Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > DIY (Do-It-Yourself) Guides
Old 06-10-2012, 02:51 PM   #1
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
DIY-Replacing Rear View Mirror/Hardwire Radar Detector
DISCLAIMER: I am NOT responsible for any damage you may do to your car.
DISCONNECT THE BATTERY!!
Pull the rubber molding down around the door frame
Pull the top of the A-pillar trim towards the center of the car. You will see this:
These green clips need to come off:
Rotate 90-degrees with a pliers, and work them out. They can be tough.
Remove the 2 screws holding the visor in place
Using two flat-head screw drivers, push in the slots to pop the clips holding the visor mount in place. You do NOT need to push hard!
Repeat on other side.
Remove the light
This is the adapter you'll need. I bought it off eBay:
http://www.ebay.com/itm/290195434507...S:3160&vxp=mtr
Remove OEM mirror by twisting the base 90-degrees, then sliding down.
Remove OEM clip
Replace with clip from kit
Slide in piece
Put base on, and attach with screws
Pull down the head liner. NOTE, there is a white clip visible once the light comes down. Use your fingers to carefully detach it.
Look in the headliner. Thanks to ft86club member tonystewart pointing out, there is already a wire harness available. It is held in with blue tape.
There are 3 wires.
Blue: (+) Reverse
White: (+) Positive
Black: (-) Negative
Connect your wires for your mirror and/or radar detector according to the installation manual
Tuck the wires back up, and re-install all the stuff you took down. Once done, slide your mirror on and tighten the screw.
I used a short wire cover that was cut even shorter to hide the wires
Finished product
Lil Abner is offline   Reply With Quote
The Following 10 Users Say Thank You to Lil Abner For This Useful Post:
civicdrivr (06-13-2012), Dang Lad (06-24-2012), dsgerbc (06-10-2012), Fly Guy (06-12-2012), FlyLow (12-01-2013), frs23 (06-19-2012), GaN-MaN (07-23-2012), Guff (06-21-2012), mezdup (06-08-2013), normancw (06-11-2012)
Old 06-10-2012, 03:13 PM   #2
dsgerbc
Drives: BRZ(sold), STI
You can avoid pulling the headliner if you wire the radar to the mirror-side plug. You can then reach the harness with your hand through the map-light opening. Has the advantage of keeping the factory wiring intact.
Old 06-10-2012, 03:21 PM   #3
Lil Abner
Yeah, I guess that could make it easier
Old 06-11-2012, 08:55 AM   #4
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Outstanding effort,thank you
tonystewart is offline   Reply With Quote
Old 06-20-2012, 07:11 PM   #5
MidnightMonkey
I am the one who knocks!
MidnightMonkey's Avatar
Drives: 2013 Whiteout FR-S MT
what are those wire junctions called? and where can i get em?
MidnightMonkey is offline   Reply With Quote
The Following User Says Thank You to MidnightMonkey For This Useful Post:
skye67 (01-25-2014)
Old 06-20-2012, 07:15 PM   #6
Lil Abner
Red T-Taps. Make sure they are RED. Autoparts stores should have them. Otherwise here is an eBay page I quickly pulled up:
http://www.ebay.com/itm/25-3M-951-T-...item2c65b1d789
Old 06-20-2012, 10:12 PM   #7
FRSpdDmn
Drives: 128i, Z3 Coupe, Fiero GT
Please help me understand... I found the "extra" harness (probably for the BRZ auto-dimming mirror?) and I found the 3 wires you described. I checked for voltage on them. I got 0 on blue, 0 on white, and 0.06V on the black wire. I was touching off on one of the body bolts inside of the door for ground. I checked the lamp wires and found 12V, so I had a good ground. I did this with the key both ON (RUN) and OFF.
I am wiring in a Valentine 1. My understanding is that I am looking for switched 12V to tap into, right? Did you find 12V on that "extra" harness?
Thanks.
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT
2017 Pirelli World Challenge TC Rookie of the Year
2012 NASA SpecE30 National Champion
www.DriveFasterNow.com
FRSpdDmn is offline   Reply With Quote
Old 06-21-2012, 06:26 AM   #8
Lil Abner
The BLACK wire is ground (-)
The WHITE wire is 12V (+) switched
The BLUE wire is 12V (+) for reverse
For your V1, use the Black (-) and White (+).
Old 06-21-2012, 08:27 AM   #9
blalor
Drives: WRB BRZ Limited 6MT
Nice write-up. I hard-wired my V1 to the fuse box; I got a little add-a-fuse thing that uses an empty slot in the fuse box. I ran the wire from the right side of the mirror, tucked it into the front edge of the headliner, and ran it down behind the A-pillar trim. You don't have to remove the weatherstripping: just squeeze the trim at the top near the headliner and it will pop off. I didn't disconnect it from the green clip; I was able to get the bottom of the trim away from the dash, leaving more than enough room for running the wire behind it. I made sure to run the wire behind the existing bundle of wires to avoid fouling the air bag.
I prefer this solution to cutting wires. The only modification I had to do was to drill a hole in the fuse box cover so that the add-a-fuse could poke through.
blalor is offline   Reply With Quote
Old 06-21-2012, 05:06 PM   #10
was385
Drives: MT WRB BRZ Limited, 2007 911s
I'm going to need to read up on how to do this for my radar detector. I really hate the cord always being in front of the shifter and my line of sight.
was385 is offline   Reply With Quote
Old 06-21-2012, 07:49 PM   #11
tonystewart
I'm buying a Savvy for my daughters V1 setup, just run one wire across the roof line and down the drivers A pillar to the OBD Port
Old 06-22-2012, 02:31 AM   #12
Gt86er
Gt86er's Avatar
Instead of hardwiring the radar detector just use the 12v jack that hidden in the glovebox. It's on the top right hand side in the FR-S. no cutting or splicing wires
Gt86er is offline   Reply With Quote
The Following User Says Thank You to Gt86er For This Useful Post:
gmookher (10-29-2012)
Old 06-22-2012, 07:34 AM   #13
was385
For me, there was really no benefit to doing that. My cord barely reached and was pulling the detector, it's still in your line of site and looks sloppy, and I can't close the glove box.
Old 06-22-2012, 10:55 AM   #14
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Oh wow! Awesome write up!
Direct wire radar detector Kieranz Electronics | Audio | NAV | Infotainment 25 11-02-2015 01:01 AM
What will you hang from your rear view mirror? Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 151 11-15-2013 03:52 PM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 04:31 PM
Mounting radar detector video ayau Photos, Videos, Wallpapers, Gallery Forum 10 06-07-2012 11:29 AM
Rear view Mirror pic nixeighty6 Photos, Videos, Wallpapers, Gallery Forum 45 01-27-2012 06:10 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
