06-17-2019, 06:32 PM | #1191 |
Drives: 2015 frs
Good luck Dustin. You deserve this to be a good reliable car with all of the effort you put into it. Sad to see you getting engines with issues the rest of the car is so nice. Hopefully you get this resolved.
The Following User Says Thank You to Zer0 For This Useful Post: | DustinS (06-18-2019) |
06-18-2019, 10:20 AM | #1192 | |
Drives: 2017 WR BLUE BRZ
The Following User Says Thank You to ILLSMOQ For This Useful Post: | DustinS (06-18-2019) |
06-21-2019, 02:46 PM | #1193 |
Drives: 2013 Ultramarine FR-S
Left to Right - Front to Back
Passenger Side: Driver Side: Lots of buildup Scoring on cylinder wall. I only checked the first two cylinders on the drivers side, but both had them.
06-21-2019, 03:05 PM | #1194 |
Drives: 2013 frs red
Dude, you need a new motor. These fucking rebuild shops are an expensive crap shoot. God bless what comes in a crate.
The Following User Says Thank You to Lantanafrs2 For This Useful Post: | DustinS (06-21-2019) |
06-21-2019, 03:38 PM | #1195 |
You've put so much into this, you deserve a reliable driver.
06-25-2019, 11:53 AM | #1196 |
Found a company offering a 2JZ to FRS harness for the ECU Masters EMU Black. Interested in how well the canbus works.
I am still weighing the options of staying LS and rebuilding it, or switching to K20 or 2JZ. I like the idea of 2J sounding great with good power, and being able to use my current transmission easily. I just don't like how heavy and large it is. It's also considerably more expensive to build over the K20. K20 is small and light, but I am worried the power I am looking for will make it lazy. I know there are way around this, but something I really enjoy about the LS is how easy it is to drive. I will need to get custom bellhousing and clutch setup, but I think quicktime should be able to handle the bellhousing. Plan is to call them here in a bit on lunch.
06-25-2019, 12:40 PM | #1197 | |
Drives: FRS
Can you DM me their contact info? Sent from my iPhone using Tapatalk |
06-25-2019, 02:28 PM | #1198 |
Found they don't actually sell it. Website doesn't actually work, it's just up while they work on a few things.
06-25-2019, 02:36 PM | #1199 | |
Drives: 2015 Raven V8
06-25-2019, 02:48 PM | #1200 | |
If the scoring is as bad as it looks, block is toast (won't know until I get it apart). Pistons were extremely worn last time the engine was apart, so I can't imagine what they look like now the second time around. Then add in rods and crank to get rid of the TSP products that will sell for next to nothing because they are used. I also like the idea of gaining space and losing weight, especially the heavy convoluted dual 3" exhaust that doesn't really fit under the FRS. Getting rid of drone is going to be an expensive quest as well. Speaking of which, if I stay LS I am going to buy the Corsa Extreme Camaro Axle Back. Seems it will cut the drone, and should sound decent with my current muffler in the center.
06-25-2019, 02:53 PM | #1201 | |
Drives: Red BRZ
Sent from my SM-G950U using Tapatalk |
06-25-2019, 03:11 PM | #1202 | |
06-25-2019, 03:31 PM | #1203 |
I just Drive.
Drives: in the womb still
Well if anyone knows how to google search properly I don't think TSP is going to get much work after this....
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
06-25-2019, 04:10 PM | #1204 |
Drives: 2014 FRS LS Swap
I would get a used ls3 oem, nice heads, cam, and call it a day. Just an example My LS2 402 made 507rwhp/491 rwtq all day long without breaking a sweat. 400 lb ft of tq from 2500 rpm up to 6800. This would give you exactly what you are looking for. I had mediocre heads too. Dart pro1's. Cam was an LG G6X3. Kooks 1 7/8 headers.
Sent from my SM-G950F using Tapatalk |
Similar Threads | ||||
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
Ls or 2jz swap? | sgoldberg01 | BRZ First-Gen (2012+) -- General Topics | 13 | 03-22-2016 03:07 PM |
Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-21-2015 11:38 PM |
AT-->MT swap | AlwaysSideways | Want-To-Buy Requests | 3 | 12-15-2014 11:14 AM |
Should I swap? | michaelahess | BRZ First-Gen (2012+) -- General Topics | 8 | 06-12-2012 07:32 PM |
