follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Issues | Warranty | Recalls / TSB
Old 06-24-2012, 07:11 AM   #309
AshWilliams
Groovy
AshWilliams's Avatar
Drives: GMC Sierra
If it's chirping (and I'm going by experience from older cars/trucks)...
A bad throwout bearing in the manual transmission can cause chirping at idle, so can bad bearings in any of your pulleys.
There can be a intermittent chirps if you have oil on your belts/serpentine belt.
A constant chirping at idle can be a T/O bearing or any of the engine pulleys.
Share the road.
AshWilliams is offline   Reply With Quote
Old 06-24-2012, 10:53 AM   #310
Julio86
Julio86's Avatar
Drives: 2013 Scion FR-S 6MT
This is what I experienced last night after coming back from Dodgers vs Angels game ( in which dodgers won ;D) it's pretty loud. What should I do? Call scion, take it to the dealer? http://i63.photobucket.com/albums/h1...s/fefb7143.mp4
I don't always drift every corner, but when I do, I drift FRS . Stay drifty my friends
2013 Scion FRS Whiteout 6MT
Julio86 is offline   Reply With Quote
Old 06-24-2012, 12:32 PM   #311
yayforaddison
yayforaddison's Avatar
Drives: Whiteout FR-S
Not sure I'm seeing the issue here
yayforaddison is offline   Reply With Quote
Old 06-24-2012, 12:34 PM   #312
Julio86
Julio86's Avatar
Well the idle is very low n goes down to 400 at times. The high pitched chirp is what is loud. The video didn't capture how loud it really was but lemmie assure you it's pretty loud n high pitched.
Old 06-24-2012, 12:37 PM   #313
ZmZMWagon
Drives: MS3
You can hear the chirping, and it seems the RPM needle keeps bouncing up and down at idle....at least that's what I think he's talking about.
ZmZMWagon is offline   Reply With Quote
The Following User Says Thank You to ZmZMWagon For This Useful Post:
Julio86 (06-24-2012)
Old 06-24-2012, 12:39 PM   #314
Julio86
Julio86's Avatar
Exactly hat I'm talking about. Obviously I Hit the throttle a lil but it was to show how low the rpm would go. N along with the chirping sound.
Old 06-24-2012, 12:40 PM   #315
yayforaddison
Yeah I guess I do see it bouncing a little bit. Mine isn't really bouncing that I know of. Just dipping well below 500rpm and bouncing one time up past 1k till it comes to a normal idle. Meh, guess its just a waiting game to find out if its normal, or needs fixed.
The Following User Says Thank You to yayforaddison For This Useful Post:
Old 06-24-2012, 12:43 PM   #316
Julio86
Julio86's Avatar
Yeah I hope there's a fix for it. I heard of some guy on This forum that they fixed something on his engine n now he has no problem so it should be fixable. I think we need more ppl to call scion. I will be calling tomorrow.
Old 06-24-2012, 01:00 PM   #317
csaba
Drives: scion tc
it would be good to see a pool to how many people have this issuee!
thanks
csaba is offline   Reply With Quote
The Following User Says Thank You to csaba For This Useful Post:
Old 06-24-2012, 01:02 PM   #318
Julio86
Julio86's Avatar
thanks
+1
Old 06-24-2012, 06:11 PM   #319
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
In the video you can hear the high pitched cricket noise. I didn't see anything wrong with the rpms. However the cricket noise is not normal. There is a thread about this in the engine sub forum. A lot of people are getting this.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-24-2012, 06:14 PM   #320
Julio86
Julio86's Avatar
Yeah it wasn't dropping as much as it does from time to time, but the video was more for the noise. I just want a fix already. Idk bout everyone else but it really bugs me to hear this specially it being a new car :/
Old 06-24-2012, 06:40 PM   #321
Lonewolf
Resident Nice Guy
Lonewolf's Avatar
Drives: Moped
Someone needs to get a hold of a scope and trace the chirping sound.
It's too hard to tell from the video if it's a belt, a loose pulley, metal rattling from inside the motor, a tob, a leak, or something else.
Scope it and you should have an answer to your problem.
***Is it me, or does the sound go away under load?
Do people with automatics experience this chirp? If they don't, then it could be the TOB like others have said.
Lonewolf is online now   Reply With Quote
Old 06-24-2012, 07:18 PM   #322
feldy
feldy's Avatar
Yes I have the AT and have the cricket noise. It seems to be coming from the right side of the motor if you are facing it.
The Following 2 Users Say Thank You to feldy For This Useful Post:
Lonewolf (06-24-2012), Lowellrenzo (06-24-2012)
Old 06-24-2012, 09:14 PM   #323
Lowellrenzo
Drives: Civic Si coupe
Mine doing the same thing
Lowellrenzo is offline   Reply With Quote
Old 06-24-2012, 09:15 PM   #324
Asphaltfrs1
Drives: 2013 asphalt fr-s
Idk, but only time I notice the idle drop is when my A/C is on.
Asphaltfrs1 is online now   Reply With Quote
Old 06-24-2012, 11:11 PM   #325
Lytheum
Drives: 2013 BRZ Premium 6MT
confirmed the idle drop today in my brz for the first time. i was at a taco bell drive thru and noticed the rpms drop to about 400 then bounce up to 900...it then did it again but dropped to about 500 and jumped up a few then leveled out. the a/c was running with the fan on the lowest setting.
ill mention it at my first oil change or take it in if it keeps happening
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 06-24-2012, 11:20 PM   #326
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
This is different.
Your car wanted you to get away from Taco Bell...
(it's sad when you're tired enough to crack up IRL at your own jokes....)
Chewie4299 is offline   Reply With Quote
Old 06-25-2012, 01:15 AM   #327
Bonburner
Bonburner's Avatar
Drives: M/T Argento FRS
I'm at ~250 miles on the FRS and I've seen the idle rpm drop from ~750 to 500. At 500 it shakes a bit (the shifter) and almost sounds like its about to stall
Old 06-25-2012, 11:40 AM   #328
Hanzo
Hanzo's Avatar
Drives: Honda Fit
Originally Posted by whiteout fr-s View Post
alright guys,
As I am the first person to actually let Toyobaru technicians fully diagnose my car, Subaru and Toyota sent 2 technicians each from Japan too actually diagnose my engine and these issues we are experiencing.
So, to begin, the issues are NOT normal and need to be fixed. The technicians fixed some valves, readjusted cam angles etc.. but I will get the full repair specs Monday. They are also tracking my car tomorrow and Sunday to get full engine read outs for future FR-S owners. So as of Monday any of you experiencing this problem will have a fix, and a quick one at that.
I have not had my car for a month now because of this but I can tell you that as long as I know that future owners will not experience these problems it was well worth it. Good luck to everyone who has had this issue and if you are still experiencing this please take your cars to the dealership over the next month and your problems should be addressed a lot sooner than mine!
Any updates? Do you know if subaru is going to issue a TSB?
Hanzo is offline   Reply With Quote
Old 06-25-2012, 11:44 AM   #329
Jayde
Jayde's Avatar
Jayde is offline   Reply With Quote
Old 06-25-2012, 11:48 AM   #330
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2013 Scion FR-S (Firestorm - 6MT)
I get both of these often, but assumed the chirping was coming from the DI system like someone mentioned in another thread maybe?
Subscribed; I want to see what the manufacturer says
GT5 PSN: Koji_Online
XBoxLive ID: KojiOnline4
Koji_Online is offline   Reply With Quote
A Small Easter Egg avusblue Scion FR-S / Toyota 86 GT86 General Forum 28 06-28-2012 10:38 PM
Subaru BRZ - The biggest small car ever Laika Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 12:21 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 11:53 AM
Isn't 6-10 miles on a new car kinda high? houseofsuffering Subaru BRZ General Forum 46 05-15-2012 11:32 AM
Kinda make me worry! (Radiation related thing) EJ20 Off-Topic Lounge 32 05-08-2011 11:58 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
