| Engine, Exhaust, Transmission, ECU Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
#45 |
Drives: 2000 MR2 Spyder
Wait, aren't all cars distributorless ignition these days?
#46 | |
NINJA MODERATOR #2
Drives: 87 FC3S TII
My experience..its pretty easy to throw around numbers, but when you start to get to the nitty gritty and start modding...things start to get hazy. Then you start fighting with yourself about feeling and compromise rather than doing whats necessary for a p:w ratio of 10. By then you've turned your beloved car into a monster, and as much as we love a beast of a machine..you cant really fall inlove with it anymore.
#47 |
NINJA MODERATOR #2
Drives: 87 FC3S TII
im pretty sure they are... at least in areas that are not 3rd world countries
#48 | |
Inverse Animosity
Drives: Celica GT-S
My Celica is being modded to be close to that-- hopefully 240hp @ 2,350lbs for 9.8. I don't feel like i wont love it anymore-- it's my first car and i'm making it into a car i can take to HPDS, not some kind of Frankenstein Nurburgring Beast.
![]() Inverse Animosity- These words codify my declaration of deference, and indemnify myself from the counter-progressive nuisance of biased judgment, ridicule and criticism based on discrimination such as driveline, engine size, pre-established dogmas, preconceptions or any such trivial nonsense. |
#49 |
Drives: Silver AT Limited
I'm hoping somewhere around 200-230 whp with a super charger + i/h/e + tuen to keep things linear.
#50 |
Drives: First SWP BRZ-L
false. Ran a catted nameless header for a week, and a track day. zero CELs. 6 hours of datalogging all came back positive.
The car will take a header without a tune no problem. the catless header has done 60 miles so far without a CEL as well. I'm planning on road testing that for a while and seeing if any CELs pop up over time. oh and. my goals are 200~ whp. I think that would be perfect for this car without disturbing the balance too much. Plus... I'm pretty close to those goals already. ![]() (I already did the high horsepower thing with my WRX. it's really not that much fun after a few years, once you realize it makes the car really boring on the streets)
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
#51 |
Drives: 2013 Scion FR-S | 1991 MR2 Turbo
My goal is +0 HP. I just want to keep the car as clean and stock as possible for as long as I have it. For aesthetics, I might add some of the dealer approved intake/exhaust parts if they provide a more rich engine sound (nothing too loud or obnoxious). I can't help feeling that I'd just ruin this car if I equip it with a turbocharger, mess with the tune, or build the motor etc
Maybe I'll wait to see what higher performance versions they produce over the years. I honestly wish I had two of these cars. This one to keep stock, and the other to make a project out of. I guess that's what my MR2 is for, heh.
2013 FR-S | 1991 MR2 Turbo
#52 | |
NINJA MODERATOR #2
Drives: 87 FC3S TII
but in reality, im looking at finding 90whp to get to the 250hp goal. getting almost 100hp (90whp) additional out of a 2.0 4cylinder in the past has been pretty ambitious..and even required some engine builders to compromise streetability for performance. then we have the chassis. Now this car is not exactly heavy. Sure we think 2800lbs is nothing new and its considered light for most modern production cars, my rx7 was 2700lbs and I felt it wasn't as nimble as the FRS around corners. If you take 200-300lbs off the Zx6 chassis, we really start to sacrifice that level of comfort we associate with a well balanced factory sports car. Taking off rear seats + factory seats, sound deadening, removing metal from the chassis, lighter wheels, etc,, by the time we reach 200-300lbs..you might as well strip the car down bare because its no longer that comfortable for street application... At this point you look at all the stuff you have done...you have a monster...all that work and effort. only to catch up to a modded 350z in performance (in terms of numbers)...while the 350z might even still be more comfortable to drive.
#53 | |
Drives: 2013 FR-S hot lava
#54 |
Drives: If god were a car he'd be an FR-S
200whp
#55 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Looking to get around 200whp with I/H/E/tune.
Then I will see if adding a Rotrex SC is in the cards at a later point in time. If it will result in >250whp I will probably go for it. |
#56 |
Drives: '13 Argento MT FR-S
Well I'm coming from a 500whp Charger SRT8 (497 sae and 4200+lbs, around 8.4lbs:hp) so simple numbers wise, I'm after about 300whp in my FR-S to be in the same ballpark.. I'm aware that's not as easy as it sounds... but the gearing in the FR-S is much better for acceleration than the top end of the SRT8.
In the meantime, I'm thinking intake, axle-back and a tune. Should give me enough grunt to evoke more SPG and reduce restrictions to raise MPG as well. Will wait on header and over/downpipe until I decide if I want to go turbo/sc or both. Seeing as I had about 7k into my SRT4, and 9k into my SRT8, this car should get about 10-11k invested before I'm ready to part with it, but then again... I went from a 21k car to a 40k car and back to a 26k car so who knows. |
#57 |
Drives: 2013 Scion FRS
300 whp or 250 wtq what ever comes first. If a turbo/supercharger isent to much I will go for that. Im gussing to get to my goal i will need.
-Exhaust -Intake -Headers -HKS Gasket (low compression) -Pistons -Maybe injectors and fuel pump? |
#58 | |
hmm. We've been watching the AFRs with the headers both on the dyno and on the street- they are pretty much the same as stock. I don't think it's a worry. At least with the nameless. I wouldn't run that junk chinese one we've seen around the forum, it looks terrible and might throw a CEL and/or mess with the motor a bit. I know I probably sound biased, haha. But it's true, I've had headers on the car for a week with zero issues. no limp mode, no CEL, nice and strong- did over 100 WOT pulls on it during the track day with no issues. That was all after several dyno pulls, data log events, and letting the car idle for a while, so I felt safe doing it. You get what you pay for I guess.
#59 |
SE Region Moderator
Drives: Limited BRZ
If you don't go for turbo and leave the car N/A, lowering compression will only result in loosing power, no gains at all. The gasket would be needed when you want to run higher Lbs. on forced injection.
#60 | |
That Guy
Drives: 2013 asphalt FRS MT
That said,I went out and checked the tag on my alternator and it says 12V 130A umungst other numbers. I wouldn't take that as gospel but it seems to me that it's a 130 amp alternator, no problem there. That only leaves the drivers in the ECU. Well and the wiring, but I'm not worried about that. |
#61 |
thanks for the info. So if i stay NA i will want the higher compression one?
#62 | |
NINJA MODERATOR #2
Drives: 87 FC3S TII
#63 | |
Inverse Animosity
Drives: Celica GT-S
Also, there are other members saying they want 300+whp and i don't think they've received the same level of scrutiny you've kind of aimed toward me. My Celica is stiff and gutted and i don't have a problem with it.
#64 | |
SE Region Moderator
Drives: Limited BRZ
There are different ways to go about it, but as a general rule, if your car is already 12.5:1 compression ratio and you are building an N/A setup, there is no gain in lowering the compression ratio, the only result is lower HP. The benefit of lowering compression ratio is it allows you to boost to higher psi. Example, both cars with engine built equally, only difference is 9:1 ratio and the other is 12.5:1, is that the 9:1 car will be able to hold higher boost without risking breaking it. This is in very simple terms there are more things into it, but it gives you an idea. |
#65 |
Drives: 2013 Scion FRS/whiteout,MT
mine is 750hp by next year, we will see if we can meet that goal
2013 Scion FR-s whiteout,MT "new project"
2013 Lancer Evolution X PB "wife's DD" '73 Porsche 911/964 turbo look Many old school V-dubs =) http://www.facebook.com/#!/groups/449832905027317/ <------South Florida Owners Page |
#66 |
Drives: MX5
200whp. NA setting, 9000+ rpm redline if possible.
250whp. Supercharge if possible. 7500 redline. adding less than 30 lbs of weight. Your goals seem to be insane.... how can a 350whp/1200kg car be a everyday car.. that's a horsepower monster.
| 100,000 Units Annual Goal for BRZ/FR-S/86 Announced by President of Fuji Heavy Indust | yajin | Subaru BRZ General Forum | 114 | 04-04-2012 03:24 PM |
| ft86.com has some serious horsepower! | MrBRZ | Off-Topic Lounge | 2 | 03-22-2012 06:45 PM |
| Pricing announced for Uk version. Question about Horsepower | maxeveland | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 02-24-2012 07:38 AM |
| Top 10 Lightest 300 Horsepower Cars | Axel | Other Vehicles & General Automotive Discussions | 2 | 11-22-2009 01:23 AM |
