01-19-2018, 06:07 PM | #57 | |
Drives: 2013 WRB BRZ 6MT
For track driving, the drilled vs non-drilled argument mostly comes down to economics if you ask me. You can run a set of iron rotors that cost you $200 per set or you can run the fancy, expensive carbon ceramics that cost you $2000 per set. People who can afford the likes of a the GT3 RS or the 488 can also afford the expensive rotors. It's not inherently unsafe to run drilled disks but people who track their cars wear though consumables very fast and "shits expensive yo" so we want to get the most bang for our buck. Not only are drilled and slotted more expensive than blanks but drilled rotors in particular will require replacement sooner than just slotted or blank. Over a year, it might only be $100 difference but over 5 years, that ads up to $500 and you could buy a header with that money... or more track time.. or other consumables... |
The Following 4 Users Say Thank You to Lynxis For This Useful Post: |
01-19-2018, 11:55 PM | #58 |
Grip>Drift
Drives: FRS
lol obviously I looked closely.
The Following User Says Thank You to BlaineWasHere For This Useful Post: | cjd (01-20-2018) |
01-26-2018, 12:34 PM | #59 |
I read through this whole thread, but I didnt see my wheels specifically.
Will this kit fit RPF1s 18x9.5 +38? |
01-30-2018, 12:16 PM | #60 |
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
the 17x9 are horrible for caliper clearance. They use a design trick to keep weight down. The barrel is from a 16" wheel thats tapered out. The spokes are from the 17' +35 wheel which has a flat face for the brakes. The combination of the two means the 17x9+35 RPF1 suck for BBK.
The Following User Says Thank You to mjanmohammad For This Useful Post: | DAEMANO (02-16-2018) |
02-15-2018, 11:24 AM | #61 |
Drives: 2017 series yellow BRZ
Enkei Raijin 18x9.5 +45 fitment
I am running fortune auto coilovers but does anyone know if the 18x9.5 +45 enkei raijin squared setup will clear the pp bbk's because these are my favorite wheels right now and do not want to waste money. Thanks
02-15-2018, 11:25 AM | #62 | |
For which wheel?
02-15-2018, 11:28 AM | #63 |
02-15-2018, 11:29 AM | #64 |
I know the 18x8 clears without a problem. I can’t imagine the 9.5 wouldn’t but I would call Enkei and confirm with them.
02-15-2018, 11:31 AM | #65 |
Why would you believe it wouldnt just wondering becuase i know the 8.5 fits but i want the squared setup, but do the rpf1 18x9.5 +38 clear? I appreciate the help
02-15-2018, 11:34 AM | #66 | |
The 18x8 squared setup in the Raijins clear the Brembos. Unless you have FI, you really don't need to be wider than that.
02-15-2018, 11:47 AM | #67 |
Call Enkei and confirm the 9.5s fit then, we don't know very much more than you do here.
02-15-2018, 12:07 PM | #68 |
I messaged enkei and the 18x9.5 +45 does not clear the front brake caliper but a 18x8.5+45 will
02-16-2018, 01:35 PM | #69 |
wheel fitment question
i think option labs r716 18x9.5 +35 will fit the bbks but can anyone confirm this?
02-16-2018, 05:12 PM | #70 |
Drives: 18 BRZ tS, 27 GRMN 86
Anyone know if the SA10R 18x8.5+45 would clear or not?
Never mind, it clears! Last edited by botbs; 02-18-2018 at 11:53 PM. |
Similar Threads | ||||
2017 BRZ Performance Package Brembo Brakes Part Numbers | Veloist | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 146 | 04-27-2023 09:36 AM |
Real STI BREMBO package upgrade - DIY | Trap63 | DIY (Do-It-Yourself) Guides | 40 | 06-15-2022 09:25 PM |
Will The Brembo BBK of the Performance Package BRZ fit into the wheels of Series Blue | DaJo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 09-25-2018 05:12 PM |
To get the Performance Package or Not? Thread | Zaku | BRZ First-Gen (2012+) -- General Topics | 141 | 12-06-2016 10:04 PM |
Someone tested the Performance Package... small but SOME info at least | ~el~jefe~ | BRZ First-Gen (2012+) -- General Topics | 13 | 11-29-2016 04:21 PM |
