The Following User Says Thank You to North_GA_FRS For This Useful Post: | OfficeLinebacker (06-10-2022) |
12-02-2019, 06:42 PM | #53 | |
Drives: 2017 toyota 86
12-02-2019, 08:00 PM | #54 |
Yes, replacements were SSP and labor was $1200 but also included the stage 2 valve body install; haven't installed the second set yet. Car is making 350/275 on a Mustang dyno.
12-02-2019, 10:25 PM | #55 | |
The next big purchase for my build is building the trans. But I really want to swap in a ZF 8HP having 6 close ratio usable gears instead of the 4 capable of handling plenty of power and swapping to a 3.7 FD with 400whp+ would be amazing. Just don’t know what would all be necessary for the ZF swap. |
12-09-2019, 06:11 PM | #56 |
Im torn between doing clutch pack / valve body or attempting a swap to a different auto.
Wish someone made an easy solution to swap in a ZF 8HP. An 8 speed with 6 usable gears and holding 400+wtq with ease would be amazing. 3-4 is just too long we need an in-between gear and then 5th is not really usable. |
Similar Threads | ||||
Boosted owners in NY - how are you passing state inspections? | Foobar | NY / NJ / CT / PA | 12 | 10-15-2015 02:02 PM |
Auto Trans issue | Triumphrider | Issues | Warranty | Recalls / TSB | 9 | 11-04-2014 07:34 PM |
Is there an Auto Trans only dyno thread? | Pure Automotive | Engine, Exhaust, Transmission | 17 | 07-17-2014 12:35 AM |
Auto Trans Feels like it is slipping... | Fett4Real | Issues | Warranty | Recalls / TSB | 19 | 01-16-2014 10:02 PM |
What is the best way to Launch the Auto Trans | DeOppressorLiber | Tracking / Autocross / HPDE / Drifting | 27 | 10-22-2013 11:24 PM |
