Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
05-19-2019, 09:33 AM | #1 |
Drives: DGM 15' BRZ Limited
Question about transmission and rear differential oil
This is for the 2015 Manual Transmission BRZ Limited
I thought there was only transmission oil and rear differential oil? But upon reviewing the manual and their website for maintenance, there’s a lot of different names for them. Are they all the same or are they actually different oils that need to be maintenanced? Also, I've heard the term manual transmission oil, is that another type of oil is is it the same thing as rear differential oil/differential oil? 48k miles service- inspect transmission gear oil 60k- inspect ATF/transmission fluid 72k- inspect transmission gear oil 48k- inspect rear differential gear oil 60k- inspect rear differential fluid 60k- replace rear differential gear oil https://imgur.com/a/ZafpqP3 |
05-19-2019, 09:41 AM | #2 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
You are correct, the components are a transmission and a rear differential. In this case the terms, "fluid" and "gear oil" are interchangeable, however, that's not to say that the fluid/gearoil itself is necessarily interchangeable between the components.
The Following User Says Thank You to BirdTRD For This Useful Post: | Ultramaroon (05-19-2019) |
05-21-2019, 02:43 PM | #3 |
Drives: Scion FR-S Series 10 #2462
Motul claims their 300 Gear Oil can be used both in the transmission (manual) and the differential. Most just use Subaru's Differential Oil without any issues.
05-21-2019, 03:00 PM | #4 |
Drives: 2017 Toyota 86
This has been covered a lot before, and in conflicting ways. Based one the spec called for in the owners manual I went with the below products.
I know many people will sell the Motul as being suitable for both the transmission and differential, but if you ever have a warranty issue with the transmission then the dealer may not be able to get Toyota to cover it unless you can prove you used the proper spec fluid. Sent from my iPhone using Tapatalk |
05-22-2019, 03:13 PM | #5 | |
I Love custom Turbo kits
Drives: Limited BRZ
05-22-2019, 10:47 PM | #6 |
Here is the research I did before delving deeper into the meaning and spec of GL-3, 4, and 5:
The Following User Says Thank You to Chuckable For This Useful Post: | Ultramaroon (05-22-2019) |
05-23-2019, 12:19 AM | #7 |
義理チョコ
My decision as well. I don't trust that it's truly safe for the brass. There's no harm in using a straight GL-4, especially when the gearbox requires only GL-3.
05-23-2019, 08:31 AM | #8 |
Only users lose drugs.
Drives: All the time
It's safe for brass in an environment where the brass components are not synchronizer rings. The buffer that coats the yellow metals and protects them will flake off by the inherent action of syncros and in the process, it brings a small layer of the substrate brass itself with it. Just use the correct GL3/4 from the get-go, instead of something that has a bandaid applied to it in an attempt to make it work in the wrong environment. GL5 in a hypoid gear environment like the rear diff is perfect.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post: | Ultramaroon (05-23-2019) |
05-23-2019, 01:21 PM | #9 | |
義理チョコ
It doesn't help that Motul is both tight-lipped about their formula and use weasel words in their application info. If they were truly confident in their product, I would expect them to use big bold font instead of burying it in small print.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | gravitylover (05-23-2019), venturaII (05-23-2019) |
06-16-2019, 09:21 PM | #10 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
For what it's worth, I dropped the trans and diff oils at 12000km and they were very soiled from the break-in period.
I went amsoil synchromesh in the trans because 2nd was tough to get in in cold weather and 75w140 gl5 in the diff. I just changed again today, 11000km later, went to amsoil 75w90 gl4 in the trans, synchromesh was a bit too thin and brought out the noisy side of the gearbox, the gl4 shifts much smoother and quieted down the box. For the same reason, I went back to dinosaur gl5 in the diff, but what I had on hand was a bit thicker than stock at 80w90. That should hardly make a difference. |
06-18-2019, 01:52 PM | #11 |
This is what the differential drain plug looked like with 20k miles on the OEM fluid. Sent from my iPhone using Tapatalk |
06-18-2019, 02:10 PM | #12 |
Purist
Drives: 2013 FRS - Hot Lava
Pentosin MTF2 in the trans. 75w-80
Motul 300 in the diff 75w90 I did mine at 40k. Didnt even look dirty. Im now around 53k, trans feels great.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
Similar Threads | ||||
FS; Brz manual transmission 2k miles. rear Differential | sokol | Transmission and Driveline | 7 | 07-25-2019 01:12 AM |
Magnetic drain plug in both transmission and rear differential? | jc7993 | Engine, Exhaust, Transmission | 19 | 04-04-2019 12:58 PM |
Transmission and rear differential drain plugs: Are they magnetic? | Seanzky | Engine, Exhaust, Transmission | 22 | 07-25-2018 07:55 AM |
Transmission and differential | Frsboxer | Transmission and Driveline | 7 | 08-29-2016 11:26 AM |
Transmission and differential question | Frsboxer | Engine, Exhaust, Transmission | 8 | 08-28-2015 08:06 AM |
