| AUSTRALIA / NEW ZEALAND Australia and New Zealand |
#45 |
Drives: Slowly
That's irrelevant in a thread about legality, because neither of those options are even close to legal.
I bought my first WRX in 1994 and enjoyed a few years of worry free motoring before they became popular with the exact demographic this car is being marketed at (the Silvia demographic). These cars will be cop magnets ... and probably rightly so.
#46 |
Drives: 86 GTS
I'm putting 18x7.5 by +45 with 225/40 federal 595 rs-r on mine easy, legal, and won't upset the handling balance.
#47 | |
Drives: Mt Fuji Red 86 GT
With regards to legalities of the track, I guess it’s lucky it isn’t your car, huh?
#48 | |
Drives: Dark Grey TRD86, Highlander, Micra
The Toyota supplied TRD wheels are 18 x 7.5 with 225/40 Michelen Pilot Super Sport tyres on them so I'm comfortable that it'll be legal and handling will be ok. Problem is the TRD wheels are about four times the price of after market wheels so definitely won't be using the actual TRD wheels. And, as the TRD version here doesn't have the TRD coilovers (they are an extra) I assume all with fit on the stock setup. Might look at 18 x 8 but only if will work and handle with stock setup without long-term issues. Don;t know much about wheels so will need to research or get advice on that. |
| The Following User Says Thank You to nzer For This Useful Post: | Panman (07-15-2012) |
#49 | |
I am assuming, that like me, you don’t care too much about a slight track increase though
#50 | |
Drives: 86 GTS
#51 | |
Drives: Slowly
Panman, your example only increases track by 6mm and is perfectly legal.
#52 | |
Drives: 86 GTS
Track increase is to the centre of the tyre - because I'm going at the +45 or at worst +48 offset (same as std) so increase in track will be around 6mm. Last edited by Panman; 07-15-2012 at 09:35 PM. Reason: Because I had it wrong - Thanks Coyote. |
#53 | |
I don’t know what you’re fuckin problem is with me though?? I couldn’t care less if you listen to me or not Don’t flatter yourself.I am not sure where you got your track calculation from, but I typed in all of the information into a track calculator and it worked it out. It says there is a track increase of 1.126in. Do they maths. 1in = close enough to 25mm. Now all you do next is multiply 25 x 1.126, and let me know the result What do you mean I have “once again made a statement that is completely incorrect and misleading”?? That’s a rude implication there, and you are guilty of providing incorrect/misleading info as well mate... |
#54 | |
![]() Here is the detailed calculator I sued http://gti-vr6.net/library/engine/Sc...ldiameters.htm I didn't write the software, just entered the details
#55 | ||
Drives: Slowly
#56 |
#57 | |
Drives: 86 GTS
I rechecked the placard on the wheels (which I have here with me Work Emotion CR-Kai happy to post photo of placard if requested.) 18x7.5 +48. According to the calculator you used it's actually 22mm increase in track which either way is legal (I went in and entered the details). I apologise if it seemed I was taking sides - an error on my part. At this point I bow out of the conversation between yourself and coyote. |
#58 | |
, Yes the +48 will decrease the track difference.Didn't think you were taking sides man, just linking to the calculator I had used
#59 | |
Drives: 86 GTS
Got it - wanted to make sure I corrected my mistake so everyone was on the same page. I didn't want to add fuel to the discussion To summarise, according to the calculator with: 18x7.5 +48 and 225/40 18" = 22mm increase in track width. With documented proof.... (Placard attached). |
#60 | |
#61 |
Drives: AVO BRZ
Can you two stop measuring your twats, thread is for helping others about legalities.
#62 |
Drives: 86 GTS
#63 | |
Drives: Slowly
I'll state again, for the purpose of testing legality in Qld, a +45 offset will result in a 6mm increase in track, which is legal. Of course there'll be a small increase in the scrub radius, but that won't have the kind of detrimental effects that offsets of +30 or less may be prone to.
#64 | |
Drives: 86 GTS Auto in Pegasus White
If I put in the same details for both wheels it shows track diff as 0 which it should. Then if I change one tyre by 10mm (so 215 to 225) it says the track changes by 0.39 of an inch. That sounds wrong to me. The tyres simply get wider but the centre of the tyre doesn't move at all. Or do I not get it? |
#65 | |
Drives: 86 GTS
Either way the electrons on the interwebz are providing lots of argument fodder and I'm legal. |
#66 |
Yeah its pretty crazy - the way I see it is going from +48 to +38 is moving the centre of the wheel out by 10mm on each wheel - so total track change is 20mm - regardless of the width of the wheel.
| Which 18" wheels will weigh the same or less than the stock wheels? | mickey177 | Wheels | Tires | Spacers | Hub | 32 | 05-16-2013 02:07 PM |
| [FYI] Street Legal Info | Calidrifter | Southern California | 7 | 06-29-2012 01:02 PM |
| Forgestar wheels, great wheels at great prices!!!! | IslandImportPerformance | Wheels and Tires | 0 | 06-15-2012 04:03 PM |
| Max legal interest rate? | UriarteMD | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 03-12-2012 12:50 PM |
| O.Z. Wheels | Zaku | Wheels | Tires | Spacers | Hub | 25 | 02-28-2012 02:21 AM |
