| Subaru BRZ General Forum All discussions about the Subaru BRZ coupe |
Drives: 2008 audi Q7, 2000 Lexus RX300
finally decided BRZ is the way to go, but got questions.
i know that in theory the cars are 100% identical.
as i wont be going to track, so i dont really care about how aerodynamic the car is or how much it weight i have to shave off by using a lightweight battery or such things. BUT i heard that the 0-60 time of the BRZ is higher than the FR-S/86, is that true ? in real life, what are the differences ? ( not cosmetic differences, im talking about how the car feels, acceleration, handling or anything else. |
#2 |
In real life, the difference is the BRZ has a little more grip and weighs FOUR lbs more than the FRS.
That's it. And if you get the car you'd be doing yourself a disservice not tracking the car. |
#3 |
Drives: 2013 Subaru BRZ Premium, Black
I'm sure the difference which was .2 seconds was simply margin of error with different cars, it's seems pretty normal to see up to 1/2 a second difference between two otherwise identical cars.
I've only driven the BRZ, but everything I read said the only real difference is the FR-Z has a slightly stiffer suspension and is a little more prone to break the rear end loose around corners because of it, I think in the same review I read the BRZ was .2 seconds slower to 60 but still beat the FR-S around the track because of the rear end breaking loose more on corners in the FR-S. |
#4 | |
i dont want to die. |
#5 | |
Drives: Forester 2007, BRZ Limited '13
You've got some pretty good stretches right where you live. Given access to GT86 and BRZ, both will be practically identical acceleration wise, as others stated. Those slightly quicker times in BRZ where on a track, with a driver that LIKED BRZ handeling better. That's it. Personal preference and excitement gets you slightly better time (marginal)
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
#6 | |
![]() and yes haha weve got some nice streets here. we also have a nice track, the dubai autodrome. ive been there once and it looked pretty nice. i might try it but it costs about 200$ for the beginner track. |
#7 |
Drives: BRZ WRB LTD MAN
Track it - it will be the best $200 you ever spent. And you WILL go back! No cops, kids, dogs, or any other distractions just you and the road!
#8 |
Drives: Honda Fit
0-60 times varies from magazine to magazine from 1-3 seconds.
#9 |
#10 |
Drives: Honda Fit
I guess more like 2 seconds. 3 is probably automatic.
#11 |
hmm probably yes.
#12 |
Drives: Honda Fit
Motortrend: 6.4 seconds
http://www.motortrend.com/roadtests/...gti_specs.html R&T: 6.6 seconds http://www.roadandtrack.com/tests/co...premium_page_4 Insideline: 7.3 seconds http://www.insideline.com/subaru/brz...and-video.html
#13 |
Drives: 2013 BRZ-GBS-Lmtd
my own opinion, BRZ is a better daily driver or grand tourer car if that's what you're aiming for.
Has more "luxurial" options available. With that said, it is very hard to pick between the two. It will be down to what amenities you want inside "out of the box".
#14 | |
White Paper Connoisseur
Drives: 2008 VW Jetta
2003 Toyota Corolla
2003 Toyota Corolla 2009 Mazda RX-8 R3 2008 VW Jetta Wolfsburg ??? |
#15 | |
#16 |
Spaceman
Drives: 2013 Firestorm Scion FR-S
I don't know about Dubai but in the UK the Toyota has the additional niceties while the BRZ is more basic. This may lead to their BRZ being 4 lbs lighter.
Sent from my Galaxy Nexus using Tapatalk 2
#17 |
Drives: Honda Fit
4 lbs lighter is the US spec car, I didn't know he was in Dubai.
#18 | |
#19 | |
Gangnam Style Guru
Drives: Suzuki GSXF650, WRB BRZ
#20 | |
Drives: 2009 135i
#21 |
Drives: 2006 Evo IX SE
The difference is negligible and could be due to a number of factors. As others have pointed out, different tests of the FR-S have yielded varying times, and the same thing applies to the BRZ, so it would certainly be the case when comparing the FR-S to the BRZ. But realistically speaking, even the same driver in the same car won't get 100% consistent numbers back-to-back, especially when you're dealing with a car that has a manual transmission and no launch control. Don't worry about it.
| FR-S NAV Questions | Dan86 | Electronics | Audio | NAV | Infotainment | 6 | 07-01-2012 01:24 PM |
| Questions | Do Boy | Engine, Exhaust, Transmission, ECU | 4 | 06-22-2012 01:33 PM |
| On the fence... (but nearly decided) | eriktherod | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 05-30-2012 03:45 AM |
| Questions regarding FRS Pre-order | ft86Fan | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 04-21-2012 01:42 PM |
| I think I've decided on the the Tint | SeattleBoy21 | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 03-30-2012 01:46 PM |
