09-25-2018, 05:00 PM | #86 |
Just the tip
Drives: 2017 DGM BRZ
Hmm, I was able to just take the brackets off my old headunit and install on the sides of the new unit. Do you have the single piece leather dash trim with rectangular opening? Should be a straight swap, no aftermarket brackets needed.
09-26-2018, 03:45 AM | #87 |
Thanks I needed to sand down some centering pins, but then was a straight swap
09-27-2018, 05:02 PM | #88 |
Jesus, this HU is really killing me: I have isssues with Mirror Link, when my iPhone 8 gets connected, I just get a black screen. Anyone with same issues?
10-05-2018, 12:47 AM | #89 |
10-05-2018, 07:35 AM | #90 | |
Drives: 2014 Subaru Forester
83154CA040 or 83154CA060 Both of those numbers show up for the 2017 Limited. Not sure what the difference between the two numbers is. 83154CA120 Is for the tS which has the black piece vs the silver. |
10-05-2018, 02:08 PM | #91 |
Just the tip
If I had to guess, it might be whether the button above the volume controls on the left cluster says "Source" or "Mode". My 2017 Canadian brz says "Mode" but every picture I see online of a 2017 wheel says "Source" instead. No idea which is which...
10-05-2018, 04:50 PM | #92 | |
Perhaps we'd need the VIN number of a car equipped with the correct remotes. I found even 83154CA110 that can be correct.
OK, this is the full list for remotes on both sides: 83154CA120, 83154CA110, 83154CA100, 83154CA060, 83154CA050, 83154CA040, 83154CA030. Quote:
Do you have voice commands and answer/reject buttons? |
10-08-2018, 05:20 PM | #93 | |
Just the tip
10-09-2018, 12:37 AM | #94 |
I found the P/N, 83154CA110 is the silver version, with all buttons and “mode” button.
01-09-2019, 12:51 AM | #95 |
Small update: part number is correct, but it has the "Source" button, "MODE" button is another part, just for Canadian market. I'll check the connections...
01-10-2019, 05:16 PM | #96 |
Update: BRZ remote buttons are a straight swap with Toyota ones. All the keys work with DDX.
01-11-2019, 07:42 AM | #97 |
Drives: '15 GT86 & '22 GR86
Whats the radio reception like for non Oz/NZ users? I'm thinking of buying one for my UK GT86 but a bit skeptical on the radio quality.
Has anybody tried Torque Pro on it yet? I know its not an approved Android Auto app but you can now use it using the XDA developers patch. |
01-11-2019, 04:38 PM | #98 |
Radio reception in Italy is good, I just miss the DAB+. I still have to test the Torque app, my bluetooth adapter had problems with my Pixel 3, they seem fixed with January update.
The Following User Says Thank You to gpvecchi For This Useful Post: | Varelco (01-15-2019) |
Similar Threads | ||||
Kenwood DDX916WS head unit -- any installed? | willimusk | Electronics | Audio | NAV | Infotainment | 39 | 07-27-2017 10:47 AM |
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US | GSX-R35 | Electronics | Audio | NAV | Infotainment | 17 | 05-26-2015 03:37 PM |
Anybody know ... what head unit this is? | chaoskaze | Electronics | Audio | NAV | Infotainment | 3 | 12-21-2014 06:44 PM |
Soo i installed a new head unit....gaps | Sniper2606 | Electronics | Audio | NAV | Infotainment | 2 | 01-16-2014 05:12 PM |
Toyota sized Kenwood Navigation unit | Laurie | Electronics | Audio | NAV | Infotainment | 36 | 09-26-2012 12:07 PM |
