Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-04-2017, 02:12 PM | #57 | |
Drives: 2014 Scion FR-S Monogram
I plan on in the next month having a full header back performance exhaust, running E85 on the OFT UEL stage 2 E85 tune, and potentially lightweight wheels to make the most of the power. Is there any testing you guys have done with any difference your intake will make on a setup like this?
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
The Following User Says Thank You to Detroiter For This Useful Post: | Somerandom18 (04-04-2017) |
04-05-2017, 10:46 AM | #58 | ||
Assuming these pressure losses are small (they're pretty small, I haven an entire article on here outlining them from start to finish), and ignoring the effects from air being compressible (those are super small), the difference in velocity and temperature at the beginning of the intake tube, and at the throttle body is going to be pretty much the same, especially on an appreciably short intake tube. So assuming that having the MAF closer to the throttle body means the amount of air that is sensed is somehow more accurate to what is about to go through the throttle body, or that you could sense the time change really doesn't have any merit. And the non-existent benefit is easily outweighed by some of the negative effects that having the sensor that close to the throttle body can sometimes show. But I have no doubt what you're feeling as a difference is actually a difference. What you perceive might be a gain or a loss in an area that you usually drive in, or a general (albeit small) reshaping of the power curve. Our it could have something to do with the funky MAF curve of that particular intake. As much as people really like to put down intakes here and say they do absolutely nothing (despite all of the testing shown that shows otherwise, and no testing that shows the opposite) a well designed intake like ours is increasing your power output to the ground by 6%. That's significant enough to feel for most people. My favorite argument is the "don't buy an intake, just buy a drop in filter. You get half the gains for a sixth of the cost." And then people will go out and buy an exhaust that gives them half the gains of an intake at 3 times the cost Quote:
The most erroneous argument I see about intakes is: "If you can flow more air in, but can't flow more air out, the intake isn't going to work." Intakes don't flow more air in. The engine isn't all of the sudden positive displacement because an intake was added. But when you decrease restriction, you will decrease pumping losses, friction, etc, and the engine doesn't have to work as hard to inhale, which makes it more efficient. So you might have to do a little more digging, but you can not go wrong with any sort of decrease in restriction when you're going for power production, and every little bit counts. Chase Engineering |
The Following 5 Users Say Thank You to GrimmSpeed For This Useful Post: | Detroiter (04-05-2017), guybo (04-05-2017), Hawk77FT (08-30-2017), leets4uc3 (04-05-2017), mgarcia707 (12-14-2018) |
04-05-2017, 11:20 AM | #59 |
Huge E85 fan!
Drives: 2016 Scion FRS
Chase, you need your own Q&A sticky thread. I'm not even kidding. I'd love if you had a dedicated intake Q&A thread. This is good stuff TY!
The Following 5 Users Say Thank You to guybo For This Useful Post: | Detroiter (04-05-2017), GrimmSpeed (04-06-2017), Hawk77FT (08-30-2017), jono_l (04-09-2017), Yardjass (04-05-2017) |
04-05-2017, 11:30 AM | #60 |
I second this
The Following User Says Thank You to Detroiter For This Useful Post: | GrimmSpeed (04-06-2017) |
04-05-2017, 11:43 AM | #61 |
Drives: '14 Monogram, '95 Miata, '90 300ZX
This is why I buy Grimmspeed stuff. As an engineer myself, I like to buy products from people that actually put the time and effort in to do this sort of development rather than just throwing something together that fits and calling it good. TBH, I'm also a little jealous you guys actually get to use what you learned in school and I like getting to live vicariously through those who document that sort of stuff online. I guess what I'm saying is keep "showing your work". We all enjoy it.
The Following 2 Users Say Thank You to Yardjass For This Useful Post: | GrimmSpeed (04-06-2017), sroby (07-07-2020) |
04-05-2017, 12:23 PM | #62 |
Drives: UK GT86
Apples to oranges. The change in filter/type of intake will of course change the airflow through the intake, having a large cone filter may well aid velocity and therefore give you the "response" change. If you could move the MAF sensor around the OEM intake, as such the readings aren't thrown off too much by turbulence or bends, there would be no perceived change in power or response no matter what the placement.
.: Stealth 86 :.
08-27-2017, 09:42 PM | #63 |
Drives: 10 Series
D Sport Magazine did 300+ dyno runs and proved there are gains with a tune. Some appear almost worth the gains for the money and can focus in on the mid range torque. Does anyone know how the intakes dsport tested compare to the Perrin long tube?
http://dsportmag.com/the-tech/scion-...ing-ecutek/10/ |
08-30-2017, 11:14 AM | #64 |
THE CORVETTE KING!
Drives: 2013 FR-S, and 2016 FR-S!
There is no gain in doing an intake. It has been proven ad nauseum.
2013 Scion FR-S.
2005 Corvette. |
The Following 2 Users Say Thank You to meadowz06 For This Useful Post: | Tcoat (08-30-2017), tennisfreak (01-09-2018) |
08-30-2017, 11:30 AM | #65 |
Drives: 2017 manual BRZ
Sucks that the Grimmspeed intake isn't on that graph..
Sent from my Pixel XL using Tapatalk |
08-30-2017, 12:13 PM | #66 |
Drives: 2013 Firestorm FR-S
I've got the Blitz and can say it sounds amazing on WOT.
01-08-2018, 11:00 PM | #67 |
Drives: 2017 Brz
Looking to upgrade intake filter with the HKS super hybrid filter and maybe a intake tube. Not sure about the sound tube deletes since they dont seem to be reinforced by wire and those videos of the intake pipe collapsing under load are surprising...so, Is there any difference between the AVO intake tube (silicone reinforced with wire with a silicone sound tube too) and blitz/cusco/hks intake tube(all looks the to be the same aluminum pipe with couplers just different price)? HP, sound, anything? any pros or cons vs the grimmspeed or perrin CAI?
01-09-2018, 10:23 AM | #68 |
Drives: '15 GT86 & '22 GR86
Ok so I thought I’d add my experiences on intake for this platform.
Bought my car new back in 2015, fitted a Cosworth panel filter and silicone intake hose after a couple of thousand miles, slight increase in induction note and the car felt like it had a little bit more poke. Within a couple of months I got used to it and completely forgot about it (happens with small gains). I ran this setup until mid 2017 then fitted a Grimmspeed intake. A lovely bit of kit, and looked great once fitted. The car ran as smooth as it did before, proving the engineering design was sound. I noticed no difference at all in terms of power or response. I primarily wanted it for the extra induction noise anyway so wasn’t too concerned but you could barely hear it. A little bark at 4k then the sound will fade away. I imagine if i ditched the stock snorkel i would of got a bit more noise. Intake temperatures were noticeable higher than the stock setup according to torque pro, it would soak heat quicker for longer. Sold it after 2k miles. So yeah what everybody says is true, fit a panel filter and intake hose and be done with it. |
01-09-2018, 11:16 AM | #69 |
Drives: 2018 BMW M240i
Best option? Stock
Use the money elsewhere. |
The Following User Says Thank You to tennisfreak For This Useful Post: | humfrz (01-09-2018) |
01-09-2018, 11:40 AM | #70 |
If you really want an intake go Grimmspeed.
Similar Threads | ||||
Crawford Power Blocks on 2017 aluminum intake? | Var | Engine, Exhaust, Transmission | 28 | 06-26-2020 05:47 PM |
BRZ 2017 Aluminum intake! MT6 | GsxrMe | Forced Induction | 27 | 07-23-2017 12:17 AM |
2017 intake manifold | oldgunfan | Engine, Exhaust, Transmission | 27 | 02-15-2017 04:48 PM |
2013 intake manifold vs 2017 Aluminium intake manifold | Bobster | Engine, Exhaust, Transmission | 29 | 12-19-2016 10:40 AM |
WTB: SOCAL 2017 Stock Intake | swarb | Want-To-Buy Requests | 0 | 10-20-2016 10:08 PM |
