follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Scion FR-S / Toyota 86 > Scion FR-S / Toyota 86 GT86 General Forum
Old 06-26-2012, 03:22 PM   #23
FakeWhiteMan
Back From The Dead
Drives: Hot Lava FR-S
Send a message via AIM to FakeWhiteMan
Originally Posted by 7thgear View Post
Probably
FakeWhiteMan is offline   Reply With Quote
Old 06-26-2012, 04:50 PM   #24
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
well duh! If you left your rumble pack inserted you'll feel some enhanced force feedback. Check your OBD II port if it is installed there
mechaghost is offline   Reply With Quote
Old 06-26-2012, 05:02 PM   #25
No Quarter
Drives: 2013 Scion FR-S AT Hot Lava
Originally Posted by FakeWhiteMan View Post
Are you doing 90 degree turns? When I leave my road it's like the diff is locking completely up.
Yup, did some more "testing" today. Definitely with wheels turned sharply, and then accelerating from a stop, I get lots of tire squeal, even though I'm not trying to "burn out". Does feel like the diff is locked out.
No Quarter is offline   Reply With Quote
Old 06-26-2012, 05:05 PM   #26
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
Originally Posted by Silver Bullet BRZ View Post
Personally, I'd notify Optimus Prime.
Just sayin...
I just sent a PM to Megatron. Apparently I failed him again.
Starscream15 is offline   Reply With Quote
Old 06-26-2012, 05:09 PM   #27
Starscream15
Originally Posted by Snoopyalien24 View Post
YOUR ANSWER
Oh this is simple. You see, you accidently left TBCA on when you didn't need it. You know Thermo-pnumatic Boost Centrifugal Adjustment. What this does is, with heat from when the car runs for a while adjust faster (Boost) exactly what the center is, and maintains it there. AKA "Centrifugal Adjustment" using heat (thermo) and pistons (pneumatic). This is highly used in much more expensive higher-end cars. Most track cars love to use this technology, sacrificing ride quality (but who cares, its a trackcar) for awesome handling. The only down fall to this technology is that since sometimes this "rumble" may get worse over time but it wont really affect the car, or the TBCA at all.
Source: Right here and explains how to solve this problem as well
Old 06-26-2012, 05:17 PM   #28
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
Originally Posted by DyoGTS View Post
Does this only happen for the 10-20 feet outside of your driveway? Did they work on the street there in the past 6 months?
There is one specific spot in my neighborhood, right at a stop sign, where I get the same thing.... They recently re-poured the cement at that area (3 months) and the BRZ is the ONLY car that I can feel the difference on. Might be the same thing?
For that one specific spot, I'll put money on the pavement being the problem. Not the car. Even if your previous vehicles didn't do it, the fact that this car ONLY does it at that stop sign and not other signs says it's the location.
As far as turning sharp, it's the limited slip in the rear causing the tires to "chirp" under power. My FR-S does the same thing. So does my dad's GMC 2500 truck. Again, so does my dad's GMC Sonoma (pick-up with limited slip diff).
Are these things to be concerned about? NOPE!
Now, if it did the "rumble" at every start, then I'd worry. If it rumbled for several MILES in the morning, I'd worry. What has been described thus far in this thread seems like normal things for ANY car.
Lil Abner is offline   Reply With Quote
Old 06-26-2012, 05:30 PM   #29
ZILLA
BRZ #575
ZILLA's Avatar
Drives: 2013 BRZ #575
Mine WILL do it on every slow sharp turn. Very easy to reproduce ANYWHERE.
ZILLA
BRZ #575 SWP Limited
18x8" Drag DR-31 +48 | 235/40/18 | 6000K HID Low/High | Wrapped All Red Tail Lights | Rear Fog + Brake Light Combo Mod [Video]
ZILLA is offline   Reply With Quote
Old 06-26-2012, 05:33 PM   #30
Lil Abner
Correct. That's what I posted.
Old 06-26-2012, 06:11 PM   #31
5150unltd
Drives: 2013 Rally Blue Subaru BRZ Limited
rumble felt here as well
limited slip and tires was my 1st thought
5150unltd is offline   Reply With Quote
Old 06-26-2012, 11:33 PM   #32
civicdrivr
Lightness is a sickness
civicdrivr's Avatar
Drives: 03 Acura CL-S6 & 13 Scion FR-S 6MT
Yea, Im pretty sure its the diff. Mine does it when I move the car after being parked.
2003 NBP Acura CL-S 6MT, very very sleepy, 1 of 480
2013 FR-S 6MT, Asphalt, First 86
civicdrivr is offline   Reply With Quote
Old 06-27-2012, 01:36 AM   #33
old greg
Rocket Surgeon
Drives: PSM GGA OMG
It's the differential just doing it's thing. You are only noticing it on slow sharp turns because that's when you have the greatest difference in relative speed between the inside and outside rear tires (and also, a lack of wind and road noise to mask it). A slight "rumble" is fine, if it changes to "WTF is that ungodly clunking?" then you might have a problem... or just a cam and pawl diff.
old greg is offline   Reply With Quote
Old 06-27-2012, 01:00 PM   #34
ZILLA
BRZ #575
ZILLA's Avatar
Thank you for the feedback... It is comforting to hear, but strange no one else is really bringing this up. I have never felt this in any of my previous cars, a few of which had LSD
ZILLA
Old 06-27-2012, 01:14 PM   #35
mact
Drives: 13' SSM BRZ 6MT
My 2001 IS300 did this. Was an automatic too.
mact is offline   Reply With Quote
Those who coming from the TC?? csaba Scion FR-S / Toyota 86 GT86 General Forum 15 06-08-2012 11:18 PM
NJ- BRZ LIMITED COMING IN!!!! Jalmeida830 Subaru BRZ General Forum 48 06-02-2012 10:31 AM
When is the next shipment coming to LA? Liquidsnake Southern California 18 05-24-2012 12:03 PM
June 1st is coming up soon! rcm47 Scion FR-S / Toyota 86 GT86 General Forum 11 05-22-2012 06:20 AM
How to get that boxer rumble? ryude Engine, Exhaust, Transmission, ECU 42 01-28-2012 01:41 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
