BT, dpfarr
Old 01-20-2017, 04:37 PM   #2017
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
cool! thought it was just mine haha, maybe its just the cold weather here.
Thanks buddy!
Mine did during start-up for a min or so and would go away once I start moving.
umpadupa is offline   Reply With Quote
Old 01-20-2017, 05:06 PM   #2018
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Originally Posted by umpadupa View Post
Anyone hear some belt squeaking on their set up?
On start up randomly and then goes away.
Silverfox is offline   Reply With Quote
Old 01-21-2017, 07:47 PM   #2019
dejahboi
dejahboi's Avatar
Drives: 13 FRS - Boosted
I got to the very very end of the install and I came upon this connector. Where does it go? It's off the tmap harness. The harness is short so the connector is near. By the look of the instructions it should be directly behind the intake manifold sensor, but I don't see it all.
I'll take it apart tomorrow to see if I have anything left behind. Side note I forgot to hook up the green connector to the alternator. So many need to come off again.
dejahboi is offline   Reply With Quote
Old 01-22-2017, 01:17 AM   #2020
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Is this the connector that branches off the TMAP Sensor (labeled "MAP Engine Harness connector" in the manual on page 7)? If it is, that should be plugging into the MAP harness (see step 161).
No need to take it apart. Just loosen and gently lift. Be careful not to pull the manifold forward or side to side as you may risk tearing the intake gaskets.
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
dejahboi (01-23-2017), Muskoka800 (02-28-2021)
Old 01-22-2017, 02:53 AM   #2021
dejahboi
dejahboi's Avatar
Name:  TMAP connector.JPG
@BigFatFlip
Here's a picture of where I'm having trouble.
I got the harness hooked up to the according to step 161/164. Its the other end where I'm having trouble.
Is the TMAP sensor tucked underneath the SC?
Old 01-22-2017, 03:15 AM   #2022
BigFatFlip
BigFatFlip's Avatar
This is the TMAP sensor (red circle). Should be attached to one of the runners.
The Following User Says Thank You to BigFatFlip For This Useful Post:
Old 01-22-2017, 03:35 AM   #2023
dejahboi
dejahboi's Avatar
Sorry I was referring to the other MAP connector.
So it's the MAP connector I'm having trouble connecting/finding.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Old 01-22-2017, 10:43 AM   #2024
BigFatFlip
BigFatFlip's Avatar
Then that needs to go to the connector that was originally plugged into the stock MAP sensor on the stock intake.
Old 01-22-2017, 01:27 PM   #2025
dejahboi
dejahboi's Avatar
Yeah noob move on my part lmao. I tucked that connector towards the front when we lowered the SC in. I went back last night with a flash light and bam, unused connecter tucked away.
Anyways, install is not complete lol. Now to go drive it and get some logs lol
Old 01-22-2017, 03:09 PM   #2026
BigFatFlip
BigFatFlip's Avatar
Man... discount pricing AND tech support? I should have charged you more...
The Following 3 Users Say Thank You to BigFatFlip For This Useful Post:
dejahboi (01-23-2017), taiguy (01-27-2017), why? (01-22-2017)
Old 01-22-2017, 09:06 PM   #2027
dejahboi
dejahboi's Avatar
Haha! Thanks for the good deals!
So I'm now running Delicious . Finding open roads to get logs is terrible up here lol
The Following User Says Thank You to dejahboi For This Useful Post:
Old 01-23-2017, 01:43 PM   #2028
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
nah just drive down to walnut creek and go through tassajara =D
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
The Following User Says Thank You to Xxyion For This Useful Post:
Old 01-23-2017, 04:15 PM   #2029
dejahboi
dejahboi's Avatar
Took your advice and I was able to do my 2k to redline pulls .
Now just waiting on the revised tune.
Old 01-23-2017, 04:56 PM   #2030
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Just got my latest Delicious Tune Revision...We probably have a similar set-up.😁
Sent from my XT1031 using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
The Following User Says Thank You to paiceyfan For This Useful Post:
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 10:09 PM
