#365 | ||
chicken tonight
#366 | |
Drives: FT86
F
Yeah sure can all the ecu are same hardware, If your car is 2012-2016 manual you can just flash in an A01G rom with tactrix no need to hack or mod anything Just use native A01G and A01G definition to flash or edit with ecuflash or romraider. All the new V4 oft roms for those years are all actually A01G but they need to do a bit of calid hacking to get oft to accept different rom. With tactrix you can jist flash it in it doesnt care. You can even use your car as a test bed to flash, you dont need to sync ecu to car to flash it. So if you got rustys ecu just remove battery connection, crawl under dash with spare ecu and just swap the four connectors into his ecu is possible to slide the second ecu next to original so cables reach. The reconnect battery and flash up the second ecu, if all dandy then you can just sync in the new ecu by looping 4-13 on obd for 30 mins. The start car and your on new ecu. No need to set vin or other stuff. The hardest bit is crawling under dash To switch back same deal battery disconnect, swap ecu plugs, attach battery, loop 4-13 , ignition on, wait 30 mins. Ign off remove loop. Your good to go on old ecu Last edited by steve99; 07-04-2018 at 04:39 AM. |
The Following 2 Users Say Thank You to steve99 For This Useful Post: | tomm.brz (07-04-2018), Ultramaroon (07-04-2018) |
#367 | |
chicken tonight
I'll just take all your broken shit. ![]()
#368 |
Here for the fun
Drives: 10 Series FR-S #2478
Urghh, I too am having this nightmare -- P0018 --. I have read every post in all 27 pages of this thread. Thanks to all who have contributed. So far I have...
Swapped OCV's from left side to right side. Checked plunger piece on cam gear (the part the OCV moves) All plungers moved freely and easily. Erased code. Drove car twice, short distances, low rpm (not over 3,500). Code returned on second drive -- P0018 -- Removed driver side cam sensor (no shim present). I found a small amount of soot on the side of the sensor near the bottom, but not on the surface that faces the cam plate. I then cleaned and measured sensor as described in the TSB. I then measured the distance from cam cover surface to cam plate in all three locations of the cam plate as described in TSB. Found one measurement to be .002" out of spec. Distance of cam sensor to cam plate should be .049" to .052", my closest measurement was .047", not much, but still. Decided to clear the code now that the soot was removed and drive it again. Drove car as described above, code returned -- P0018 -- I then decided to remove the passenger side cam sensor. No shim was present. Cleaned and measured sensor (exact same as driver side sensor) and measured cam cover to cam plate. It was found to be within spec at .050" I then swapped cam sensors from side to side (intake sensors only). Then cleared the code and drove car as described above, code returned -- P0018 --. At this point I'm planning to purchase the shim kit and use the .002" shim on the drivers side. I'm not optimistic this will cure the problem, but I feel I must do my due diligence to eliminate all possibilities before going into the motor for the cam gears themselves. Urghhh. This sucks, and I know I'm not the only one. I track and know many fellow owners here in So Cal. I'm finding more and more about this problem as it is frustrating for loyal owners/enthusiasts. I will do my best to follow up...
There's just Not Enough Hours in The Day
On Flickr http://www.flickr.com/photos/24663968@N00/ On Instagram XLTimbo Last edited by 10Tim; 07-07-2018 at 06:40 PM. |
#369 |
Drives: BlueBurz
Please do keep us posted. It will be interesting to learn how your shim swap goes. I don't think we've seen anyone here, for whom the shim swap worked. It would be of interest to see your results.
Sent from my SM-G930V using Tapatalk |
#370 | |
Drives: DGM BRZ limited
#371 | |
chicken tonight
BTW, parts of your VVT assemblies are on their way to Belgium to rescue another owner's engine. @faninos ![]()
#372 |
Here for the fun
So, I received the shim kit from Toyota. Shimmed the cam sensor on the intake to be within spec according to the TSB. Erased the code on the ECU and drove the car as described in my earlier post. On second drive cycle the code returned, P0018. I really didn't have high hopes the shim kit would be the answer, but I want to follow proper procedure.
Next on the list is replacing the cam gear. I figure if I'm going to go in there, I might as well replace both intake cams at the same time. I don't want to get a P0016 sometime down the road and be pissed I didn't do both. After that, I'm also fairly certain I will also need to replace the ECU to fully resolve this issue, as that is what I have been reading on this issue. I'm both pissed off and bummed about this whole thing. I take good care of my car and this sucks to have to deal with!
On Flickr http://www.flickr.com/photos/24663968@N00/ On Instagram XLTimbo |
The Following User Says Thank You to 10Tim For This Useful Post: | TheStig85 (07-24-2018) |
#373 | |
Drives: 2013 Subaru BRZ
Sent from my Pixel 2 XL using Tapatalk |
The Following 2 Users Say Thank You to TheStig85 For This Useful Post: | 10Tim (07-24-2018), Ultramaroon (07-25-2018) |
#374 | |
Here for the fun
I know. However my engine only has 26,000 miles, and I'm willing to bet when I pop it open there will be very minimal wear. I honestly believe this is a design flaw and not a wear issue, and I'm trying to minimize cost. However, that being said, I know what you are saying is true and it cuts into me all the more.
#375 | |
The Following User Says Thank You to TheStig85 For This Useful Post: | 10Tim (07-29-2018) |
#376 |
Drives: 2013 FRS DIRTY ASPHALT
#377 |
#378 |
When you swapped the sensors and OCV Did you swap them with the ones right under them or did you replace it? Looking to do this on my FRS I’m pulling up a p0018. Out of warranty here.
P0016 fixable without new ECU? | Mr.Jay | Issues | Warranty | Recalls / TSB | 8 | 02-06-2022 05:15 AM |
P0016/P0017 cause | AVOturboworld | Issues | Warranty | Recalls / TSB | 18 | 04-16-2021 11:09 PM |
P0016 Code | Shady195 | Engine, Exhaust, Transmission | 30 | 02-21-2019 02:31 PM |
p0016 need help asap | lol | Issues | Warranty | Recalls / TSB | 25 | 10-30-2018 03:49 PM |
OFT P0016 and TSB question | mmmcambelsoup | Software Tuning | 10 | 05-24-2017 09:24 AM |
