Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-18-2017, 10:32 AM | #15 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
In which direction is the jerk?
If car jerks forward (you get pushed into the seat), give less RPM when you shift. If car jerks backwards (you get pushed forward), give more RPM when you shift. |
05-18-2017, 10:39 AM | #16 | |
Drives: Subaru BRZ
Another thing that helps is cupping the gear knob with your hand, for 1st and 2nd palm facing away from the driver (if driving a RHdrive car) and when moving to 3rd, 4th etc then palm towards the driver (if driving RHdrive car). This helps to place subtle pressure on the gear knob helping to move the lever to the correct plane ready for next gear. |
05-18-2017, 10:48 AM | #17 | |
The Following User Says Thank You to Tcoat For This Useful Post: | JD001 (05-18-2017) |
05-18-2017, 11:24 AM | #18 |
A.K.A. Starlord
Drives: 2015 Series.Blue
One simple thing I want to add. When driving normally, you can shift smoothly with no jerking. When driving spiritedly, you can still shift relatively smoothly with no jerking.
However, when you're driving balls out, you don't really have time for "smooth shifts." If you really are talking about just balls-out, full-throttle acceleration through 2nd gear, then you kinda-sorta do just aggressively move the shifter from 1st to 2nd (no need to SLAM it into 2nd, but just a very quick shift), and then you don't quite POP the clutch, but almost. You get a chirp from the wheels because you are NOT rev-matching, and are instead allowing the drive-train to aggressively slow the engine. Just wanted to point that out. After a certain point, shifts ARE violent by the nature of what you're trying to accomplish. However, 99% of the time you're driving the car, if your shifting is violent, you're doing it wrong.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
The Following 3 Users Say Thank You to Stang70Fastback For This Useful Post: |
05-18-2017, 11:31 AM | #19 | |
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | meWant (05-18-2017), strat61caster (05-18-2017) |
05-18-2017, 11:42 AM | #20 |
Drives: Subaru BRZ
I think we are now slowly creeping into race car areas.. Taking your DD on to the track and crashing through gears is not a good thing if your are mechanically sympathetic and want to drive your car back home.
A street car is not a race car and obviously a race car is not a street car and the mechanics reflect this. |
The Following User Says Thank You to JD001 For This Useful Post: | Tcoat (05-18-2017) |
05-18-2017, 11:57 AM | #21 | |
The Following 6 Users Say Thank You to Tcoat For This Useful Post: | Icecreamtruk (05-18-2017), JD001 (05-18-2017), spike021 (05-18-2017), strat61caster (05-18-2017), Turdinator (05-18-2017) |
05-18-2017, 12:12 PM | #22 | |
Except I also stalled like 3 seconds later for the first time in 2-3 weeks! Shit happens! |
05-18-2017, 12:14 PM | #23 | |
For me personally I learned to drive using cars that had ATs. It was quite the change getting used to shifting for me but it's not an unbreakable barrier by any means. |
The Following User Says Thank You to spike021 For This Useful Post: | JD001 (05-18-2017) |
05-18-2017, 12:20 PM | #24 | |
The only place that comes to mind is on a drag strip, where you are racing another car just like yours ....... and just how many times is that going to happen .. ?? In that case, you have won or lost the race coming off the line .... before you even shift out of first gear ...... humfrz |
05-18-2017, 12:27 PM | #25 |
Drives: '17 86
I had a similar question a few days ago and @VTEC answers it pretty well.
If you shift from first to second as fast as possible, the engine doesn't have enough time to slow down and your wheels will spin when you drop the clutch in second. I don't think he means jerk as in engine rpm is too low for second. |
05-18-2017, 12:58 PM | #26 | |
EDIT! I just reread it and what I read first time around as "If I let drop" is actually "If I DON'T let drop" so yes @VTEC had the right answer! I feel so foolish now. What I said before still applies though since either revs too high or revs too low both will give you issues. Need to get all the parts of the shift together for it to be smooth.
05-18-2017, 01:08 PM | #27 | |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
But after driving cars for 16 years now i can drive both just fine.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
The Following User Says Thank You to Xxyion For This Useful Post: | spike021 (05-18-2017) |
05-18-2017, 02:13 PM | #28 |
Drives: 2017 BRZ
Yes, VTEC understood me correctly! Thanks guys
Similar Threads | ||||
Aggressive brz's | ScoobySubie14 | BRZ First-Gen (2012+) -- General Topics | 22 | 01-30-2016 06:05 PM |
Mercedes E55 AMG...Fast..but not fast enough. | gdrider77 | FR-S / BRZ vs.... | 18 | 08-28-2014 03:56 PM |
What would you say is more aggressive? | TomT2411 | Engine, Exhaust, Transmission | 16 | 05-08-2014 05:40 PM |
Fast car Fast driver vinyl decal I need help | francosolracer | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 10-20-2012 03:43 AM |
shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 05:09 PM |
