Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-27-2018, 11:50 AM | #1 |
Drives: dark grey metallic Toyota 86 MT
IRP short shifter rattle fix
Very simple fix but may need regular replacement.
1. Remove the shifter trim and boot. 2. Locate this part, which is the “cable stop” for the reverse lock out and apply insulation. I used felt covered vinyl cut to size. 3. Stuff the cavity of the center console. Add up to what you feel is enough and still able to return the shifter trim and boot. My first attempt shifted the rattle to 5k rpm. After adding a little more foam I achieved significant reduction. Very minimal rattle to none at all. I also installed the free anti rattle kit but that alone was of little or no help for me. Disclaimer: not guaranteeing anything and proceed at your own risk
The Following User Says Thank You to andrewFT86 For This Useful Post: | JimmyMac (04-06-2018) |
04-03-2018, 11:06 AM | #2 |
IRP RATTLE FIX
[ame="http://youtu.be/PSp4URdI7gY"]https://youtu.be/PSp4URdI7gY[/ame]
The Following User Says Thank You to andrewFT86 For This Useful Post: | XCO (09-24-2018) |
04-03-2018, 11:30 PM | #3 |
Drives: 2013 Scion FR-S 10 Series
I don’t have the Individual Racing Parts shifter, but have always been interested in it. The issue with rattling was definitely a negative, so I appreciate your post and video. Overall, what are your thoughts on the product and would you recommend it?
04-04-2018, 04:33 AM | #4 | |
When it was new the rattle was not an issue. The rattle came out after about 3 months and was present at 3000 to 4000 rpm. NVH definitely increased; road noise, drive shaft and the rattle because installing the IRP required removing all of the insulation of the stock shifter leaving an (almost) open hole in the cabin. From stand still, 1st and 2nd gear can be difficult to engage but I think it will be solved after some adjustment (pic: part marked red). The shifter can get warm with regular driving and more so when car is parked under the sun. It does cool down quickly and has never been too hot to use. Will I recommend it ? Definitely The only thing I regret is getting it right away because the newer one with the reverse lock out button would probably match my current interior better. As is, I'm still very happy.
The Following User Says Thank You to andrewFT86 For This Useful Post: | RJasonKlein (04-04-2018) |
04-04-2018, 07:48 PM | #5 |
How hot does it get where you live? Here it commonly goes above 100F in the summer, and our summers are long
04-05-2018, 01:23 AM | #6 |
It's almost perpetual summer here and 90-100F is the afternoon temp range. We can hit around 104 but not often.
04-06-2018, 12:23 AM | #7 |
04-06-2018, 01:33 AM | #8 |
Drives: Q5 + BRZ + M796
If i had this shifter, and the rattle was coming from shaking of the entire assembly then I would probably drill some holes and add some lateral springs.
04-06-2018, 02:56 AM | #9 | |
04-06-2018, 03:49 AM | #10 |
04-20-2018, 04:08 PM | #11 |
Drives: 2015 scion FR-S
I've had this shifter for about 4 months. I've got the same buzzing sound also. Today I took it apart after I saw this and found that the 4 allen screws that hold the base to the shifter had come loose. I put some lock tight on them. It seemed to make it quiet it down a bit. But I drove it without the center console in and held onto things as it was making the sound and mine is definitely coming from the button. But even holding the button does not make it go away.
07-06-2018, 07:55 AM | #12 | |
01-30-2020, 10:12 AM | #13 |
Drives: 2015 FRS
Any update on this topic everyone? I love my shifter and I can never go back but this rattling issue, after doing everything that everyone suggested including insulation, still there above 4k rpm, at least 30% of it...
02-02-2020, 05:11 PM | #14 |
Drives: 2018 BRZ
I’m very interested in one also, but not if it rattles.
Similar Threads | ||||
Individual Racing Parts (IRP) V3 Short Shifter Rattle Thread | Shadow_ | Tracking / Autocross / HPDE / Drifting | 50 | 08-15-2023 10:56 AM |
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing | bergy | Transmission and Driveline | 8 | 10-20-2016 09:57 PM |
TRD short shifter rattle fix | morrisonmagic | Engine, Exhaust, Transmission | 2 | 06-01-2016 10:30 AM |
kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 01:41 AM |
TRD Short Shifter Quick Shifter Scion FRS | hirollaz | Transmission and Driveline | 3 | 04-15-2014 01:24 AM |
