04-14-2018, 06:37 PM | #939 |
Reminds me of a back-in-the-day story .....OK, what doesn't .....
It was a hot August day, back on the farm, and the crops had been laid by ......so, I had some free time to work on my built car. I had cleaned and gapped the spark plug, so I pulled er out on the paved road in front of the farm, to see how it ran. I had just got it wound up in high gear, when the steering wheel just spun around and the wheels stayed straight. Understand that the steering on my machine consisted of a steering wheel attached to piece of water pipe, that two lengths of 2x4 were attached to. An old (apparently rotten) piece of clothesline was wound around the box on the steer mechanism, and led through a couple of pulleys down to the front axle, which would turn when I turned the wheel (most of the time). Here I am, going full speed (maybe 30 MPH) going down a straight road when, you guessed it, a car came from the other direction ....... The steering rope apparently broke and I was out of control. What to do ..... I hit the brake ...... right? ....... wrong move! The hand brake only worked on the left rear wheel ...... which, when applied, pulled my machine off to the left ....... in the path of the oncoming car ....... Well, the other car slowed down and I zoomed off of the road into the ditch in front of it. The fellow stopped and ask me if I was OK. I was so embarrassed when I had to push my "car" back down the road into the barnyard ....... THE END humfrz |
04-15-2018, 08:36 AM | #940 |
Only happy when it rains.
Drives: series.blue
wow that sucks. Glad you are ok and you figured out what happened.
But 2280 pounds! That is not much heavier than my Yaris. That is amazing. |
04-16-2018, 06:24 PM | #941 | |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
The Following User Says Thank You to Anthony For This Useful Post: | humfrz (04-16-2018) |
04-16-2018, 09:44 PM | #942 |
Wise old man
Drives: 86 GTS
I am glad you are ok, and that the damage is non fatal.
Seems we are having a bad run recently. i blew my 3rd motor on the track and havent had the pleasure of my car since march 20.. at the end of the day its still cheaper than 5 years of payments for a 911 isnt it.. |
04-18-2018, 08:49 AM | #943 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Anthony have you looked into this Chase Bays Brake Boost eliminator? Its hard to find info of anyone using it but it could save anywhere from 10-50lbs if you removed ABS according to the site. And the weight would come from that front driver side where you need to lose most.
https://www.chasebays.com/products/c...nt=33631463497 |
04-18-2018, 10:22 AM | #944 | |
Weight Nazi
05-15-2018, 12:20 AM | #945 |
Drives: '88 Supra 1JZ, '16 FR-S, '23 GR86
glad to see the numbers finally.
What's next from here? what else can you do? Brake mod would be good, but Dry carbon doors are expensive. Swiss cheese?
NARFALICIOUS
Noob Poster 1988 | 2016 |
06-10-2018, 03:17 AM | #946 | |
Weight Nazi
My thoughts, exactly. You can't blame me by celebrating my victory with a fun little drive-right-into-a-pole. <3
I'm at the mercy of USAA, and so far, them dudes is dumb. So dumb, I installed a phone call recording app so that I might play back their self contradictions to themselves, that I might seem not as insane as I guess I have been - to them - lately. Y'ever seen the BME Pain Olympics? I can do a lot. Quote:
Swiss cheese = master cheese.
06-10-2018, 02:14 PM | #947 |
義理チョコ
How did I miss this? Super glad you're ok. While typing, I just reviewed your signature quote. Disturbingly relevant.
06-10-2018, 03:58 PM | #948 |
Weight Nazi
The Following 2 Users Say Thank You to Anthony For This Useful Post: | korhun (06-29-2019), Ultramaroon (06-10-2018) |
07-10-2018, 09:18 PM | #949 |
Drives: 2017 Halo 86
Holy crap, nearly 30 lbs for the front and rear bumpers. I'm totally doing that.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
The Following User Says Thank You to Lakitu For This Useful Post: | Anthony (07-11-2018) |
10-26-2018, 02:50 PM | #950 |
This thread is awesome. Can't believe I just discovered it.
11-16-2018, 08:28 AM | #951 |
Drives: they all have 4 wheels
read all 69 (hehe) pages of this! great job with the build. sorry about the crash. maybe if the inusrance money clears, might as well go full blown track car?
11-16-2018, 03:18 PM | #952 |
Drives: 2013 WRB BRZ 6MT
Seems there is a string of bad luck for some of us lately. I reversed into a brick wall causing about 12k in damage.. total fuckup on my part, paniced while backing out and slammed throttle.. thankfully they are covering it.
Tags |
mother fu(king winning! |
