follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Engine, Exhaust, Transmission, ECU
Engine, Exhaust, Transmission, ECU Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain.
Old 07-16-2012, 01:52 PM   #1
harajukukei
Drives: MB c230k
Throttle Controllers
I haven't seen anyone talking about these things yet, but Tom's, Blitz, and a bunch of other JDM tuning brands are selling electronic throttle controllers for the 86/BRZ. I was wondering if anyone has experience with these and can explain their use/value? I understand how they work, just curious if they are worth while. All my previous cars had mechanical throttles so these are new to me.
Examples:
Blitz Full Auto Light
http://www.blitz.co.jp/products/elec...ler_light.html
Blitz Full Auto Plus
http://www.blitz.co.jp/products/elec...ocon_plus.html
http://youtu.be/vBpkU1DgrAM
harajukukei is offline   Reply With Quote
Old 07-16-2012, 02:35 PM   #2
empower-auto
Kouki-Monster
empower-auto's Avatar
Drives: 1994 Toyota Soarer 2.5 GT-T
Send a message via MSN to empower-auto
I think OBX makes a ghetto version of this. Even I don't know if they are good.
Rich Anderson
EMPOWER Auto / speedtech racing development
1994 Toyota Soarer GT-T Black Black 5MT
2013 Scion FR-S - Raven Black 6MT
empower-auto is offline   Reply With Quote
Old 07-16-2012, 02:36 PM   #3
dwx
I can't find the thread but someone actually did a test or relayed a JDM test that showed that the throttle controllers work worse than stock and generally just make the car idle worse.
dwx is online now   Reply With Quote
Old 07-16-2012, 02:38 PM   #4
Martin Donnon
86 Racer
Martin Donnon's Avatar
Drives: 86GT
All throttle controllers do is trick the relationship between the throttle pedal (your foot) and the throttle blade (your engine). You can achieve exactly the same result by pushing the pedal down further or less. Its not magic, in fact its not even good. Its a gimmick.
Martin Donnon is offline   Reply With Quote
Old 07-16-2012, 04:00 PM   #5
Turbowned
Turbowned's Avatar
Drives: AW11 MR2 20v, E30 BMW 318is
It allows you to tune the throttle-by-wire's response time. I have something similar in my Audi, called "Drive Select". In normal mode there is a slight lag in throttle response (very slight) to improve fuel economy. In "Dynamic" mode it sharpens the throttle response to make it feel more sporty. In "Comfort" mode it delays throttle response even further, to avoid jerky accelaration. I almost never take it out of normal mode but there is a marked difference between the three modes. Would I spend the money on one of these, though? No.
Old 07-16-2012, 07:43 PM   #6
mike2100
Fanboy
mike2100's Avatar
If all you want is acceleration then yes, I agree.
However, as I've gone through a few HPDEs I have realized the importance of throttle modulation. Being able to make small, precise changes in the amount of throttle input allows you to transfer weight more smoothly and ultimately go faster.
So, the ideal pedal-to-butterfly relationship (IMO so far) is a 1:1 relationship. Draw a graph. Make throttle input the X axis and throttle/butterfly opening the Y axis. The relationship I'm describing is a line that starts at the origin and has a slope of 1, extending to 100% throttle input and 100% throttle opening.
These throttle controllers can change that line into a curve. I forget how to describe it (been a while since math class) but I'm thinking of something like an exponential function.
What I am curious to know is if the stock throttle map is linear (straight line) or not. If it is, then no need for a throttle controller in my opinion, unless you just like to tool around town and don't need the precision. The other case may be that you want to dampen the throttle to trick yourself into driving more slowly to save gas.
mike2100 is offline   Reply With Quote
Old 07-16-2012, 08:58 PM   #7
Martin Donnon
86 Racer
Drives: 86GT
I wouldnt have thought there would be too much need to modulate the throttle in small increments on a 200hp NA four cylinder to control its attitude. Flat out on the throttle or flat out on the brake pedal in something like the FT86. I will get to prove this in mine at the track in the next few weeks
Old 07-16-2012, 09:01 PM   #8
mike2100
Fanboy
mike2100's Avatar
So you don't modulate the throttle when you drive your 86 on the track?
Old 07-16-2012, 10:07 PM   #9
Martin Donnon
86 Racer
Drives: 86GT
Not to the point where the throttle action or slope of throttle needs to be changed with a tricker box. Now maybe a 500hp FRS might be a different story....
Old 07-16-2012, 10:22 PM   #10
serialk11r
Drives: 2000 MR2 Spyder
Throttle and engine load are different :P
Old 07-17-2012, 11:13 AM   #11
arghx7
Drives: car
it's an SAFC for your gas pedal
Old 07-23-2012, 05:43 AM   #12
ae86trueno
Drives: AE86, RS200
Hi all, I was searching for this information for quite sometime.. So GT86 does actually have the drive by wire? How close does the response compare to car which run with just wire directly and carb?
Reason why I'm asking its because I'm so used to old car which just run from pedal to throttle with wire (used to have ae85 then changed to ae86 and integra zx for daily drive). When I got Altezza, it just annoy me to no end with the throttle response. For just driving daily its okay but I just felt it does not have the response I want.
ae86trueno is offline   Reply With Quote
Old 07-23-2012, 05:07 PM   #13
dwx
The drive by wire system is probably the same as used in the STi since 2004 and WRX since 2006. It's pretty good and there isn't really any throttle lag. Nobody installs these throttle controllers on those cars.
Old 07-23-2012, 05:19 PM   #14
EsoBOFH
Senior Hoonigan
EsoBOFH's Avatar
Drives: 2013 Argento 6MT FR-S
Examples:
These actually have some good applications - throttle response (in terms of adjusting delay) is just one small part. The value in these is to create custom throttle curves...
As an example, the stock Tundra has a crazy sensitive throttle - it seemed like the first 10% of throttle movement went from 0% to 90% of throttle, and the remaining pedal movement did little or nothing. This was a real issue when trailering and trying to back up, maneuver a load, be precise etc.
with this box, you can really have the first bit of pedal movement feathered out, and make it really easy to control speed on the low end. you could make a full linear curve, an economy curve.. or all on if you wanted
Granted, i'm not sure what application this would have on our cars.. I think the throttle is pretty well sorted.
EsoBOFH is offline   Reply With Quote
The Following User Says Thank You to EsoBOFH For This Useful Post:
Jesse (07-23-2012)
Old 07-23-2012, 05:22 PM   #15
UncleFester
Cone Killer
It only makes a difference at part throttle. Full throttle there is no difference. Plenty of people have done 0-60 tests with and without and found no difference.
They are snake oil products IMO.
UncleFester is online now   Reply With Quote
Old 07-23-2012, 05:31 PM   #16
xcelir8brz
xcelir8brz's Avatar
Worked great on my previous Honda Fit. Major stock lag.
xcelir8brz is offline   Reply With Quote
Old 07-23-2012, 05:46 PM   #17
xjohnx
Grip>Slip
xjohnx's Avatar
Drives: 13 SWP BRZ LTD 6MT
FWIW, 04 STi was still mechanical, 05+ got the DBW.
Old 07-23-2012, 05:46 PM   #18
vividracing
FT86Club Official Vendor
vividracing's Avatar
Send a message via AIM to vividracing
To be honest. Stay away from these. Get a tune.
Outside of here I work in the motorcycle world. I see guys using these and even a few in the Subaru world that have had the gears jam on their throttle bodies from using these.
Plus you are only going to waste money if you going to get a tune anyways. Its one of the maps the tuner adjusts.
vividracing is offline   Reply With Quote
Old 07-23-2012, 05:54 PM   #19
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
One reason people don't use these on a Subaru is that they start out pretty good. The other reason is that once the ECU has been cracked, these become a paperweight with wires. Rather than trick a throttle, you can adjust it exactly as you please in the ECU.
TheRipler is offline   Reply With Quote
Old 07-23-2012, 06:00 PM   #20
SkullWorks
Drives: SSM LT MT BRZ
actually there are plenty of cable operated TB's that have a curve built in to the TB mechanism (example: Q45 TB that everyone uses) it scales the throttle so you can leave a light without burning the hides off the car, then after a ceretain point the curve goes linear and gets steep.
BACK TO THE CAR AT HAND:
the FRs/BRz seem to have throttle application limited at low RPM to limit torque (for economy or warranty I am not sure) that is the largest single benefit I could see from a device such as this, it may potentially allow full throttle opening at all RPM's, I will know for sure soon, waiting on my AEM patch harness from MPT.
Old 07-23-2012, 06:12 PM   #21
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
There's no possibility of jamming gears or anything with one of these controllers. All it does is tell the ECU you are pressing the gas pedal a different amount than you actually are. It's not doing anything you couldn't do yourself by simply pressing the pedal a different amount. The difference is how the throttle responds to how much you are pressing the pedal.
I've used many different brands of throttle controller from Blitz to Pivot, etc. Never seen any vehicle ever have an issue, and I find they work very well.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 07-23-2012, 06:17 PM   #22
SkullWorks
Jeff
yuck, so reading this, you can't even trick the throttle to giving more angle than max allowed vs, RPM in the stock ECU?
bummer, officially useless, unless correcting drivability issues
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 10:50 AM
To those with the auto -any throttle lag or hesitation at low speed? ahausheer Engine, Exhaust, Transmission, ECU 22 07-25-2012 04:21 PM
86 Full Throttle Video + another. Aus86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 06:07 AM
Throttle Blip, and other features? ashtray Subaru BRZ General Forum 39 03-07-2012 09:52 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
