Old 08-25-2017, 04:26 PM   #1
Shit Luck
Drives: red frs
Swap issue: No starter trigger
So I am swapped.
Standalone to run engine, canbus is integrated.
I used the factory harness for everything else, but I get no starter when I turn the key.
Anybody have any ideas?
Shit Luck is offline   Reply With Quote
Old 08-25-2017, 04:30 PM   #2
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
What are you using to trigger starter?
Edit:
That is the thick white/blue wire used to trigger the starter. That is directly attached to the ignition switch (well sorta). You don't need to do anything other than plug it on to the starter solenoid.
If you are looking for "Switch Power" for you harness. You can use that grey wire to power a relay as the trigger wire.
Okay, Found my ignition source wire. I am going to run a relay (possibly Fan relay 2 that I removed earlier) to power the Ignition source for GM harness. Using the Grey C/Open relay trigger wires (IG2) to trigger ignition relay.
If you follow the Grey wire that comes from IG2 and C/Open relay it leads to the ECM ignition switch wire (from what I understand that is what it is on the ECM). This is the end of wiring for my swap until the MRS Device arrives.
Edit: Hoping this didn't come across as harsh, just not wanting you to hurt anything.
Old 08-25-2017, 04:39 PM   #3
Shit Luck
Drives: red frs
I am not sure what you are asking.
The entire body harness is bone stock, so the factory relays and stuff.
Old 08-25-2017, 04:40 PM   #4
DustinS
DustinS's Avatar
So factory Starter trigger wire then. White with blue tracer?
Old 08-25-2017, 04:48 PM   #5
Shit Luck
Drives: red frs
I have seen these write ups.
I intentionally left the stock harness intact to keep it looking factory and make the wiring easier.
Old 08-25-2017, 04:49 PM   #6
Shit Luck
Drives: red frs
Yup it's all factory.
Like I said all I have done is unplug the engine harness at the main connector.
Old 08-25-2017, 04:50 PM   #7
DustinS
DustinS's Avatar
Should just be able to use the factory trigger wire then. So thick white wire, blue tracer. Will be covered with the black plastic wire loom cover with grey electrical tape. Has a female spade connector on it if I am remembering correctly. Make sure clutch is down when starting as well
Old 08-25-2017, 04:56 PM   #8
Shit Luck
Drives: red frs
Yeah it doesn't trigger...
Old 08-25-2017, 05:06 PM   #9
DustinS
DustinS's Avatar
Manual or AT car?
Old 08-25-2017, 05:08 PM   #10
Shit Luck
Drives: red frs
Manual or AT car?
Manual...
I am thinking some how the immobilizer is involved.
Old 08-25-2017, 05:10 PM   #11
DustinS
DustinS's Avatar
Base FRS Right? Can't tell from your instagram lol. Don't think Base FRS had an immobilizer
Wiring Schematic
Page 86 has the starter system wiring. Triple check everything there. Really weird.
If you don't have the factory ECU hooked up, it won't work either.
Old 08-25-2017, 05:11 PM   #12
Shit Luck
Drives: red frs
Yeah it's a base 2013
Old 08-25-2017, 05:14 PM   #13
Shit Luck
Drives: red frs
Wiring Schematic
I have the factory ecu but not the injector driver that was on the engine.
Old 08-25-2017, 05:15 PM   #14
DustinS
DustinS's Avatar
Injector driver shouldn't matter
Starter swap? Wil Engine, Exhaust, Transmission 1 07-27-2016 07:50 AM
Pulled the trigger... Stewie BRZ First-Gen (2012+) -- General Topics 1 01-01-2015 02:16 AM
Help about to pull the trigger.... JerryMichaels7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-25-2014 06:12 PM
6 MT Swap, Complete: Transmission,Starter, Flywheel, Clutch, Driveshaft, Pedals, Hydr ecda Transmission and Driveline 2 01-30-2014 10:45 PM
Just pulled the trigger Trobinson CANADA 5 04-08-2013 10:48 PM
