follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Electronics | Audio | NAV | Infotainment
Old 06-12-2012, 10:48 PM   #1
ruskymx
ruskymx's Avatar
Drives: 13 HotLava FRS, 93 4Runner, 97 Taco
Using Factory USB port with Aftermarket HU
I came across this when I was searching about using the factory USB port with an aftermarket deck. I want to install either a Pioneer AppRadio 2, which I already bought and I have sitting in my dining room, or a AVIC-X940BT. I've been second guessing myself after buying the AppRadio 2 and I'm thinking about returning it and getting the 940BT. Actually, I'm pretty sure that's what I am going to do.
Anyway, here's the link to the write up to be able to use the factory USB port. It's done on a Tacoma, but the port looks like it is the same so it should work.
http://www.tacomaworld.com/forum/aud...head-unit.html
I just need to figure out how to use the factory mic with the Pioneer unit and I'm set. I would rather not have a second mic in the car if I don't have to. From my searching, this seems like it's going to be the hardest part.
Ruskymx
ruskymx is offline   Reply With Quote
The Following 5 Users Say Thank You to ruskymx For This Useful Post:
cmarks20 (04-22-2013), Dadhawk (06-13-2012), DkY in Vcr (01-31-2013), kmbkk (06-16-2012), lordtakuban (07-23-2012)
Old 06-13-2012, 10:11 AM   #2
keithbribac
Drives: Gray
I just did this mod 2 days ago. Usb and aux works good with my pioneer 8400. I would like to know how to use the factory mic as well
keithbribac is offline   Reply With Quote
Old 06-13-2012, 05:22 PM   #3
Mblanchard
Drives: Tc
Frs
How did you get the aux to work?it plays video through this.did you wire up the usb or hot glue it in?
Mblanchard is offline   Reply With Quote
Old 06-13-2012, 06:09 PM   #4
keithbribac
Drives: Gray
http://www.scionlife.com/forums/showthread.php?t=207173
I used this guide. Everything works. Aux does not play video, only through usb. I used gorilla glue to glue the usb plug in place.
Old 06-14-2012, 08:58 AM   #5
Cessblood
Drives: Raven FR-s, Lexus ES300, & Turbo tc
I have the AVIC-X940BT too. I might install mine this weekend.
Cessblood is offline   Reply With Quote
Old 06-14-2012, 05:34 PM   #6
DYOLF26
Hey I'm looking into getting the same Pioneer head unit. I'm curious to know where you got yours from? On their website they retail at $999 but i see them on Ebay new right at $600. Did you find it cheaper anywhere else? Also do you know if you need additional parts for it to play video while car is moving?
Thanks in advance ha.
DYOLF26 is offline   Reply With Quote
Old 06-15-2012, 08:31 AM   #7
ruskymx
ruskymx's Avatar
You will need Metra 70-1761 wiring harness ($5.39 w free S&H), Metra 95-8202 mounting kit ($10.75 w/ free S&H), and Scosche LSAAB Antenna adapter ($9.55 w/ Free S&H).
I didn't buy the 940BT yet, but eBay and Amazon have it cheapest. If you have an Amazon Rewards credit card, I think you can get an additional 3% in points to use towards future purchases. If you open a new account, they'll give you $30 instant gift card. eBay will give you 2% back in eBay Bucks. Since I don't want another credit card, I'm probably going to buy it from eBay. I have $11+ in eBay Bucks now and this would give me another $12. I'll be able to buy something in July for about $23 off.
If someone wants to buy from Amazon, I have a link on my blog (link in sig)
Ruskymx
The Following User Says Thank You to ruskymx For This Useful Post:
KRAZYK (07-23-2012)
Old 06-15-2012, 08:58 AM   #8
Scooby
Scooby's Avatar
Drives: Audi A5 Coupe
Can you show us a pic of how it looks installed? Thanks.
Scooby is offline   Reply With Quote
Old 06-15-2012, 01:58 PM   #9
keithbribac
Drives: Gray
Here you go
Old 06-15-2012, 03:13 PM   #10
Scooby
Scooby's Avatar
Here you go
Thanks :-) but I actually meant the head unit.
Old 06-15-2012, 05:23 PM   #11
keithbribac
Drives: Gray
The Following 5 Users Say Thank You to keithbribac For This Useful Post:
Dadhawk (06-15-2012), normancw (06-27-2012), Roborat (08-13-2012), Scooby (06-18-2012), slaxx (08-14-2012)
Old 06-16-2012, 04:55 PM   #12
DYOLF26
Ruskymx
Thanks a bunch! Especially for listing off all the part numbers for the wiring harnesses and such. This will definitely be my second addition to my Raven FR-S when it is delivered, after tint of course.
Old 06-16-2012, 10:04 PM   #13
encity5
encity5's Avatar
sorry if this question is a little obvious, but I want to replace my stock unit with the X940BT as well. The parts you listed about, (wiring harness, mounting kit, LSAAB antenna adpater)
What exactly do i need them for? I was going to buy the unit soon, but it sounds like before i can install it, ill obviously need more than just the headunit itself. How simple is it to wire everytihng together?
Any help is appreciative, thanks, just trying to learn more about this stuff
encity5 is offline   Reply With Quote
Old 06-17-2012, 08:27 AM   #14
ruskymx
ruskymx's Avatar
The wiring harness is needed so you don't have to chop your factory harness up and makes it so much easier to wire everything up correctly. The mounting kit is needed to fill the gaps along the sides of the radio because most aftermarket radios won't be as wide as the original. The antenna adapter is needed so you can hook up the radio antenna to the 940BT. Without out this, it's like trying to fit a square peg into a round hole
Ruskymx
encity5 (06-17-2012)
Old 06-17-2012, 08:36 AM   #15
encity5
encity5's Avatar
Ruskymx
Ruskymx
amazing, thanks for the clear explanation, that really helps and makes sense now!
So is the installation of one of these units essentially, wire the wiring harness to the wires that the headunit comes with, then just plug that into the factory harness? install the unit itself and route the wires and such and done?
Old 06-17-2012, 09:14 AM   #16
ruskymx
ruskymx's Avatar
Yes, that's about it unless you want to use the factory USB port. Then you need to follow the steps in the link that I have in the first post.
Ruskymx
Old 06-20-2012, 02:44 PM   #17
xxthrillxx
SoCalFR-S.com
xxthrillxx's Avatar
Drives: Scion FR-S
going to try this soon... just purchased a sony xav601bt... hopefully i can make all my factory shenanigans work
xxthrillxx is online now   Reply With Quote
Old 06-21-2012, 09:35 AM   #18
encity5
encity5's Avatar
Originally Posted by xxthrillxx View Post
check this out:
You know that link is the same link in the first post (the reason for the thread)
Old 06-21-2012, 11:56 AM   #19
xxthrillxx
SoCalFR-S.com
xxthrillxx's Avatar
Drives: Scion FR-S
Yeah my bad, i had a different link, but managed to copy the same one
ill find the other one again...
Old 06-26-2012, 12:13 PM   #20
kndonlee
I've been trying to do this, but it seems like it should be possible to use that 3rd radio harness to splice into/aftermarket connector to wire up the USB & AUX. It seems that that 3rd harness is a newer harness.
Also, somewhere I read about the microphone above the light being usable, but it's a 4 wire setup which is supposed to be for an amplified mic. Any resources on converting an amplifed mic setup to a non-amplified 2-wire mic?
kndonlee is offline   Reply With Quote
Old 06-26-2012, 01:21 PM   #21
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex, U-28
I'm interested in doing this as well!
kmbkk is offline   Reply With Quote
Old 06-26-2012, 02:57 PM   #22
kndonlee
It seems like that 3rd harness would have the key to being able to wire up the built-in USB/AUX/Mic ports without taking apart the dash or replacing the ports. Anyone have any idea on what kind of adapter is needed for that 3rd harness?
The bestbuy audio guy taking a look at that third harness seemed to think it was a new harness type he had not seen before.
Auto Factory Aftermarket exhaust ESBjiujitsu Engine, Exhaust, Transmission, ECU 106 05-07-2013 02:43 AM
More Scions in Richmond Port. Marloon CANADA 203 06-07-2012 12:43 PM
More shots from the Port of Portland DarrenDriven Photos, Videos, Wallpapers, Gallery Forum 10 05-11-2012 12:04 PM
Look what I spotted at the port of LB today Trojan_SC Southern California 4 05-09-2012 01:40 PM
Southeast Cars are In Port! Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 3 04-27-2012 10:39 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
