Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
09-30-2017, 09:35 PM | #1 |
Drives: 2013 Scion FR-S, 2014 Audi S4
I messed up, can someone help me identify this part?
I ordered some Bilstein B6 shocks a few months ago along with some other suspension stuff, managed to install the 2 fonts and one of the rears before I had to head home to England for a few weeks. Flew back to Houston the day Harvey touched down and my house flooded, the last shock was in its box on the floor in the garage and it was drenched. I took the shock out and threw the box away. Anyway, went to install it today and, low and behold, I had also thrown away the part in the picture.
I thought this would be a spring perch but a Google search brings up nothing. Does anyone know what the part is or even the part number so that I can finally finish up the suspension install. The car hasn't moved for like 2 months, it would be great to drive it again! |
09-30-2017, 09:46 PM | #2 |
Drives: '13 FRS - STX
Looks like a spring perch to me. You'd have to call Bilstein directly to get a replacement I'd wager, I don't think there's a part number you can just press order for. Maybe tire rack as they sell the dampers individually? I'd be dumpster diving...
Edit: rereading your post, that's the spring perch for your last damper, you didn't throw it away it's right there. The other one is on the car. Derp. |
09-30-2017, 10:07 PM | #3 |
I pulled it from the installed shock because I messed up and hadn't installed the bump stop, the car hasn't been driven since the install and the spring has a rubber tube on it so it looks new. I actually bought the shocks from Tire Rack so I'll give them a call, ermmm, e-mail...
The Following User Says Thank You to UFO For This Useful Post: | strat61caster (09-30-2017) |
10-01-2017, 11:42 PM | #4 |
Drives: 2016 BRZ
How much did you pay for those struts? I've just found that one of my rears is leaking, from what I've seen, any aftermarket struts seem to cost about as much as a set of coilovers.
PS. Where in England are you from? I live in near Cypress, originally from Leeds but grew up in Humberside. |
10-02-2017, 12:00 AM | #5 | |
https://www.tirerack.com/suspension/...3&autoModClar= I'm a Northern boy too, from Manchester and living in Katy now. I hope Harvey was kind to you! |
10-02-2017, 11:01 AM | #6 |
Make sure you don't install the rear spring perches upside down.
- Andrew |
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | strat61caster (10-02-2017), Tcoat (10-02-2017) |
10-02-2017, 01:53 PM | #7 |
Site Moderator
Drives: Stuff
Might have to call Bilstein for them. Explain what happened and they may just ship one for free/cheap.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
The Following User Says Thank You to Dave-ROR For This Useful Post: | wparsons (10-02-2017) |
10-02-2017, 03:10 PM | #8 |
The Following User Says Thank You to UFO For This Useful Post: | Racecomp Engineering (10-02-2017) |
10-02-2017, 03:12 PM | #9 |
Nah, they just gave me a part number of E4-FT2-Y026A01 which the local distributor couldn't locate. Guess I'll have to call back and spend another 30 minutes on hold as I probably wrote it down wrong. That's what I get for being a dumb arse!!
The Following User Says Thank You to UFO For This Useful Post: | strat61caster (10-02-2017) |
10-02-2017, 03:57 PM | #10 |
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post: |
10-02-2017, 05:39 PM | #11 |
10-02-2017, 06:07 PM | #12 | |
And this And sorry I posted a misleading photo, a few people have flipped the spring perches and put on lowering springs at the same time and complained about sitting too high off the ground, maybe because of this exact picture... |
The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Racecomp Engineering (10-02-2017), UFO (10-02-2017) |
10-02-2017, 07:28 PM | #13 | |
Thanks for the help. |
10-02-2017, 08:35 PM | #14 | |
The bumpstop thing is not clearly stated in instructions and there is miscommunication about it online based on misinterpretation (Bilstein claims 'internal bumpstops' on their struts, which is true (and isn't super complicated if you want to know more, but it sounds fancier than it is), but the rear damper is not a 'strut' on the 86 and needs the bumpstop in the same configuration as OEM) The spring perch is more of a 'common sense' thing, but it looks like they've updated their documentation with much better pictures, see page 4 of this PDF which you can get off Bilstein's website here https://productdesk.cart.bilsteinus....M5-Y437A00.pdf |
The Following User Says Thank You to strat61caster For This Useful Post: | UFO (10-03-2017) |
Similar Threads | ||||
Messed up downshift - how bad did i fuk up ? | WGMGR | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 11-05-2015 01:55 PM |
Help me identify this part! | ATESIX | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 07-14-2015 07:50 AM |
I messed up | tmcmullins | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 04-11-2015 07:45 PM |
So the dealer messed up... | koolhawk | BRZ First-Gen (2012+) -- General Topics | 26 | 06-18-2012 08:19 PM |
Messed up? You decide. | Godzilla35 | Scion FR-S / Toyota 86 GT86 General Forum | 66 | 05-15-2012 02:20 PM |
