Software Tuning Discuss all software tuning topics. |
#15 |
Drives: 2017 BRZ
#16 |
Drives: frs
#17 |
Drives: 2013 FRS
#18 |
Drives: frs
#19 |
Drives: FT86
ok guys here is some ZA1JK00C stock roms but with P0420 cat efficiency cel disabled and a second with cat efficiency and quiet start mods done. For guys who have fitted header to stop cel trip and not wake neighbors
get you through till OFT guys release full tune for headers for MY2017 K00C rom Just unzip and load into oft @gskv @justinco @Lonewolf Last edited by steve99; 10-12-2016 at 02:40 AM. |
The Following 6 Users Say Thank You to steve99 For This Useful Post: | GeorgeJFrick (01-13-2018), invaliduser (10-11-2016), justinco (10-11-2016), Lonewolf (10-12-2016), OrangeGuitar (06-08-2017), Teseo (10-11-2016) |
#20 | |
Drives: 2017 BRZ
Shiv just emailed me a test file for checksum verification. But noted to not load onto my car yet! |
#21 | |
Drives: FT86
thier is no tuning changes just cel code disabled the second rom with cold start mods is just ancillary changes tune is stock. |
#22 |
Drives: Scion FRS
Does anyone know how the new 2017 model gets around the torque dip? There has to be a change to the Headers or intake runner length. Tune alone cannot replace lack of airflow from experience.
#23 | |
Drives: FT86
intake manifold design change and its aluminium larger bend radius intake tube (similar to aftermarket offerings) air filter now paper based not cotton based, ie similar to aftermarket performance air filters new larger diameter primary tube header (still with integrated cat) |
#24 | |
Drives: Scion FRS
The bend and filter change appear just for top end air flow improvement. The trick can be in the larger diameter header that will now scavenge at a higher engine speed. The old headers hit peak scavenging at ~2800rpm I believe and from there on it died off slowly. Perhaps this one peaks at a later engine speed so by the time the scavenging dies off the power band picks up reducing the dip. This could sacrifice the really low end but who cares. |
#25 |
Drives: 17 86
As long as the FA20 is in the car, there will always be a torque dip. I did 400 miles on 101 today, and spent the majority of the trip under 4k and above the speed limit. What it needs now, though, is a seventh gear.
#26 |
Drives: 17 86
Somebody do this ASAP and report back. I'm going to wait for others success before I try again. Hope there is not something wonky with my particular car that caused a failure, but Shiv said all should have been well. Anyway, y'all hurry up and flash!
#27 |
btr.life
Drives: 2022 GR86
I got the same test file and it loaded to the OFT ok. Not flashing the car until he gives the go ahead. Plus, I want to get more miles on it.
#28 |
Drives: 2017 BRZ
I'm coming from a e92 m3 and that car has one of the best torque curves ever.
Changing the headers out makes it quite nice to not have the dip, but honestly the car is so good stock, it doesn't bother me that much. More power, drivability and slightly corrected curves are just nice bonuses. I've flashed my car with the test as per Shiv's instruction, he informed that he'll need a day or 2 to work out the tune! I did notice after flashing the test file, my car idled differently. Perhaps maybe I am on a Canadian car? :S |
openflash tablet vs ecutek tune | brz23 | Software Tuning | 104 | 07-28-2020 04:36 PM |
Openflash tune problem with brz | sgoldberg01 | BRZ First-Gen (2012+) -- General Topics | 6 | 02-09-2016 01:13 PM |
fi and openflash tune | Hachi6 | Forced Induction | 59 | 11-20-2015 01:28 PM |
OpenFlash-- header tune | mtimney | Forced Induction | 3 | 08-07-2014 03:51 PM |
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
